6 Replies Latest reply on Sep 1, 2015 10:47 AM by Zac Lam
    MakeAudioRenderer() unknown error compiling movie
    ttoinoud Level 1
      I just compiled the SDK Exporter sample plugin and trying to export a file to .sdk results in «error compiling movie».
      Turns out the last instruction I can debug is about MakeAudioRenderer.
      In the 2015 documentation its written «The Sequence Audio Suite is now at version 2, revising MakeAudioRenderer() to take PrAudioChannelLabel* as a parameter.»
      But here is the line of code from the sample plugin :
          mySettings->sequenceAudioSuite->MakeAudioRenderer(    exID,
                                                              exportInfoP->startTime,
                                                              (PrAudioChannelType)channelType.value.intValue,
                                                              kPrAudioSampleType_32BitFloat,
                                                              (float)sampleRate.value.floatValue,
                                                              &audioRenderID);
      Thanks in advance,
      Antoine.
        • 1. Re: MakeAudioRenderer() unknown error compiling movie
          Zac Lam Adobe Employee
          Hi Antoine,
          Thanks for reporting this, I'll check it out.
          • 2. Re: MakeAudioRenderer() unknown error compiling movie
            ttoinoud Level 1
            Thank you for checking this out. I am currently creating an exporter for APP & AME and have others video-related issues. Did you try to use the sample SDK Exporter with anamorphic pixels and interlaced video ? Sometimes it just doesn't work (no error message, the .sdk is just filled with the headers : no frames were written). Antoine.
            • 3. Re: MakeAudioRenderer() unknown error compiling movie
              Hi Toinou,
              There does seem to be a problem with calling MakeAudioRenderer() using version 1 of the sequenceAudioSuite.  Version 2 should work.
              The 2nd issue you mention is the fact that the async rendering code in the exporter sample is not complete in SDK_Exporter.cpp.  Starting from this code:
              mySettings->videoSequenceParser->GetRTStatus(videoTime, segmentEnd, playcode);
              if (playcode == PRT_PLAYCODE_REALTIME)
              else
              You can just replace it all with:
              result = RenderAndWriteVideoFrame(videoTime, exportInfoP);
              • 4. Re: MakeAudioRenderer() unknown error compiling movie
                Hi Toinou,
                The problem calling MakeAudioRenderer() using version 1 of the sequenceAudioSuite is in the SDK exporter sample.
                When acquiring/releasing sequenceAudioSuite in SDK_Exporter.cpp, it is acquiring version 2, but then in usage it uses version 1:
                Replace:
                spError = spBasic->AcquireSuite(
                    kPrSDKSequenceAudioSuite,
                    kPrSDKSequenceAudioSuiteVersion,
                    const_cast<const void**>(reinterpret_cast<void**>(&(mySettings->sequenceAudioSuite))));
                with:
                    kPrSDKSequenceAudioSuiteVersion1,
                and replace:
                if (lRec->sequenceAudioSuite)
                    result = spBasic->ReleaseSuite(kPrSDKSequenceAudioSuite, kPrSDKSequenceAudioSuiteVersion);
                with:
                    result = spBasic->ReleaseSuite(kPrSDKSequenceAudioSuite, kPrSDKSequenceAudioSuiteVersion1);
                • 5. Re: MakeAudioRenderer() unknown error compiling movie
                  tit_toinou Level 1
                  Hi Zac,
                  Looks like it is working now, thank you, I'll work with the audio now.
                  Thanks for the tip to render videos with non squre PAR and/or interlaced.
                  I'm testing the SDK example with a bunch of weird videos...
                  I have a debug assertion thrown (MSVCP120.DLL, file VC/include/list line 210, "Expression list iterator not dereferencable", the issue seems to be in the ParseSequence function), here is a link to download the PP project and video : Dropbox - PremiereProSDKExporterBug tit toinou.zip
                  Antoine.
                  • 6. Re: MakeAudioRenderer() unknown error compiling movie
                    Ah, again you have hit some test code that is not fully complete.  You'll notice the comment immediately above the call to ParseSequence():
                    // The following code is in progress to test the new custom pixel format support
                    So feel free to comment out that block of code.  I am cleaning up the sample code based on your feedback, thanks!
