1 Reply Latest reply on Aug 11, 2015 4:16 PM by ManiacJoe
    Can't export or import in LR 6
      I am unable to export or import photos into lr 6. The export error message is "file could not be written" and some export functions were not performed."  Can you help
        • 1. Re: Can't export or import in LR 6
          ManiacJoe Adobe Community Professional
          Files could not be written
          Check your directories for the needed permissions. You need READ and WRITE.
          "some export functions were not performed"
          Check your export settings, down at the bottom, the "post processing" section. If the "application" line is empty, make sure the "after export" box says "do nothing".
          If these do not solve your problems, you need to include an actual detailed description of the problems you are having.
