6 Replies Latest reply on Aug 18, 2015 6:55 PM by niblung3
    Problems Rendering Environment Layer
    niblung3
      Using the latest version of AE, on a new iMac 27" Retina, the following problem occurs.
      Environment layers display fine within AE, however whenever I go to render the composition, AE is treating the environment layer as a flat 2d layer.
      For instance, suppose you create a comp where the camera pans 360 degrees around an environment layer.  In the RAM preview, the shot will look as expected,
      continuous image wrapped around the scene.  However, when I render this comp ou, what I get is the camera panning until it reaches the end of the image, and from then on the comp is black.
      I've tried various output formats, and get the same result, both in the AE render, as well as Media Encoder.
      Anyone ever encountered this before?
      Thanks, Mike
