10 Replies Latest reply on May 14, 2006 6:23 AM by Newsgroup_User
    CSS hover problem
    Level 7
      www.westernturnpike.com/prototype.htm
      I want the text color, background color, and border to change on the entire
      button, but only the text picks up the change when you hover/rollover.
      How can I get the effect to work for entire button?
      Paul
        • 1. Re: CSS hover problem
          Level 7
          An easier way than your doing it is to use unordered lists, instead of table
          rows. Create your navigation menu something like this:
          <ul>
          <li><a href="#">Course Layout</a></li>
          <li><a href="#">Daily Rates</a></li>
          <li><a href="#">Scheduled Events</a></li>
          <li><a href="#">Membership</a></li>
          <li><a href="#">Contact</a></li>
          </ul>
          In your CSS, you'd style your :
          #nav li a { }
          (this will give you the look of any linked list-item)
          And then to style it on :hover, you'd style this :
          #nav li a:hover { }
          Also, be sure to style your actual list the way you want it, like so :
          #nav ul { }
          Hopefully this points you into the right direction. I know it is possible to
          do with tables, but unordered lists are much cleaner, IMHO.
          Shane H
          shane@NOSPAMavenuedesigners.com
          http://www.avenuedesigners.com
          "P.F." <paul@orion-ics.com> wrote in message
          news:e44tns$49l$1@forums.macromedia.com...
          > entire
          > Thanks,
          > Paul
          • 2. Re: CSS hover problem
            Level 7
            Oh my goodness .. okay, I will try.
            other suggestions welcome. :-)
            "Shane H" <shane@NOSPAMavenuedesigners.com> wrote in message
            news:e44ub9$4v1$1@forums.macromedia.com...
            table
            > <ul>
            > </ul>
            > #nav li a { }
            > #nav li a:hover { }
            > #nav ul { }
            to
            > Shane H
            > > entire
            > > Thanks,
            > > Paul
            • 3. Re: CSS hover problem
              Level 7
              I should also make note, for that code supplied - you'd add this #nav ID
              like so :
              <div id="nav">
              <ul>
              <li>....</li>
              </ul>
              </div>
              Shane H
              > table rows. Create your navigation menu something like this:
              > <ul>
              > </ul>
              > #nav li a { }
              > #nav li a:hover { }
              > #nav ul { }
              > to do with tables, but unordered lists are much cleaner, IMHO.
              > Shane H
              >> entire
              >> Thanks,
              >> Paul
              • 4. Re: CSS hover problem
                Level 7
                Okay .. thanks ...
                any hint or example on style sheet entries that are similar to what I am
                looking for?
                I will be trying meanwhile.
                news:e44uld$58u$1@forums.macromedia.com...
                > like so :
                > <div id="nav">
                > <ul>
                > <li>....</li>
                > </ul>
                > </div>
                > Shane H
                > > <ul>
                > > </ul>
                > > #nav li a { }
                > > #nav li a:hover { }
                > > #nav ul { }
                possible
                > > Shane H
                > >> entire
                > >> Thanks,
                > >> Paul
                • 5. Re: CSS hover problem
                  Level 7
                  > Thanks,
                  > Paul
                  Check the uberlinks tutorial on Projectseven.com
                  Bonnie in California
                  kroko at
                  sbcglobal dot net
                  http://www.theanimalrescuesite.com/cgi-bin/WebObjects/CTDSites.woa
                  • 6. Re: CSS hover problem
                    Level 7
                    thanks .. would you have a link to the toot?
                    "Bonnie" <"kroko[Occam]"@sbcglobal.net> wrote in message
                    news:e44vae$5tv$1@forums.macromedia.com...
                    entire
                    > > Thanks,
                    > > Paul
                    > kroko at
                    > sbcglobal dot net
                    • 7. Re: CSS hover problem
                      Level 7
                      Here you go:
                      http://www.projectseven.com/tutorials/css/uberlinks/index.htm
                      kroko at
                      sbcglobal dot net
                      • 8. Re: CSS hover problem
                        Level 7
                        tyvm Bonnie in CA
                        news:e450rd$7kt$1@forums.macromedia.com...
                        > Here you go:
                        > kroko at
                        > sbcglobal dot net
                        • 10. Re: CSS hover problem
                          Level 7
                          Going the unordered list route is probably the best way, but if you want to
                          make a table cell clickable, here's an example with the associated css....
                          http://www.dreamweaverresources.com/tutorials/clickable_cell.htm
                          Nadia
                          Adobe� Community Expert : Dreamweaver
                          http://www.csstemplates.com.au - CSS Templates | Free Templates
                          http://www.DreamweaverResources.com - Dropdown Menu Templates|Tutorials
                          http://www.macromedia.com/devnet/dreamweaver/css.html - CSS Tutorials
                          > entire
                          > Thanks,
                          > Paul
