28 Replies Latest reply on Aug 12, 2015 4:50 PM by picenilllo
    lag - seriously bad - how can i reduce
    adzatpew
      im using 13.5.1.48
      most operations are fast, but moving a pivot point (pan behind tool) or sliding layers in the timeline, there is enormous lag and when i let go of the mouse and move it the layer or pivot adopt this mose, even though i have released the mouse
      so i am having to manipulate (slowly) the content, then pause for a second
      this is really slowing me down
      how can i improve performance of this?
        • 1. Re: lag - seriously bad - how can i reduce
          StormyCPb Level 3
          Are your elements located on a fast/separate hard-drive? How big (dimensionally & size) and what type of files are they? Do you have any adjustment layers in your comp with effects on or any heavy processing effects on the elements themselves (like any blurs for example)?
          • 2. Re: lag - seriously bad - how can i reduce
            adzatpew Level 1
            i have 4 physical HDs
            the work is stored on a different drive to the install
            the content is just a text layer.....and nothing else
            it doesnt matter if i have a single solid or a comp full of stuff, the lag is exactly the same...it doesnt seem to be resource dependent ....but rather a fundamental flaw in the performance of AE
            • 3. Re: lag - seriously bad - how can i reduce
              StormyCPb Level 3
              Do you have a chock full font library? I've read that having too many fonts installed can cause issues....
              • 4. Re: lag - seriously bad - how can i reduce
                adzatpew Level 1
                i have installed maybe 40 fonts on top of the basic opsys ones
                but the issue is not limited to text layers.....it is any layers
                • 5. Re: lag - seriously bad - how can i reduce
                  StormyCPb Level 3
                  there is a chance you have a defective font... test and see what happens if you remove all of the ones you installed (saving them first!), try AE on the basic opsys ones, if it's solved then you'll know (just not which font!)
                  • 6. Re: lag - seriously bad - how can i reduce
                    StormyCPb Level 3
                    I say that because to me it sounds like AE is struggling to establish a link to something, like a network or damaged file....
                    • 7. Re: lag - seriously bad - how can i reduce
                      adzatpew Level 1
                      if i create a brand new project....the layers solids and text all work smoothly.....so it must be something inherently wrong with my current project
                      i am currently on save iteration 1056....would that affect it?
                      it contains hundreds of comps...thousands of layers.....although each individual comp only contains a dozen or so layers
                      so even if i create a brand new comp in this project, everything lags
                      so i guess to refine the problem....given this project is composed of lots of shots and i am reluctant to break it down into smaller chunks.....is there a an inherent issue with after effects not liking large projects?
                      • 8. Re: lag - seriously bad - how can i reduce
                        StormyCPb Level 3
                        Not really no, AE doesn't usually freak with large project files, just how you use certain effects is the main culprit. Create a report and copy/paste here all the effects and lets see...
                        • 9. Re: lag - seriously bad - how can i reduce
                          StormyCPb Level 3
                          It's not a fan of most audio formats tbh, wavs are usually safe tho, and try and keep all your video the same format/codec. Does your footage and comp fps settings match too? Are you timewarping or using motion-pixel blurring?
                          • 10. Re: lag - seriously bad - how can i reduce
                            adzatpew Level 1
                            1. how do i create a report?
                            2. comps with just a single solid and no audio have the same issue....literally nothing in the comp, just a single solid....dragging the pivot or the layer on the timeline is laggy.....
                            • 11. Re: lag - seriously bad - how can i reduce
                              StormyCPb Level 3
                              File > Dependencies > Collect Files - then tick the Report Only box and save....
                              • 12. Re: lag - seriously bad - how can i reduce
                                StormyCPb Level 3
                                you can also scan through all your elements in case one is accidentally on the network or crappy HD or something....
                                • 13. Re: lag - seriously bad - how can i reduce
                                  adzatpew Level 1
                                  Report created:
                                    12/08/2015 21:05:47
                                  Project name: Retirement #1063.aep
                                  Source files collected: All
                                  Collected comps:
                                    Basic character source 2015 07 18
                                    Shadow
                                    Body
                                    Eyes
                                    Arms
                                    Basic setup
                                    Test Shot
                                    01 planning ahead T
                                    02 when could i retire T
                                    03 state pension and tax T
                                    04 guidance guarantee & getting advice T
                                    05 how can you use your dc plan for retirement T
                                    06 how you can take your db pension T
                                    07 db protection in retirement T
                                    08 db avcs T
                                    09 work and money T
                                    10 health T
                                    11 leisure T
                                    12 getting ready for retirement T
                                    001001
                                    001002
                                    001003
                                    001004
                                    001005
                                    001006
                                    001007
                                    001008
                                    001009
                                    001010
                                    001011
                                    001012
                                    001013
                                    PLANNING AHEAD Comp 1
                                    WHEN COULD I RETIRE? Comp 1
                                    STATE PENSION and TAX Comp 1
                                    GUIDANCE GUARANTEE & GETTING ADVICE Comp 1
                                    HOW CAN YOU USE YOUR DC PLAN FOR RETIREMENT? Comp 1
                                    HOW YOU CAN TAKE YOUR DB PENSION Comp 1
                                    DB - PROTECTION IN RETIREMENT Comp 1
                                    DB - AVCs Comp 1
                                    WORK and MONEY Comp 1
                                    HEALTH Comp 1
                                    LEISURE Comp 1
                                    GETTING READY FOR RETIREMENT Comp 1
                                    friends
                                    001001 A
                                    sky
                                    1
                                    beach
                                    caravan
                                    2
                                    3
                                    back
                                    fore
                                    van
                                    4
                                    back
                                    fore
                                    5
                                    6
                                    B&Q apron
                                    purse
                                    moth
                                    thought bubble
                                    Day to day A
                                    dumbell
                                    Older person
                                    birthday rosette 67
                                    coin facing
                                    coin stacking
                                    Month calendar
                                    book for stacking
                                    pencil
                                    Table
                                    overlays
                                    basic cordless phone
                                    buttons
                                    Expert A
                                    expert 004 only
                                    ipad front
                                    04 gov uk
                                    Basic browser source
                                    webpage-01
                                    04 gov uk
                                    calculate button
                                    ipad front 04 gov uk
                                    calculator
                                    fade to calculator
                                    bus
                                    bus back
                                    bus front
                                    cottage
                                    blue sky
                                    back
                                    fore
                                    door Comp 1
                                    mortgage statement
                                    paid stamp
                                    rent bill
                                    pension pot
                                    coins into pot
                                    birthday banner
                                    fitting
                                    001014
                                    09 lots of help
                                    001015
                                    back
                                    comp
                                    fore
                                    flip chart
                                    wheelbarrow
                                    hard hat
                                    3 puzzle pieces
                                    001016
                                    back
                                    fore
                                    Basic partner
                                    dream flower
                                    dream parachute
                                    001017
                                    banner
                                    inside drawers
                                    001018
                                    back
                                    Basic setup with parachute
                                    how?
                                    cash?
                                    defer?
                                    fun?
                                    time?
                                    parachute opening
                                    002001
                                    002002
                                    002003
                                    002004
                                    002005
                                    002006
                                    002007
                                    002008
                                    002009
                                    002010
                                    002011
                                    002012
                                    002013
                                    002014
                                    002015
                                    002016
                                    vid2 character
                                    walking frame
                                    brief case for carrying
                                    skateboard
                                    archive box
                                    002 back
                                    a
                                    Group 1
                                    door
                                    b
                                    c
                                    one
                                    a
                                    b
                                    c
                                    two
                                    tea mug
                                    002002 B
                                    back
                                    foreground
                                    fade to
                                    002003 A
                                    ground
                                    trees a
                                    trees b
                                    trees c
                                    trees d
                                    trees e
                                    signs
                                    car
                                    003001
                                    003002
                                    003003
                                    003004
                                    003005
                                    003006
                                    003007
                                    003008
                                    003009
                                    003010
                                    vid3 tax man
                                    money bag single basic
                                    wheelbarrow official
                                    003001 a
                                    back
                                    fore
                                    scene
                                    vid3 main character
                                    scene 2
                                    simple? Comp 1
                                    text
                                    vid3 mustache
                                    ? Comp 1
                                    ? Comp 2
                                    male
                                    female
                                    Day to day blank
                                    cheque 113
                                    cheque 150
                                    003011
                                    waiting
                                    waiting
                                    004003 waiting
                                    vid3 main character golf putt
                                    golf hat
                                    vid3 tax man mirrored
                                    wheelbarrow official mirrored
                                    003012
                                    money bag single basic mirrored
                                    vid3 main character raking
                                    rake
                                    vid3 worker with pick axe
                                    sledge hammer
                                    003013
                                    back
                                    fore
                                    vid3 NI collector
                                    003014
                                    back
                                    fore
                                    003007 door
                                    003008 a
                                    8 b
                                    003008 b
                                    Group 1
                                    Group 2
                                    vid3 tax man shot 9
                                    vid3 main character shot 9
                                    005001
                                    005002
                                    005003
                                    005004
                                    005005
                                    005006
                                    005007
                                    005008
                                    005009
                                    005010
                                    005011
                                    005012
                                    005013
                                    005014
                                    005015
                                    005016
                                    005017
                                    digger
                                    driving digger
                                    piggy bank
                                    005018
                                    Group 1
                                    Group 2
                                    wages
                                    Basic wheel barrow and pot
                                    005019
                                    Group 1
                                    005002B
                                    the deal main
                                    money
                                    single note
                                    the deal business
                                    pension pot no shadow
                                    A
                                    005020
                                    B
                                    C
                                    Annuity Cash Out Drawdown Phased Retirement Comp 1
                                    Pre-comp 1
                                    Pre-comp 2
                                    small pot
                                    baseball cap
                                    old walk carrying big pot
                                    005021
                                    Group 2
                                    Group 1
                                    annuity pot no shadow
                                    plain
                                    cap
                                    dress
                                    plain mirrored
                                    annuity pot
                                    saying yes
                                    milk
                                    Basic shopping trolley and pot
                                    shopping trolley
                                    005022
                                    Group 1
                                    Group 2
                                    Pre-comp 3
                                    smash pot
                                    angel
                                    005011 B
                                    A
                                    for sale on car
                                    005011 C
                                    B
                                    Driving car
                                    ferrari
                                    Group 1
                                    Group 1 copy
                                    salesman wave bye
                                    005011 D
                                    C
                                    005011 E
                                    Group 1
                                    Group 3
                                    Group 4
                                    Group 2
                                    hitchiker
                                    D
                                    E
                                    farmer
                                    pension pot tap
                                    005023
                                    Group 1
                                    Group 2
                                    Bicycle
                                    dude
                                    Template
                                    wheel for bicycle
                                    wheelchair
                                    wheel for wheelchair
                                    bottle champagne
                                    glass
                                    bottle
                                    props 2015 08 03
                                    small road sign
                                    medium road sign
                                    large road sign
                                    back
                                    wheel
                                    wheel copy
                                    fore
                                    station wagon
                                    lamp post
                                    flower by side of road
                                    vacuum
                                    multi option road sign
                                    fire axe
                                    bucket
                                    bbq
                                    bbq spatula
                                    02
                                    invested text
                                    005024
                                    Pre-comp 4
                                    B
                                    005017 B
                                    Group 1
                                    006001
                                    006002
                                    006003
                                    006004
                                    006005
                                    006006
                                    006007
                                    006008
                                    006009
                                    006010
                                    006011
                                    006012
                                    006013
                                    006014
                                    006015
                                    006016
                                    006017
                                    006018
                                    006019
                                    006020
                                    006021
                                    006022
                                    boss sat at desk
                                    006023
                                    Group 1
                                    Group 2
                                    boss sat at desk arms
                                    db plan
                                    test
                                  Number of collected files:  659
                                  Size of collected files:  561 MB
                                  Collected source files:
                                    E:\Working Folder\Clients\Retirement\source files\AI\Setup\Basic character source 2015 07 18.psd
                                    E:\Working Folder\Clients\Retirement\source files\audio\2015 07 22\RETIRE - Planning Ahead.wav
                                    E:\Working Folder\Clients\Retirement\source files\audio\2015 07 22\RETIRE - State Pensions and Tax.wav
                                    E:\Working Folder\Clients\Retirement\source files\audio\2015 07 22\RETIRE - When Could I Retire.wav
                                    E:\Working Folder\Clients\Retirement\source files\audio\2015 07 23\RETIRE - How Can You Use Your DC Plan etc.wav
                                    E:\Working Folder\Clients\Retirement\source files\audio\2015 07 23\RETIRE - How You Can Take Your DB Pension.wav
                                    E:\Working Folder\Clients\Retirement\source files\audio\extended corporate music.wav
                                    Sequence "flip chart then point[0001-0046].jpg" at E:\Working Folder\Clients\Retirement\source files\flash\001\010 with 46 files and 0 auxiliary files
                                    Sequence "001 skateboard[0001-0017].jpg" at E:\Working Folder\Clients\Retirement\source files\flash\002\001 with 17 files and 0 auxiliary files
                                    Sequence "001 suitcase walk[0001-0016].jpg" at E:\Working Folder\Clients\Retirement\source files\flash\002\001 with 16 files and 0 auxiliary files
                                    Sequence "001 walking frame[0001-0020].jpg" at E:\Working Folder\Clients\Retirement\source files\flash\002\001 with 20 files and 0 auxiliary files
                                    Sequence "basic character catch money[0001-0021].jpg" at E:\Working Folder\Clients\Retirement\source files\flash\003\001 with 21 files and 0 auxiliary files
                                    Sequence "tax man throw money[0001-0032].jpg" at E:\Working Folder\Clients\Retirement\source files\flash\003\001 with 32 files and 0 auxiliary files
                                    Sequence "puff[0001-0009].png" at E:\Working Folder\Clients\Retirement\source files\flash\003\002 with 9 files and 0 auxiliary files
                                    E:\Working Folder\Clients\Retirement\source files\flash\003\004\sat waiting.png
                                    Sequence "golf putting[0001-0040].jpg" at E:\Working Folder\Clients\Retirement\source files\flash\003\005 with 40 files and 0 auxiliary files
                                    Sequence "raking[0001-0012].jpg" at E:\Working Folder\Clients\Retirement\source files\flash\003\006 with 12 files and 0 auxiliary files
                                    E:\Working Folder\Clients\Retirement\source files\flash\003\008\sat in ifa office with money.jpg
                                    E:\Working Folder\Clients\Retirement\source files\flash\005\002\the deal.jpg
                                    E:\Working Folder\Clients\Retirement\source files\flash\005\002\the shop.jpg
                                    Sequence "launch[0001-0151].jpg" at E:\Working Folder\Clients\Retirement\source files\flash\005\003 with 151 files and 0 auxiliary files
                                    Sequence "B_[00000-00150].jpg" at E:\Working Folder\Clients\Retirement\source files\flash\005\003\ref for rocket\B with 151 files and 0 auxiliary files
                                    Sequence "small pot[0001-0032].jpg" at E:\Working Folder\Clients\Retirement\source files\flash\005\005 with 32 files and 0 auxiliary files
                                    Sequence "saying yes[0001-0031].jpg" at E:\Working Folder\Clients\Retirement\source files\flash\005\008 with 31 files and 0 auxiliary files
                                    Sequence "salesman wave goodbye[0001-0006].jpg" at E:\Working Folder\Clients\Retirement\source files\flash\005\011 with 6 files and 0 auxiliary files
                                    Sequence "smash pot[0001-0014].jpg" at E:\Working Folder\Clients\Retirement\source files\flash\005\011 with 14 files and 0 auxiliary files
                                    E:\Working Folder\Clients\Retirement\source files\flash\005\011\hitchiking.jpg
                                    E:\Working Folder\Clients\Retirement\source files\flash\005\011\money angel.jpg
                                    E:\Working Folder\Clients\Retirement\source files\flash\006\001\boss.jpg
                                    E:\Working Folder\Clients\Retirement\source files\photoshop\001001 A.PSD
                                    E:\Working Folder\Clients\Retirement\source files\photoshop\001003.PSD
                                    E:\Working Folder\Clients\Retirement\source files\photoshop\001007.PSD
                                    E:\Working Folder\Clients\Retirement\source files\photoshop\001009.PSD
                                    E:\Working Folder\Clients\Retirement\source files\photoshop\001011.PSD
                                    E:\Working Folder\Clients\Retirement\source files\photoshop\001012.PSD
                                    E:\Working Folder\Clients\Retirement\source files\photoshop\001013.PSD
                                    E:\Working Folder\Clients\Retirement\source files\photoshop\002002 B.PSD
                                    E:\Working Folder\Clients\Retirement\source files\photoshop\002002.PSD
                                    E:\Working Folder\Clients\Retirement\source files\photoshop\002003 A.psd
                                    E:\Working Folder\Clients\Retirement\source files\photoshop\003001 a.psd
                                    E:\Working Folder\Clients\Retirement\source files\photoshop\003004.PSD
                                    E:\Working Folder\Clients\Retirement\source files\photoshop\003005.PSD
                                    E:\Working Folder\Clients\Retirement\source files\photoshop\003006.PSD
                                    E:\Working Folder\Clients\Retirement\source files\photoshop\003007 door.psd
                                    E:\Working Folder\Clients\Retirement\source files\photoshop\003007.PSD
                                    E:\Working Folder\Clients\Retirement\source files\photoshop\003008 a.PSD
                                    E:\Working Folder\Clients\Retirement\source files\photoshop\003008 b.PSD
                                    E:\Working Folder\Clients\Retirement\source files\photoshop\004 basic back.jpg
                                    E:\Working Folder\Clients\Retirement\source files\photoshop\004 expert back.jpg
                                    E:\Working Folder\Clients\Retirement\source files\photoshop\004003 waiting.PSD
                                    E:\Working Folder\Clients\Retirement\source files\photoshop\005001.PSD
                                    E:\Working Folder\Clients\Retirement\source files\photoshop\005002.PSD
                                    E:\Working Folder\Clients\Retirement\source files\photoshop\005003.PSD
                                    E:\Working Folder\Clients\Retirement\source files\photoshop\005006.PSD
                                    E:\Working Folder\Clients\Retirement\source files\photoshop\005010.PSD
                                    E:\Working Folder\Clients\Retirement\source files\photoshop\005011 B.PSD
                                    E:\Working Folder\Clients\Retirement\source files\photoshop\005011 C.PSD
                                    E:\Working Folder\Clients\Retirement\source files\photoshop\005011 D.PSD
                                    E:\Working Folder\Clients\Retirement\source files\photoshop\005011 E.psd
                                    E:\Working Folder\Clients\Retirement\source files\photoshop\005012.PSD
                                    E:\Working Folder\Clients\Retirement\source files\photoshop\005013.PSD
                                    E:\Working Folder\Clients\Retirement\source files\photoshop\005017 B.PSD
                                    E:\Working Folder\Clients\Retirement\source files\photoshop\006001.PSD
                                    E:\Working Folder\Clients\Retirement\source files\photoshop\bus.psd
                                    E:\Working Folder\Clients\Retirement\source files\photoshop\dude.psd
                                    E:\Working Folder\Clients\Retirement\source files\photoshop\ferrari.PSD
                                    E:\Working Folder\Clients\Retirement\source files\photoshop\france\props 2015 08 03.psd
                                    E:\Working Folder\Clients\Retirement\source files\photoshop\moneyadvice page.jpg
                                    E:\Working Folder\Clients\Retirement\source files\photoshop\pensionwise page.jpg
                                    E:\Working Folder\Clients\Retirement\source files\photoshop\Table.jpg
                                    E:\Working Folder\Clients\Retirement\source files\photoshop\thoughts\A.png
                                    E:\Working Folder\Clients\Retirement\source files\photoshop\thoughts\B.png
                                    E:\Working Folder\Clients\Retirement\source files\photoshop\thoughts\C.png
                                    E:\Working Folder\Clients\Retirement\source files\photoshop\thoughts\D.png
                                    E:\Working Folder\Clients\Retirement\source files\photoshop\thoughts\E.png
                                    E:\Working Folder\Clients\Retirement\source files\photoshop\webpage-01.psd
                                  Rendering plug-ins:
                                    Classic 3D
                                  Effects used:  16
                                  Effect:  CC Page Turn
                                  Effect:  CC Rainfall
                                  Effect:  Circle
                                  Effect:  Color Balance (HLS)
                                  Effect:  Corner Pin
                                  Effect:  Drop Shadow
                                  Effect:  Exposure
                                  Effect:  Fast Blur
                                  Effect:  Grid
                                  Effect:  Levels
                                  Effect:  Mesh Warp
                                  Effect:  Numbers
                                    External dependencies:
                                    Font family: ‘BPreplay’, Font style: ‘Bold’
                                  Effect:  Puppet
                                  Effect:  Stereo Mixer
                                  Effect:  Stroke
                                  Effect:  Tint
                                  Layer:  Text Layer
                                    Font family: “BPreplay”, Font style: “Bold”
                                  • 14. Re: lag - seriously bad - how can i reduce
                                    adzatpew Level 1
                                    enjoy reading that
                                    • 15. Re: lag - seriously bad - how can i reduce
                                      StormyCPb Level 3
                                      Ugh, I can't see much in there that's obvious, but I've had much larger projects than that before so I don't think its that. Mesh Warp could be a culprit or Puppet if you have a large amount of triangles per layer, that may do it.
                                      • 16. Re: lag - seriously bad - how can i reduce
                                        StormyCPb Level 3
                                        Is it easy to shut them off and check?
                                        • 17. Re: lag - seriously bad - how can i reduce
                                          StormyCPb Level 3
                                          If you have any pre-comp work you're happy with and unlikely to change, you could render them out as a sequence, import back in and dump in the same comp, then shut off the original layers. This will speed things up as AE isn't having to constantly render the effects, which may be the source of your issues
                                          • 18. Re: lag - seriously bad - how can i reduce
                                            adzatpew Level 1
                                            i just tried to find all instances of puppet and meshwarp....from what i can tell, it is not used anywhere....i only applied it to a couple of layers in one comp which is no longer used....so i deleted that layer, saved and did a new log.....but they are still listed
                                            but those effects are not used in any of the comps that i can see...they consist of mainly shape layers...some psds
                                            • 19. Re: lag - seriously bad - how can i reduce
                                              StormyCPb Level 3
                                              how big are you comps?
                                              • 20. Re: lag - seriously bad - how can i reduce
                                                adzatpew Level 1
                                                just did an old 3ds max trick....imported the entire afx project into a new project and there was a huge improvement in performance.....but it is still not as good and a completely clean project
                                                • 21. Re: lag - seriously bad - how can i reduce
                                                  StormyCPb Level 3
                                                  Although this is a hindsight point to make, in future, as soon as you notice a drop in performance, go back through your history and try and correlate what could have caused it. This has happened to me in the past and if you don't nip it asap it can be (and is for you now!) a nightmare...
                                                  • 22. Re: lag - seriously bad - how can i reduce
                                                    StormyCPb Level 3
                                                    if it works, it works!
                                                    • 23. Re: lag - seriously bad - how can i reduce
                                                      adzatpew Level 1
                                                      it doesnt work entirely
                                                      however...i just did a quick test.....
                                                      empty project has great performance
                                                      empty project with imported massive project, slightly less performance
                                                      exact same project with 22 comp tabs and terrible performance
                                                      so it would seem that afx is struggling in general with a big project...that sucks
                                                      • 24. Re: lag - seriously bad - how can i reduce
                                                        adzatpew Level 1
                                                        as for your hindsight comment....this has not been a sudden drop in performance....it has been gradual over the past 2 weeks
                                                        • 25. Re: lag - seriously bad - how can i reduce
                                                          adzatpew Level 1
                                                          i will just soldier on....thanks for your help
                                                          • 26. Re: lag - seriously bad - how can i reduce
                                                            StormyCPb Level 3
                                                            I'm afraid your project isn't that big, the one I'm on at the moment is running smoothly and has:
                                                            No of Comps: 563
                                                            Number of collected files:  15953
                                                            Size of collected files:  8.0 GB
                                                            Effects used:  64
                                                            No of Fonts: 32
                                                            • 27. Re: lag - seriously bad - how can i reduce
                                                              adzatpew Level 1
                                                              i hate mysterious problems like these
                                                              • 28. Re: lag - seriously bad - how can i reduce
        picenilllo Level 1
        There are some issues with CC 2015 (After Effects version 13.5.1).
        I am having the same issues an others since the latest update, another annoying bug I am experiencing is when I Ctrl + z. it doesn't undo my ram preview unless I modify something else.
        Let's hope the AE peeps get these issues solved soon. my workflow is getting affected by this I must admit.
