Flex Builder 2 errors on Eclipse 3.2
BKBK Dec 9, 2006 12:12 AMWhenever you start Eclipse 3.2, five errors and two warnings
occur, apparently caused by Flex Builder 2. To see them, follow the
Eclipse menu
Window =>
Show View =>
Other =>
PDE Runtime =>
Error Log. Here is a summary of the logs.
You get the following errors whenever you start Eclipse 3.2:
eclipse.buildId=M20060921-0945
java.version=1.5.0_09
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
Command-line arguments: -os win32 -ws win32 -arch x86
plugin: org.eclipse.core.filebuffers
Error
Sat Dec 09 08:39:04 CET 2006
The content type with id "com.adobe.flexbuilder.project.content-type.actionscript" specified in the extension point does not exist.
Error
The content type with id "com.adobe.flexbuilder.project.content-type.css" specified in the extension point does not exist.
Error
The content type with id "com.adobe.flexbuilder.project.content-type.mxml" specified in the extension point does not exist.
plugin: org.eclipse.ui
Error
Internal plug-in action delegate error on creation.
java.lang.NullPointerException
at org.cfeclipse.cfml.editors.actions.EditTagAction.setActiveEditor(EditTagAction.java:112)
at org.eclipse.ui.internal.EditorPluginAction.initDelegate(EditorPluginAction.java:56)
at org.eclipse.ui.internal.PluginAction.createDelegate(PluginAction.java:123)
at org.eclipse.ui.internal.PluginAction.selectionChanged(PluginAction.java:278)
at org.eclipse.ui.internal.PluginAction.<init>(PluginAction.java:110)
at org.eclipse.ui.internal.PartPluginAction.<init>(PartPluginAction.java:29)
at org.eclipse.ui.internal.EditorPluginAction.<init>(EditorPluginAction.java:32)
at org.eclipse.ui.internal.ActionDescriptor.createAction(ActionDescriptor.java:256)
at org.eclipse.ui.internal.ActionDescriptor.<init>(ActionDescriptor.java:170)
at org.eclipse.ui.internal.ActionDescriptor.<init>(ActionDescriptor.java:100)
at org.eclipse.ui.internal.EditorActionBuilder.createActionDescriptor(EditorActionBuilder.ja va:41)
at org.eclipse.ui.internal.PluginActionBuilder.readElement(PluginActionBuilder.java:158)
at org.eclipse.ui.internal.registry.RegistryReader.readElements(RegistryReader.java:138)
at org.eclipse.ui.internal.registry.RegistryReader.readElementChildren(RegistryReader.java:1 27)
at org.eclipse.ui.internal.PluginActionBuilder.readElement(PluginActionBuilder.java:141)
at org.eclipse.ui.internal.registry.RegistryReader.readExtension(RegistryReader.java:149)
at org.eclipse.ui.internal.registry.RegistryReader.readRegistry(RegistryReader.java:170)
at org.eclipse.ui.internal.PluginActionBuilder.readContributions(PluginActionBuilder.java:11 2)
at org.eclipse.ui.internal.EditorActionBuilder.readActionExtensions(EditorActionBuilder.java :58)
at org.eclipse.ui.internal.EditorManager.createEditorActionBars(EditorManager.java:318)
at org.eclipse.ui.internal.EditorManager.createSite(EditorManager.java:832)
at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:583)
at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:372)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:566)
at org.eclipse.ui.internal.EditorAreaHelper.setVisibleEditor(EditorAreaHelper.java:263)
at org.eclipse.ui.internal.EditorManager.setVisibleEditor(EditorManager.java:1446)
at org.eclipse.ui.internal.EditorManager$5.run(EditorManager.java:1006)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:843)
at org.eclipse.ui.internal.EditorManager.restoreState(EditorManager.java:1001)
at org.eclipse.ui.internal.WorkbenchPage.restoreState(WorkbenchPage.java:2843)
at org.eclipse.ui.internal.WorkbenchWindow.restoreState(WorkbenchWindow.java:1936)
at org.eclipse.ui.internal.Workbench.doRestoreState(Workbench.java:2857)
at org.eclipse.ui.internal.Workbench.access$14(Workbench.java:2805)
at org.eclipse.ui.internal.Workbench$19.run(Workbench.java:1681)
at org.eclipse.ui.internal.Workbench.runStartupWithProgress(Workbench.java:1421)
at org.eclipse.ui.internal.Workbench.restoreState(Workbench.java:1679)
at org.eclipse.ui.internal.Workbench.access$12(Workbench.java:1650)
at org.eclipse.ui.internal.Workbench$17.run(Workbench.java:1529)
at org.eclipse.ui.internal.Workbench.restoreState(Workbench.java:1473)
at org.eclipse.ui.internal.WorkbenchConfigurer.restoreState(WorkbenchConfigurer.java:183)
at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(WorkbenchAdvisor.java:702)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:1085)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1847)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:419)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplication.java:95)
at org.eclipse.core.internal.runtime.PlatformActivator$1.run(PlatformActivator.java:78)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLau ncher.java:92)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.jav a:68)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:400)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:177)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336)
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Error
Could not create action delegate for id: org.cfeclipse.cfml.editors.actions.EditTagAction
Warning
Sat Dec 09 08:39:00 CET 2006
Warnings while parsing the editor contributions from the 'org.eclipse.ui.editorActions' extension point
Warning
Actions require a non-empty label or definitionId: plug-in='com.adobe.flexbuilder.debug.ui', id='AUTOGEN:::com.adobe.flexbuilder.debug.ui.mxmlRulerActions/com.adobe.flexbuilder.debug .ui.mxmlDoubleClickBreakpointAction'
Warning
Actions require a non-empty label or definitionId: plug-in='com.adobe.flexbuilder.debug.ui', id='AUTOGEN:::com.adobe.flexbuilder.debug.ui.actionScriptRulerActions/com.adobe.flexbuild er.debug.ui.actionScriptDoubleClickBreakpointAction'
Warning
Sat Dec 09 08:38:59 CET 2006
Warnings while parsing the key bindings from the 'org.eclipse.ui.commands' extension point
Warning
Cannot bind to an undefined command: plug-in='org.cfeclipse.cfml', id='org.cfeclipse.cfml.editors.actions.EditTagAction'
Error
Error
Error
Error
Error
Warning
Warning
Warning
Warning
Warning
