4 Replies Latest reply on Aug 14, 2015 8:39 PM by BSKTCreation
    myTextFrame.fit(FitOptions.frameToContent); only works in Debug mode
    Ivel97 Level 1
      This is my code:
              for (i = startDate; i <= endDate; i++) {
                  //Create label
                  var myTextFrame = myPage.textFrames.add();
                  myTextFrame.contents = i.toString() + " " + monthName;
                    //Add it to the array
                    myDates.push(myTextFrame);
                    //Apply style
                    var myTextObject = myTextFrame.parentStory;
                    myTextObject.paragraphs[0].appliedParagraphStyle = myDocument.paragraphStyles.itemByName("Date numbers (Greg)");
                    //Place it in position
                    MoveTextFrameToSquareNum(myTextFrame, parseInt(startSquare) + parseInt(i) - parseInt(startDate), 89,3);
                    //Fit text frame to content
      As you can see I loop through some numbers making TextFrames from each one, towards the end I fit the TextFrame to the content.
      Now this all works perfectly in ExtendScript, but as soon as I add as a script to InDesign and run it as a script it starts messing up. Only some get sized properly, the rest not at all. When I tried this code to loop through the textboxes after they have been placed and resize them, it didnt work at all!
      Second try:
                  //Create label
                  //Apply style
              var i;
              for(i=0;i<myDates.length;i++){
                  myDates[i].fit(FitOptions.FRAME_TO_CONTENT);
      Is there anyone who understands what the problem is and knows how to fix it?
      Thanks, alot.
