4 Replies Latest reply on Dec 8, 2006 7:43 PM by Generave
    Farmatting a number as currency
    Level 7
      I am calculating a sale amount for an order form. I want to place that
      amount in a text box as follows: $x,xxx but Can't figure out how this is
      done. Can anyone help? Thanks in advance.
        • 1. Re: Farmatting a number as currency
          TimSymons Level 1
          You can try this function I wrote. I tested it for $xxx,xxx,xxx,xxx.xx and $x.xx
          Tim
          • 2. Re: Farmatting a number as currency
            Generave Level 1
            Here is another way to write it as well. Just the first thing that came to my mind. There are probably ways to improve on this.
            Good Luck!
            • 3. Re: Farmatting a number as currency
              Level 7
              Generave:
              This function worked well. The function written by TimSimons would always
              add an additional 50 cents.
              Thank you for your time.
              "Generave" <webforumsuser@macromedia.com> wrote in message
              news:elcjag$77m$1@forums.macromedia.com...
              > to my
              > Good Luck!
              > function ToCurrency(d:Number) : String {
              > d = Math.ceil(d*100)/100;//round up to the nearest penny
              > //d is the raw number inputted without formatting, for example 12345.67
              > var s:String = d.toString(10);//start by converting the number to a
              > string
              > //make sure cents are in the string and if not add them
              > if(s.indexOf(".") == -1){//if no period
              > s += ".00";//append zero cents
              > } else if (s.indexOf(".") == s.length - 2){//if last zero missing for
              > cents
              > s += "0";
              > //rewrite the number with commas
              > for(var i:Number = 1; -3*i-2-i > -s.length; i++){
              > trace(d/(1000^i));
              > s = s.substr(0,-3*i-2-i) + "," + s.substr(-3*i-2-i);
              > return "$" + s;
              > trace(ToCurrency(123456.677));//just a test
              • 4. Re: Farmatting a number as currency
                Generave Level 1
                You're welcome. Please ignore this line:
                trace(d/(1000^i));
                I accidentally left that one in there, but it serves no purpose ;)
                Have a good weekend!
