5 Replies Latest reply on Dec 10, 2006 7:57 AM by kglad
    loadmovienum and gotoandplay help
    MrLeche Level 1
      hi, my question is basically simple, it's just a GotoAndPlay from a LoadMovieNum... how can I trigger the button to control the main movie?
      here's the scenario:
      I have a movie called BgAndMenu.swf who has labels on frames 1, 50, and 100 named start, mid, and end respectively. Then it basically stops to frame 25 with a stop() actionscript then triggers another movie named content1.swf, the actionscript is LoadMovieNum content1.swf level 10. everything loads fine.
      then on the content1.swf, there is a button that should trigger the movie to unload and basically should move the BgAndMenu.swf to the frame labeled mid. I can;t get it to happen this is the one I tried on content1.swf's button:
      ist line on release (mouse event)
      2nd line GotoAndPlay > frame label > mid
      3rd line unloadmovienum > level > 10
      when i hit the button, it unloads the content1.swf movie but doesn't move the main movie to frame "mid" I got the idea the button only tried to locate the frame mid on the content1.swf itself and not the BgAndMenu.swf
      How do I make it possible? thanks!
        • 1. Re: loadmovienum and gotoandplay help
          2nd line should target _level0 and should use gotoAndPlay (case counts):
          • 2. Re: loadmovienum and gotoandplay help
            MrLeche Level 1
            Hi, Thank you. Although I can copy paste your code into the actionscript field, Can you tell me how to do it with the "script assist" enabled? if it's not too much to ask. thanks!
            • 3. Re: loadmovienum and gotoandplay help
              whoa, that's a major pain if you're going to use script assist. i had no idea how hard it is to use that until you asked your question and i opened flash to try it:
              actionscript 2.0 classes/Movie/MovieClip/Methods/gotoAndPlay
              object is _level0.
              but i'd strongly recommend not using script assist. flash automatically colors it methods and keywords as you type them so you can catch typos/case mismatches etc by looking at the keywords as you type. if they're not colored, you mistyped. now check in the flash help file.
              • 4. Re: loadmovienum and gotoandplay help
                MrLeche Level 1
                hi sir, yeah I get that a lot. But I started learning flash since 4 and never really had a formal study of actionscripting. I also didn't bother to look for changes but I have purchased 5.0, MX, MX2000( i think) and 8.
                I'm still the old simple ac scripter which uses the same old gotoandplay, telltarget ifframeloaded loadmovienum and unloadmovie :)
                For me it seems that kind of actionscripting which has dots and underscores are like programming to me. I started as a designer basically circles thru photoshop, flash and dreamweaver, lately I'm into PHP and MySQL but never had any programming languages before so I find really amazing when people just tell these codes by underscores and dots all in one line and voila, what I wnated to achieve is done in a zap.
                • 5. Re: loadmovienum and gotoandplay help
                  oh i understand using "easy mode" from flash 5 days when flash had helpful code suggestions. but once mm released flash mx (and easy mode disappeared) it became more difficult to avoid learning actionscript.
