7 Replies Latest reply on Aug 14, 2015 9:39 AM by Peter Spier
    Help? Choosing the Best Global Mapper Vector Export for InDesign CS6
    kellybellis Level 1
      The GIS application Global Mapper offers an extensive array of vector export options; however, the list of InDesign Importable file types has me asking this question: What is the best choice of vector export from Global Mapper destined for an InDesign document without additional intermediary steps; e.g., involving ai?
      Initially after reading on this subject, it sounded as if EPS might have been best, but alas, EPS is not on GM's export list (yet). Windows EMF (Enhanced Meta File) is; however, I'm presently not seeing it listed during export from Global Mapper v16.2 b072415.
      Thank you very much for any suggestions.
      Kelly
        • 1. Re: Help? Choosing the Best Global Mapper Vector Export for InDesign CS6
          BobLevine MVP & Adobe Community Professional
          We know what InDesign can and can't do. What can Global Mapper export?
          • 2. Re: Help? Choosing the Best Global Mapper Vector Export for InDesign CS6
            kellybellis Level 1
            Global Mapper TM
            Vector Formats
            3D PDF Files
            3DS Max Format
            7Z Archives
            ASPRS LIDAR LAS Files
            ATLAS BNA (Boundary File)
            AVS UCD Format
            Alberta Township System (ATS) Format
            AnuDEM Contour Text Files
            Anuga Triangulated Mesh Format
            Arc/Info Export Format (E00)
            ArcGIS Layer Pack Files
            AutoCAD DWG (DraWinG) File
            AutoCAD DXF (Drawing Interchange File)
            Blender .blend
            CDF (GES Cartographic Data Format)
            CML, CXF, and TAF (Italian Cadastral Exchange Formats)
            COLLADA 3D Models (DAE)
            Cogent3D .line, .point, and .poly Files
            CompeGPS RTE, TRK, and WPT Formats
            DBF (DBase III+) Files
            DECC UK Wind Speed Data
            DMDF (Digital Map Data Format) Format
            DeLorme Text Files
            Delft3D (LDB) Files
            E57 Lidar Point Cloud Format
            EMF (Windows Enhanced Metafile) Format
            ESRI File Geodatabase Format
            ESRI Personal Geodatabase Format (MDB) Files
            ESRI Shapefiles
            EasyGPS .LOC File
            Esri zLas Lidar
            FCC Antenna Structure Registration (ASR) Files
            GML (Geography Markup Language) Format
            GPS TrackMaker
            GPX (GPS eXchange Format) Files
            Garmin PCX5 Format Waypoint (WPT), Route (RTE), and Track (TRK) Files
            Garmin TCX (Training Center Database) Files
            GeoJSON Format
            GeoPDF® Files
            HTF (Hydrographic Transfer Format)
            Hypack LNW (Planned Line) Files
            Hypack RAW GPS Log Files
            Idrisi Vector (VCT) Format
            JPEG Image with Embedded EXIF Position Information
            KML/KMZ Formats
            Kongsberg SIS Plan Format
            LIDAR LAZ (Compressed LAS) Files
            LMN (Spectra Line Management Node) Files
            LandXML
            Landmark Graphics Vector Files
            Leica PTS Lidar Point Cloud Format
            LizardTech MrSID MG4 Lidar
            LogASCII (LAS) Files
            Lowrance LCM (MapCreate) Format
            Lowrance SonarViewer/SonarLog (SLG) Format
            Lowrance USR
            MagicMaps IKT Files
            MapInfo MIF/MID and TAB/MAP Formats
            MapMaker DRA (Drawing) Files
            Marplot MIE Files
            MicroStation DGN Format
            NIMA GNS (GeoNet Names Server) Format
            NMF (ArcGIS Explorer Map) Format
            NMGF (Noise Model Grid Format)
            NOAA DSDATA Geodetic Control, SDTS Format
            NTF Grid/Contour Format
            OBJ (Wavefront)
            OCAD .OCD Files
            OTF (Objective Terrain Format)
            OpenAir Airspace Format
            OpenStreetMap (OSM) Files
            Orca XML
            OziExplorer Waypoint (WPT), Route (RTE), and Track (PLT) Files
            PLS-CADD XYZ Files
            PLY (Standford Polygon Library)
            Platte River ASCII Digitizer Format
            Polish MP (cGPSMapper) Format
            S-57 Digital Chart Files
            S-63 Encrypted Digital Chart Files
            SEGP1/UKOOA Seismic Shotpoint Format
            SEGY Seismic Shotpoint Format
            SMT KINGDOM Software Planimetric Polygon Format
            SOSI Files
            SPS (Shell Processing Support)
            STL (StereoLithography) Files
            Sketchup .skp
            Surfer BLN Files
            TAF (Italian Cadastral Exchange Format)
            TIGER/Line Files
            Tobin .bas (TDRBM II) Format
            TomTom OV2 Files
            Trimble Field Level Survey and Applied XML
            USGS Digital Line Graph, Optional Format (DLG-O)
            USGS Digital Line Graph, Spatial Data Transfer Standard Format (DLG/SDTS)
            USGS Geographic Names Information System (GNIS)
            USGS Land Use and Land Cover Data (LULC)
            VPF (VMAP0, VMAP1, DNC) Files
            Vulcan3D Triangulation (.00t) Files
            WAsP .MAP Format
            XTF (eXtended Triton) Format
            ZFS (Z+F) Lidar
            ZMap+ Fault Polygon Text Files
            ZMap+ IsoMap Line and XYSegID Text Files
            • 3. Re: Help? Choosing the Best Global Mapper Vector Export for InDesign CS6
              The only choices on that list the ID can read are Windows emf and jpeg, and I wouldn't use either one. Best is probably to bite the bullet, save as .dwg, and convert in Illustrator.
              • 4. Re: Help? Choosing the Best Global Mapper Vector Export for InDesign CS6
                kellybellis Level 1
                I'm presently not seeing EMF listed during export from Global Mapper v16.2 b072415 (the application itself) though it is listed on Blue Marble's reference page (linked above).
                Adding Illustrator into the workflow was hoped to have been avoided; largely in part, because I wondered if GM's existing long list might already include an ideal vector format that InDesign recognized but by another name. Another reason of avoiding Illustrator was to simply not add additional steps in the production of this book of maps being contemplated.
                • 6. Re: Help? Choosing the Best Global Mapper Vector Export for InDesign CS6
                  kellybellis Level 1
                  Yes, and so far in preliminary tests, with nice results that are editable in Illustrator. Next to see how multiple scripted exports can be composited; i.e., registered layers, in InDesign.
                  • 7. Re: Help? Choosing the Best Global Mapper Vector Export for InDesign CS6
                    I didn't see PDF in the list, so I didn't mention it, but that would be the first choice for direct placement in ID. Illustrator is not a general purpose PDF editor, though, so opening the files there could be a problem.
