9 返信 最新の回答 日時: Aug 19, 2015 2:48 PM ユーザー:A.T. Romano
    Premiere Elements 13 でVBR 2pass書き出しできない。
    wibers5871
      ファイルの書き出しを行う際に1passでしか指定できない。
      以前から、2passで書き出しで来ている情報を得ていたため、
      2pass書き出しができると思って購入しましたが、できないとなると困りもの…
      個人的にpass数はユーザー側で指定できる方がありがたいのですが…
      実装は不可能なのでしょうか。
        • 1. Re: Premiere Elements 13 でVBR 2pass書き出しできない。
          A.T. Romano Level 7
          wibers
          Premiere Elements 13/13.1 which was released in September 2014 has always used Bitrate Encoding VBR-1 Pass.
          It is highly unlikely at this late date that Adobe will do a special update 13.2 to include a Bitrate Encoding VBR-2 Pass choice as well.
          If history repeats itself, Adobe should be releasing a new version of the program in September October 2015. Only Adobe knows the new features and what will remain and what will be removed.
          Please refer to the Adobe Feature Request Bug Report Form.
          Feature Request/Bug Report Form
          The Adobe Premiere Elements Forum in which you have posted is essentially a user to user forum. The frequency of the Adobe presence in this forum is undefined.
          ATR
          • 2. Re: Premiere Elements 13 でVBR 2pass書き出しできない。
            A.T. Romano Level 7
            wibers
            When I answered your thread question, it was in the Adobe Premiere Elements Forum.
            This morning I now find your thread moved to the Adobe International Forum. I did not move it there.
            Since you posted a Premiere Elements question in the Adobe Premiere Elements Forum, there should be no problem in that.
            Others with your language have in the past, gaining successful results.
            If you find it easier to post in the Adobe International Forum for communication purposes, that is your decision.
            But, I just wanted to let you know that I am available to answer your Premiere Elements questions in the Adobe Premiere Elements Forum Premiere Elements
            with the assist of the translate button and/or Google Translate.
            Best wishes
            ATR
            • 3. Re: Premiere Elements 13 でVBR 2pass書き出しできない。
              150kw Most Valuable Participant
              お早うございます、wibers5871さん
              Premiere Elements 12ですと、ディスクではなくファイルへ書き出しなら「VBR、2パス」を設定できます。Premiere Elements 13でも同じように出来ると思いますが、お試しください。
              ①「書き出し・配信」(ウインドウ右上)をクリックします。
              ②「コンピューター」を選択します。
              ③開いた「コンピューター:場所と設定を選択」ウインドウで「MPEG」を選択し、「詳細設定」ボタンをクリックします。
              ④「書き出し設定」ウインドウが開きます。ここの「ビットレート設定」の項で「VBR、2パス」が設定できます。
              • 4. Re: Premiere Elements 13 でVBR 2pass書き出しできない。
                A.T. Romano Level 7
                150kw
                You seem to be telling wibers that there is VBR-2 Pass Bitrate Encoding in Premiere Elements 13/13.1. Do you have some special version of 13/13.1 that offers VBR-2 Pass Bitrate Encoding in Premiere Elements 13/13.1? Unless you do, there is no VBR-2 Pass Bitrate Encoding in Premiere Elements 13/13.1.
                Premiere Elements 13/13.1 does not offer VBR-2 Pass under the Publish+Share/Computer/MPEG and its presets Advanced Button/Video Tab or anywhere else there in Publish+Share/Computer/...... Please refer to my post numbered 1 as well as the screenshot below.
                Have you ever used Premiere Elements 13/13.1or are you basing your answer on Premiere Elements 12/12.1 which is not the same as 13/13.1?
                ATR
                • 5. Re: Premiere Elements 13 でVBR 2pass書き出しできない。
                  wibers5871さん
                  A.T. Romanoさんが添付下さった図から見ると、Premiere Elements 13では「VBR、2パス」の選択肢はなさそうですね。12は選択できましたが。
                  A.T. Romanoさん
                  早々にご連絡ありがとうございます。
                  私は英語は分かりません。添付図から、13には「VBR、2パス」がないことが分かりました。
                  • 6. Re: Premiere Elements 13 でVBR 2pass書き出しできない。
                    A.T. Romano Level 7
                    150kw
                    English to Japanese using Google Translate
                    回答していただきありがとうございます。私はGoogleが日本語で返信する翻訳使用しています。
                    確認するために...プレミアエレメント13/13.1パブリッシュ+共有/コンピュータ/ MPEGまたはその他にはビットレートエンコーディングVBR-2パスはありません。
                    プレミア要素の新しいバージョンがすぐに期待されています。誰が、アドビシステムズ社は、新機能を知っているか、どのような特徴が保持され、どのように多くを除去しました。
                    私は、英語から日本語へGoogle翻訳が読み取り可能であることを願っています。
                    ご多幸を祈る
                    ATR
                    English version of message
                    Thank you for the reply. I am using Google Translate to reply in Japanese.
                    To confirm...there is no Bitrate Encoding VBR-2 Pass in Premiere Elements 13/13.1 Publish+Share/Computer/MPEG or other.
                    A new version of Premiere Elements is expected soon. No one but Adobe knows the new features or what features will be retained and how many removed.
                    I hope that the Google Translation from English to Japanese is readable.
                    Best wishes
                    ATR
                    • 7. Re: Premiere Elements 13 でVBR 2pass書き出しできない。
                      A.T. Romano Level 7
                      150kw and wibers5871
                      私はプレミアエレメント13/13.1のWindowsにはVBR-2パスビットレートエンコーディングが存在しないことを書いたところ、私のポストへの調整は4と6の番号が付けられようにする必要があります。私が見つけた1つの例外があります。見ます
                      +共有/コンピュータ/ Windowsのメディアプリセットの選択肢を公開します。スクリーンショットは一例であり、
                      それだけで私はVBR-2パスビットレートエンコーディングのためのオプションを見つけるプレミアエレメント13/13.1のWindows Media選択肢です
                      ATR
                      • 8. Re: Premiere Elements 13 でVBR 2pass書き出しできない。
                        お早うございます
                        A.T. Romanoさんの先の書き込みで、VBR 2パスはPremiere Elements 13にはないことが分かりました。
                        今回は、図を添付までされて説明をして頂きましたが、申し訳ありませんが、日本語翻訳機能がいまいちなんでしょうか、私には内容を理解することができませんでした。
                        ありがとうございました。
                        • 9. Re: Premiere Elements 13 でVBR 2pass書き出しできない。
                          A.T. Romano Level 7
                          150kw
                          I write now in English because translator is not good between English and Japanese. I am hoping that someone who reads and writes both English and Japanese can provide an accurate translation to tell you to look for VBR-2 Pass in Premiere Elements 13/13.1 only in Publish+Share/Computer/Windows Media. Refer to screenshot in post 7.
                          Thank you.
                          ATR
