7 Replies Latest reply on Dec 31, 2008 5:39 AM by TC2112
    Drop down menu disappears
    itsa37ford
      Is there a method or a work around to alter Internet Explorer
      to function the same way as other W3C Compliant browsers
      to correct this problem ?
      I'm setting up a web site with Dreamweaver CS3, using Spry f
      or a drop down menu with parent and child to multiple levels.
      Dreamweaver automatically imported all necessary CSS, javascript and etc.
      The menu is properly located at the left side of the screen and page for all
      tested browsers - MS IE, Firefox, Opera and Safari. However, when the
      mouse scrolls over the menu items that have multiple menu
      drop down lists, IE places the sub items list in the middle
      of the screen, away from the parent menu. The other browsers
      that I test with operate as intended with drop down lists on the
      left side beside the parent menu.
      The HTML code passes the W3C.
      Both CSS files (my custom one and the Spry imported one) pass the W3C.
      How can I compensate for IEs weakness ?
      Is there some work around code that will allow IE to operate as the other browsers do for this web site ?
        • 1. Re: Drop down menu disappears
          Level 7
          Look for any align attributes and remove them. Also make sure that any
          text-align declarations in your style sheet are on <a> selectors and never
          on the root menu element or the menu UL elements.
          Al Sparber - PVII
          http://www.projectseven.com
          The Finest Dreamweaver Menus | Galleries | Widgets
          http://www.projectseven.com/go/pop
          The Ultimate DW Menu System
          "itsa37ford" <webforumsuser@macromedia.com> wrote in message
          news:gjemke$3c1$1@forums.macromedia.com...
          > all
          • 2. Re: Drop down menu disappears
            itsa37ford Level 1
            OK! got rid of all the aligns and text-aligns. The page looks like crap. All still works fine with all my testing browsers except IE. The child drop menus are still popping up at center page/screen.
            Hmmm?
            • 3. Re: Drop down menu disappears
              Level 7
              It's impossible to give a definitive answer without seeing your page. Hmm?
              I would never use spry code, so if you cannot post a live example, well, it
              could be anything - so you might as well move over the spry forum rather
              than the Dreamweaver forum..
              Al Sparber - PVII
              news:gjf5rt$knu$1@forums.macromedia.com...
              > All
              > menus
              > Hmmm?
              • 4. Re: Drop down menu disappears
                .V1 Level 5
                If you want a less quircky browser in IE you might want to look at this project; http://code.google.com/p/ie7-js/ and use a CSS reset stylesheet.
                And like Al Sparber said, with out seeing any code there is nearly no way for us to see what the issue is.
                • 5. Re: Drop down menu disappears
                  Level 7
                  What Al didn't say is that his menus are *WAY* better than the Spry ones,
                  and they work right out of the box.
                  Murray --- ICQ 71997575
                  Adobe Community Expert
                  (If you *MUST* email me, don't LAUGH when you do so!)
                  http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
                  http://www.dwfaq.com - DW FAQs, Tutorials & Resources
                  "V1 Fusion" <info@3rd-eden.com> wrote in message
                  news:gjf9o2$p8o$1@forums.macromedia.com...
                  > for
                  • 6. Re: Drop down menu disappears
                    .V1 Level 5
                    > for
                    Thats a matter of opinion and I respected that. Spry Menu's also work out of the box and are also highly customizable and ITS FREE.
                    • 7. Re: Drop down menu disappears
                      TC2112 Level 1
                      Hello,
                      Without seeing your code, this is a wild guess of course but...
                      If you highlighted text in the Spry menu, then used the text-align icon in the Properties window to align the text center, DW insterted divs into the menu which breaks it in IE.
                      If this is the case, go into code view and remove all the div and closing div tags.
                      If you wanted to align text center, add text-align:center; to the link CSS in the Spry CSS stylesheet.
                      Take care,
                      Tim
