13 Replies Latest reply on Apr 15, 2018 3:46 PM by selondon
    Lightroom mobile & camera profile
    littlegem4921
      I change my camera profile on import so photos are set to 'camera natural'. I then sync my photos with lightroom mobile so I can work on them from my iPad.
      When the images are synced back from Lightroom mobile to my desktop computer, the profile has changed back to Adobe Standard!  Is there a way of stopping this happening, please?  I can't figure out why it's doing it but I want the profile to remain as I have set it at import.
      Thanks for any help.
        • 1. Re: Lightroom mobile & camera profile
          littlegem4921 Level 1
          I've experimented and it seems to retain the camera profile only if it's changed after import, not on import.  Is this a bug?  Being able to change develop settings on import is very useful, but not if the changes are overridden by lightroom mobile.
          • 2. Re: Lightroom mobile & camera profile
            Dustin Kerstein Level 1
            I can replicate this issue when changing the profile after import.
            This renders LR Mobile edits useless for my workflow, and potentially damages photos without any clear indication or way to find which photos may have been reverted back to the Adobe Standard profile.
            This is a bug to me, but I imagine it may be more of a design limitation. If LR Mobile only supports Adobe Standard, then it needs to prevent edits to photos that aren't using it.
            -Dustin
            • 3. Re: Lightroom mobile & camera profile
              Bump. Can other folks replicate this?
              • 4. Re: Lightroom mobile & camera profile
                trshaner Adobe Community Professional & MVP
                What profile are you changing to on import? Does the selected camera profile also appear in LR Mobile. LR images will revert to Adobe Standard if the camera profile used on the last edit is not available (i.e. deleted or missing). Is it a camera profile you manually installed in the User folder?
                • 5. Re: Lightroom mobile & camera profile
                  Rikk-Flohr Level 4
                  This has been reported to Adobe.
                  It is not a bug per se but rather a design limitation. A request has been submitted to Adobe to allow the upload and use of custom profiles by Lightroom mobile.
                  • 6. Re: Lightroom mobile & camera profile
                    Interesting. I'm not sure it's as simple as Lightroom Mobile not being aware of the custom profile as I have done a little bit more testing with a custom (non Adobe supplied) camera profile and I am seeing some strange results. I've gone back and forth with edits and profile switches on Desktop and basic edits / reset to import on LR Mobile, and sometimes LR Mobile reverts the photo to a previously selected custom profile (but not the camera model default profile). Sometimes it reverts to Adobe Standard. And other times it leaves the correct custom profile selected. Strange...
                    I'll try to isolate the behavior a little bit but it's seemingly been a bit fluky. I feel there may be some interaction with setting the default Develop settings for the camera model (holding Alt and saying "set as default").
                    Do you happen to have a link to the Adobe bug report?
                    Dustin
                    • 7. Re: Lightroom mobile & camera profile
                      BGhibby Level 1
                      I think the issue is due to the alpha-numeric sorting of camera profiles. Adobe Standard appears first due to the folder structure within the LR program directory.  If you create a profile you wish to use with LR mobile simply export it from DNG profile editor with the name set to "01 Profile xxx".  This forces it to take the number one spot in the drop down list on the calibration tab.  When LR creates the smart previews it simply embeds the first profile in the list, this is then the profile used by LR mobile.  Works for me and now all mobile edits at least take my preferred base profile rather than jumping back to Adobe Standard which is way off the mark for colour accuracy.
                      Hope this helps.
                      Ben
                      • 8. Re: Lightroom mobile & camera profile
                        johnshore Level 1
                        Apparently, LR Mobile (including Lightroom web) does not know about custom camera profiles that are applied to Canon CR2 raw files.   The mobile versions are always rendered in Adobe Standard.   This of course makes mobile editing tof CR2 files useless wrt color.
                        On the other hand, when you convert such a CR2 file to DNG and sync that version, the mobile versions are rendered correctly with the custom camera profile.
                        Such different behavior for CR2 and DNG surely is a bug.
                        js
                        • 9. Re: Lightroom mobile & camera profile
                          sethc1777767 Level 1
                          Unfortunately your work around is very limited... because ALL of your camera calibration profiles are stored on your computer, you can't be renaming the profiles each time with a '01' at the beginning... yes, it will work once, but as soon as you create another profile. this will move to the top of the 'list' and any other images edited will default to the new (rather than the originally intended) profile.  Adobe need to find a way to sync the camera profiles within the Lightroom desktop software with the LR mobile app.  Back in June I had an email conversation with an adobe support person and they claimed to be unaware of the problem, but they could replicate it themselves.  They even gave me some compensation as I pointed out that LR mobile is unusable with this limitation.  Really hope they sort it out soon.
                          • 10. Re: Lightroom mobile & camera profile
                            deano73955163 Level 1
                            Is there any news when custom camera profiles will work with Lightroom Mobile
                            It appears to me that profiles included with Lightroom for my cameras (adobe standard, camera standard, camera natural etc) work fine but when I use a custom camera profile (which I usually use exclusively) and it syncs back to lightroom as has been previously pointed out lightroom desktop has reverted to the first camera profile in the list (in my case ACR4.6)
                            My current work around is to import and do everything in camera natural for now but this is not ideal at all I want and need to use my own custom made camera profiles
                            Best Regards
                            Dean
                            • 11. Re: Lightroom mobile & camera profile
                              MMC4251 Level 1
                              I'm just now experiencing this issue with a custom camera profile and Lightroom Mobile, and it's so disappointing and frustrating. It really does make LR mobile useless for me. Has anyone heard if this will be fixed by Adobe in the near future?
                              • 12. Re: Lightroom mobile & camera profile
                                Pixel-Sallo Level 1
                                With the latest update I can't use Lightroom on my tablet anymore.
                                I use a custom profile in Lightroom CC classic. In the app I get an failure that I can't edit the image. Is it possible to import the profiles in the mobile app?
                                • 13. Re: Lightroom mobile & camera profile
                                  selondon Adobe Community Professional
                                  Unfortunately there isn't currently. I read on another forum that if you apply another one of the supplied profiles instead, you can edit. Though of course, this may not help you.
