4 Replies Latest reply on Dec 18, 2006 4:17 PM by romeogq
    CF / phpBB intergration
    romeogq Level 1
      First, I would like to know if anyone has been successful in intergrating their member-based cf site with phpBB? If so could you explain how you did so.
      If no one has:
      My member-based site uses sessions to log member sign-ins and sign-outs instead of cflogin/cflogout. I went this way in hopes of being able to seamlessly intergrate the cf sign-ins with php sign-ins, more specifically phpBB. I don't think php can read cf sessions, if i'm wrong than correct me, so I'm thinking after the initial cf sign-in process, I will have to forward the page to a php sign-in script, then back again... whether using cflocation & the php equivalent (can't remember it right now). I would rather not use a js popup to run the additional script.
      Additional info: Both my site tables and the phpBB tables reside in the same database (msSQL 2000).
      Does anyone have any insight to this?? If so please respond. I'm slightly confused and don't want to waist days by going down the wrong track. Thanks in advance.
        • 1. Re: CF / phpBB intergration
          Level 7
          Any reason you want to go with a PHP based forum? Ever consider a CF based
          forum script?
          • 2. Re: CF / phpBB intergration
            romeogq Level 1
            phpBB is just waaaaaaaaaaaaaay better than the CF forums I've seen around on the web, in terms of functionality, esthetics, and add-on capability (MODS). Sorry about all the a's. I'm getting there, I'll post the walk-thru when done.
            • 3. Re: CF / phpBB intergration
              romeogq Level 1
              If anyone's interested, I figured out a way to log into both my cfm site and my phpbb forum, seemlessly.
              Joint registration was easy. Just post the required fields into the required tables.
              regdate must be unix, and password must be hash (md5).
              • 4. Re: CF / phpBB intergration
                romeogq Level 1
                For log in I used two functions... one for cfm login & the other for phpbb login.
                Using the first function to simply log into my cfm site, I stored both the phpbb username and password in session scope. This infomation I used for the second function.
                <cffunction name="inphpbb" access="public" returntype="string">
                <cfargument name="username" type="string" required="yes">
                <cfargument name="password" type="string" required="yes">
                <cfinclude template="phpbb_login_script.cfm">
                <cfabort>
                <cfreturn noResult>
                </cffunction>
                Included phpbb_login_script.cfm:
                <cfif not isdefined('session.login')>
                <cflocation url="#application.homepage#" addtoken="no">
                </cfif>
                <html xmlns=" http://www.w3.org/1999/xhtml">
                <head>
                <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" />
                </head>
                <body onload="document.phpbblogin.submit();">
                <cfoutput>
                <form name="phpbblogin" action=" http://www.yoursite.com/phpbb/login.php" method="post">
                <input name="username" type="hidden" value="#arguments.username#" />
                <input name="password" type="hidden" value="#arguments.password#" />
                <input name="autologin" type="hidden" value="1" />
                <input type="hidden" name="redirect" value=" http://www.yoursite.com/alldone.cfm">
                <input name="login" type="hidden" value="Log in" />
                </form>
                </cfoutput>
                </body>
                </html>
                Important:
                One small edit must be made to your login.php.
                Approx line 104, Comment redirect(append_sid($url, true));
                In it's place type, header("location: ".$HTTP_POST_VARS['redirect']); exit();
                This was a lot quickly. So if any questions, I'll be checking back periodically. Thanks to all whom helped me with aspects of this code (Mike, Dan).
                No I need to figure out how to sign out both, should be easier.
