1 Reply Latest reply on Aug 17, 2015 12:12 AM by Akash Sharma
    That bloody Import issue...
    andrewt37755647
      Can see the previews, click to import. Hangs. Import buttons grey out.
      Have to start LR again but repeats issue. Have checked all permissions.
      Have not been able to import a single (RAW) image since this started. No reason why, having worked so well, it has suddenly done this.
      I have seen this problem on other forums but have not seen any clear solution.
      Any helpers? (Adobe are next to useless as their "support" trail is circular....)
      MacBook Pro
      OS 10.10.2
      LR 5.7.1
        • 1. Re: That bloody Import issue...
          Akash Sharma Adobe Employee
          Hi Andrew,
          We Apologize for the Inconvenience you had.
          Please make sure that in the Import Panel>> Destination to which you are Coping/Adding/Moving files is not set as /Library or ~/Library
          Also make sure that you have the option  "Into Sub folder" Checked.
          Most importantly Read/Write Permissions to the Destination should be there.
          Try removing Phone/Card/Tablet connected to your computer and reimport.
          Hope that helps
          Akash
