1 Reply Latest reply on Aug 17, 2015 3:05 AM by EugenF.
    run script after variable has value (XML ajax request)
    EugenF.
      I would like to use XML data to set values in text elements. When I try to get information from the variable at this point, I get empty values. But it works well when I use the variable later in the code, as examle in the mouseover event.
      Code in .compositionReady:
      var xmlData;
      $.ajax({
        url: 'content.xml',
        dataType: 'xml',
        success: function(data){
        xmlData = $('element',data);
        sym.getComposition().getStage().$("txt_titel").html(xmlData.find("00").find("text").text( )); //<-------- delivers an empty value
        error: function(data){
        alert("Error loading Map Content from XML");
      Could someboday help me, please? What should be changed to get the code work?
        • 1. Re: run script after variable has value (XML ajax request)
          EugenF. Level 1
          Got it:
          var xmlData;
          $.ajax({
            url: 'content.xml',
            dataType: 'xml',
            sym.initText();
          sym.initText = function(){
          Thanks anyway.
