Captivate 8 software simulation slide automatically rewinds to previous slide. How do I stop it from doing this? It has occurred twice in my project. When I am on the slide that loops back, the Rewind button on the skin is highlighted but I did not click it.
You have to check Seamless tabbing option.
Can you check if there is an On Exit action for the slide?
There is No action on exit.
And you do not have interactive object with an action? Check also On Enter
action of next slide.
No interactive object. The On Enter is also No Action. I am stumped!
How do you test? Preview in Browser or Preview in HTML browser are best,
closest to published file.
I usually test with Preview from this slide. I just tried Preview in Browser and the auto-rewind problem is worse - it rewound to the beginning of the project instead of just 2 slides!
What happens when you uncheck the playbar?
I reviewed the slides again using Preview from this slide and noticed that the Rewind button is selected when I press the Tab button as part of the simulation!
Where is this option?
I found the Seamless Tabbing option in Publishing but found a similar option in Preferences>Project>Publishing Settings>Restrict keyboard tabbing to slide items only
