4 Replies Latest reply on Aug 18, 2015 11:42 PM by williamb49824458
    Same image in mutiple documents
    williamb49824458
      Hello,
      If I have an image in my InDesign document and I edit this file, InDesign gives me a marker to tell me the image has changed en needs to be updated. That's fine.
      But, what if I have an image which is used in several InDesign files. If I edit the image, is there a way InDesign can show me in which docs this file is being used?
      So that I know which documents I have to open and update.
      Thank in advance,
      William
        • 1. Re: Same image in mutiple documents
          Steve Werner Adobe Community Professional & MVP
          I don't think that's possible without some kind of content management system. InDesign doesn't have access to information about all the files (on various drives and servers) where you may have placed that picture.
          • 2. Re: Same image in mutiple documents
            John Mensinger Adobe Community Professional & MVP
            InDesign can't track that for you. But assuming the body of documents in question is stored logically in one or more locations where they can be searched, you can search for InDesign files which contain references to the image file name using Agent Ransack (Windows) or Spotlight search (Mac).
            • 3. Re: Same image in mutiple documents
              If you are sure you always want modified links to be updated, you could force updates when the document is opened via a startup script. So for OSX something like this Applescript—open in Apple's Script Editor and save to your startup scripts folder (Applications/Adobe InDesign CC 2014/Scripts/startup scripts). This would only work with modified links and missing links would not be changed.
              tell application "Adobe InDesign CC 2014"
                  set check links at open of linking preferences to false
                  make event listener with properties {event type:"afterOpen", handler:updateAll}
              end tell
              on updateAll()
                      try
                          tell active document
                              update (every link whose status is link out of date)
                          end tell
                      end try
                  end tell
              end updateAll
              • 4. Re: Same image in mutiple documents
                williamb49824458 Level 1
                Thanks for the input, Steve, John and Rob.
                I'll give it a try!
