3 Replies Latest reply on Aug 20, 2015 8:11 AM by JonnyDL
    applescript error I don't understand why its occuring
    JonnyDL Level 1
      Im writing a script that will convert photos from color to black and white. I wrote it at home on cs 5.1 and it worked flawlessly, but when I took it to work on a cs6 version it went buggy. again the code below works on 5.1 but when run at work  it gets into the photoshop handler convertpics() errors.
      It errors on change mode line. when run i get the word mode highlighted snd "Expected end of line, etc. but found identifier." it (also) doesn't seem to like the use of Document 1 or current document.in the other lines? Is it how I/m writing it that the dictionary/synatax has changed. ( i couldn't find ant difference). This one is racing my brain because to me it makes no scene. HELP!
      global picfolder
      global origimages
      tell application "Finder"
      set myhome to (path to home folder) as string
      set picfolder to myhome & "Documents:Dark Side:"
      if (exists (folder picfolder)) then
      movePics(picfolder) of me
      else
      make new folder at myhome & "Documents" with properties {name:"Dark Side"}
      end if
      set myPath to (path to home folder) as string
      end tell
      -------------------test to see if files are already there------------------------------------
      -------------------test to make sure original files still are there---------------------------
      on movePics(picfolder)
      tell application "Adobe InDesign CS5.5"
      tell document 1
      set linkList to file path of links
      repeat with linknumber from 1 to count of linkList
      set docimage to item linknumber of linkList
      copy file docimage to folder picfolder
      end tell
      end repeat
      end tell
      convertpics(picfolder) of me
      end tell
      end movePics
      on convertpics(picfolder)
      tell application "Finder" to set origimages to files of entire contents of folder picfolder
      repeat with i in origimages
      set oneImage to i as string
      tell application "Adobe Photoshop CS5.1"
      open file oneImage
      change mode of document 1 to grayscale
      set fname to name of current document as string
      set myFile to picfolder & fname & "_BW"
      save current document in file myFile as TIFF with options {byte order:Mac OS, embed color profile:false, image compression:LZW, save alpha channels:false, save layers:false} appending lowercase extension
      close current document without saving
      end tell
      end repeat
      end convertpics
