6 Replies Latest reply on Aug 20, 2015 1:50 PM by mkitos
    Lightroom won't export after OS X upgrade.
    mkitos
      Hi there.
      I just upgrade my Mac mini with the new OSX. Alway keep my OS up to date.
      And now my lightroom is unable to export the files.
      Is anyone out there with the same problem???
        • 2. Re: Lightroom won't export after OS X upgrade.
          99jon Adobe Community Professional & MVP
          Try trashing the prefs which is usually necessary after upgrading OSX. Start by quitting Lightroom.
          Launch Finder and click the Go menu whilst holding down the Option (alt) key. Then go to Library >> Preferences and clear everything relating to LR5 (or your version number) which usually means deleting the following files:
          com.adobe.Lightroom5.plist
          com.adobe.Lightroom5LSSharedFileList.plist
          Then re-launch Lightroom.
          • 3. Re: Lightroom won't export after OS X upgrade.
            mkitos Level 1
            Thanks for the quick replay here.
            Unfortunately didn't did the trick.
            On the good side it loads much quicker now.
            • 4. Re: Lightroom won't export after OS X upgrade.
              mkitos Level 1
              Hi there,
              Found the problem, was my fault really.
              Was try to export to a alias folder.
              Thank you very much for your help.
              • 5. Re: Lightroom won't export after OS X upgrade.
                Tanuj Sandal Adobe Employee
                Hi Mkitos,
                The time you export the images from LR, the option at the bottom "Post Processing" please make sure the option that says After Export says "Do nothing"
                Also where are you trying to export the images from LR , to you hard drive ?
                Incase that does not work , please let us know if you get any particular error while exporting.
                Please let us know if it helps.
                Regards,
                Tanuj
                • 6. Re: Lightroom won't export after OS X upgrade.
                  khatwani Adobe Employee (Admin)
                  Hi Marcos,
                  Sorry for that inconvenience.
                  Can you please try exporting that to desktop.
                  If that works that will be great.
                  If not please follow these steps.
                  Try giving permissions to both the Libraries (System Library & user Library) and the Applications folder.
                  For Applications Folder
                  Open Finder
                  On the left panel you will find applications folder ->  right click on that (CTRL + Click) and then click on Get Info.
                  At the bottom you will find sharing and permissions - Click on that
                  You will find a Lock icon at the bottom right , please click on that lock icon and then it might ask you for your mac password, please put in that.
                  Now click on the small plus(+) icon and then add the users that you want , Please make sure that you are adding the admin account as well.
                  Provide read and write permissions to all.
                  Click on the gear icon at the bottom of the get info window and then choose "Apply to enclosed items "  This will pop a message that changes cannot be undone- click OK to that.
                  This will apply privileges and that might take a bit time depending upon the size of folder.
                  once done , Click on lock icon and then close the get info window.
                  Done with applications folder here.
                  For User Library
                  Open Finder
                  Click on Go at the top and then select "Go to folder"
                  type "~/Library" and press go
                  Right Click(CTRL + click) on the the Library folder, if you are inside that library you can right click (ctrl + click) at blank space between the folders and then click on Get Info
                  Done with user library folder here.
                  For System Library
                  Open Finder
                  type "/Library" and press go
                  Done with System library folder here.
                  Please let me know if that works
                  Please Note : Do not just right click on complete MAC HD and provide full permissions that can make MAC in no boot mode.
                  Regards
                  Jitendra Khatwani
                  • 7. Re: Lightroom won't export after OS X upgrade.
                    mkitos Level 1
                    Hi there,
                    Was trying to export to a alias folder.
