0 Replies Latest reply on Aug 20, 2015 5:03 AM by Eric Lipton Ice
    Overzicht maken actieve fonts in Indesign via Applescript
    Eric Lipton Ice Level 1
      Ik wil bij deze een script delen. Het script maakt een overzicht van alle beschikbare fonts in InDesign. Er zijn meer scripts te vinden die dit doen, maar die voldeden niet voor mij. Voorheen werkte fontgander perfect, maar dat was systeem 9. Ik heb tot op heden nog niets vergelijkbaars gezien voor OSX. Uit ontevredenheid geboren dus dit script. Enjoy!
      tell application "Adobe InDesign CS6"
          activate
          set myFontList to get name of fonts as string
          set mydoc to make document
          tell document 1 to tell document preferences
              set pages per document to 1
              set page orientation to landscape
              set page width to "210 mm"
              set page height to "297 mm"
              set facing pages to false
          end tell
          tell master spread 1 of mydoc to tell margin preferences of pages
              set top to 5.5
              set left to 5.5
              set bottom to 5.5
              set right to 5.5
              set column count to 5
              set column gutter to 3
          end tell
          set find text preferences to nothing
          set change text preferences to nothing
          set find what of find text preferences to "    "
          set change to of change text preferences to " "
          set transform reference point of layout window 1 to top left anchor
          zoom layout window 1 given fit page
      end tell
      set nBrs to count myFontList
      set nTal to nBrs / 25
      round nTal rounding up
      set sampleText to "A B C D E F G H I J K L M N O P Q R S T U V W X Y Z a b c d e f g h i j k l m n o p q r s t u v w x y z 0 1 2 3 4 5 6 7 8 9 ( ! ? ; ” & @ ] }"
      set f to 1
      set xPage to 1
      repeat nTal times
          set b1 to 5.5
          set a1 to 5.5
          set b2 to 8.5
          set a2 to 42.9
          set b3 to 9.5
          set a3 to 5.5
          set b4 to 59.5
          set a4 to 42.9
          repeat 5 times
              tell application "Adobe InDesign CS6" -- [rij 1:]
                  tell page xPage of document 1
                      set xFrame01 to make text frame with properties {geometric bounds:{b1, a1, b2, a2}, fill color:color id 11, contents:(item f of myFontList), text frame preferences:{vertical justification:center align}}
                      delay 0.25
                      tell xFrame01 to tell paragraph 1
                          set applied font to "DINCond    Medium"
                          set point size to 5.5
                          set fill color to color id 15
                          set left indent to 1.0
                          set right indent to 0.5
                          set baseline shift to 0.5
                      end tell
                      set xFrame02 to make text frame with properties {geometric bounds:{b3, a3, b4, a4}, fill color:color id 14, contents:sampleText, text frame preferences:{vertical justification:justify align, auto sizing type:height and width proportionally, auto sizing reference point:top left point}}
                      tell xFrame02 to tell paragraph 1
                          set applied font to (item f of myFontList)
                          set point size to 27.712
                          set leading to 25.697
                          set fill color to color id 11
                          set justification to fully justified
                          set kerning method to "Optisch"
                          set tracking to -125
                          set composer to "Adobe Composer alinea"
                          set name of xFrame02 to "sampleText"
                      end tell
                  end tell
              end tell
              set b1 to b1
              set a1 to a1 + 40.4
              set b2 to b2
              set a2 to a2 + 40.4
              set b3 to b3
              set a3 to a3 + 40.4
              set b4 to b4
              set a4 to a4 + 40.4
              set f to (f + 1)
          end repeat
          set d1 to 63.5
          set c1 to 5.5
          set d2 to 66.5
          set c2 to 42.9
          set d3 to 67.5
          set c3 to 5.5
          set d4 to 117.5
          set c4 to 42.9
          repeat 5 times
              tell application "Adobe InDesign CS6" -- [rij 2:]
                      set xFrame01 to make text frame with properties {geometric bounds:{d1, c1, d2, c2}, fill color:color id 11, contents:(item f of myFontList), text frame preferences:{vertical justification:center align}}
                      delay 0.25
                      end tell
                      set xFrame02 to make text frame with properties {geometric bounds:{d3, c3, d4, c4}, fill color:color id 14, contents:sampleText, text frame preferences:{vertical justification:justify align, auto sizing type:height and width proportionally, auto sizing reference point:top left point}}
                      end tell
                  end tell
              end tell
              set d1 to d1
              set c1 to c1 + 40.4
              set d2 to d2
              set c2 to c2 + 40.4
              set d3 to d3
              set c3 to c3 + 40.4
              set d4 to d4
              set c4 to c4 + 40.4
              set f to (f + 1)
          end repeat
          set f1 to 121.5
          set e1 to 5.5
          set f2 to 124.5
          set e2 to 42.9
          set f3 to 125.5
          set e3 to 5.5
          set f4 to 175.5
          set e4 to 42.9
          repeat 5 times
              tell application "Adobe InDesign CS6" -- [rij 3:]
                      set xFrame01 to make text frame with properties {geometric bounds:{f1, e1, f2, e2}, fill color:color id 11, contents:(item f of myFontList), text frame preferences:{vertical justification:center align}}
                      delay 0.25
                      end tell
                      set xFrame02 to make text frame with properties {geometric bounds:{f3, e3, f4, e4}, fill color:color id 14, contents:sampleText, text frame preferences:{vertical justification:justify align, auto sizing type:height and width proportionally, auto sizing reference point:top left point}}
                      end tell
                  end tell
              end tell
              set f1 to f1
              set e1 to e1 + 40.4
              set f2 to f2
              set e2 to e2 + 40.4
              set f3 to f3
              set e3 to e3 + 40.4
              set f4 to f4
              set e4 to e4 + 40.4
              set f to (f + 1)
          end repeat
          set h1 to 179.5
          set g1 to 5.5
          set h2 to 182.5
          set g2 to 42.9
          set h3 to 183.5
          set g3 to 5.5
          set h4 to 233.5
          set g4 to 42.9
          repeat 5 times
              tell application "Adobe InDesign CS6" -- [rij 4:]
                      set xFrame01 to make text frame with properties {geometric bounds:{h1, g1, h2, g2}, fill color:color id 11, contents:(item f of myFontList), text frame preferences:{vertical justification:center align}}
                      delay 0.25
                      end tell
                      set xFrame02 to make text frame with properties {geometric bounds:{h3, g3, h4, g4}, fill color:color id 14, contents:sampleText, text frame preferences:{vertical justification:justify align, auto sizing type:height and width proportionally, auto sizing reference point:top left point}}
                      end tell
                  end tell
              end tell
              set h1 to h1
              set g1 to g1 + 40.4
              set h2 to h2
              set g2 to g2 + 40.4
              set h3 to h3
              set g3 to g3 + 40.4
              set h4 to h4
              set g4 to g4 + 40.4
              set f to (f + 1)
          end repeat
          set j1 to 237.5
          set i1 to 5.5
          set j2 to 240.5
          set i2 to 42.9
          set j3 to 241.5
          set i3 to 5.5
          set j4 to 291.5
          set i4 to 42.9
          repeat 5 times
              tell application "Adobe InDesign CS6" -- [rij 5:]
                      set xFrame01 to make text frame with properties {geometric bounds:{j1, i1, j2, i2}, fill color:color id 11, contents:(item f of myFontList), text frame preferences:{vertical justification:center align}}
                      delay 0.25
                      end tell
                      set xFrame02 to make text frame with properties {geometric bounds:{j3, i3, j4, i4}, fill color:color id 14, contents:sampleText, text frame preferences:{vertical justification:justify align, auto sizing type:height and width proportionally, auto sizing reference point:top left point}}
                      end tell
                  end tell
              end tell
              set j1 to j1
              set i1 to i1 + 40.4
              set j2 to j2
              set i2 to i2 + 40.4
              set j3 to j3
              set i3 to i3 + 40.4
              set j4 to j4
              set i4 to i4 + 40.4
              set f to (f + 1)
          end repeat
                  repeat with oneFrame in (get text frames)
                      set a to visible bounds of oneFrame
                      set x1 to second item of a
                      set x2 to fourth item of a
                      set b to x2 - x1
                      set c to 37.4 / b * 100
                      tell oneFrame to set horizontal scale to c
                      tell oneFrame to set vertical scale to c
                  end repeat
              end tell
          end tell
          set xPage to (xPage + 1)
              tell document 1
                  tell every text frame to change text
                  select (every page item whose name is "sampleText")
                  tell application "System Events" to tell process "InDesign"
                      key code 31 using {shift down, command down}
                  end tell
                  try
                      set name of selection to "doetutniet"
                  end try
                  set myMaster to object reference of master spread "A-Stramien"
                  set myNewPage to make page with properties {applied master:myMaster}
              end tell
              set active spread of active window to parent of myNewPage
          end tell
      end repeat
          tell document 1
              delete myNewPage
          end tell
      end tell
