3 Replies Latest reply on Aug 21, 2015 6:38 AM by Doug A Roberts
    Where does InDesign keep text variables?
    Doug A Roberts Adobe Community Professional & MVP
      Specifically the readymade ones. I have been on a hunt but can't seem to track them down. Also, what are they made of? What kind of file?
        • 1. Re: Where does InDesign keep text variables?
          Steve Werner Adobe Community Professional & MVP
          I don't believe there is any external preset or style file which they are stored in. I think they're probably stored within the InDesign preferences.
          If you wanted them used in all future InDesign files, you could define them with Type > Text Variables > Define when no documents are open, and they should appear in any new document. (I haven't tested this but it should work, I think.)
          In the Text Variables dialog box, there is a Load command, so you should also be able to import them by selecting another InDesign file that has the text variable(s) you need.
          • 2. Re: Where does InDesign keep text variables?
            What are you trying to do? Use existing variables, or define some new type of variable that is not yet implemented?
            • 3. Re: Where does InDesign keep text variables?
              Hello chaps,
              I wanted to use this script:
              Add highly customized Text Variables to InDesign | Ozalto
              ...to establish a 'last modified by [username]' variable for some of our documents here (along with a regular modified date one). but as it updates the variable on a document open event, it simply shows whatever user has the document open at the time, not so useful. so i was hunting through the other event types for something suitable. i thought the Modification Date variable must be doing something similar at the point i'd want the user's name variable to update, so i thought if maybe i could have a look in it i could apply whatever it's doing to the new variable. having it run 'beforeSave/As/Copy' seems to work alright though. 'before/afterClose' didn't seem to have the desired effect, though i would ideally like it to update whenever the Modification Date updates.
