2 Replies Latest reply on Aug 20, 2015 5:08 PM by Captiv8r
    Auto save in RH 2015
    daveh0714 Level 1
      How do you disable auto save in RoboHelp 2015? The instructions say to deselect "Save Without Prompt" in the General tab, but that option does not exist. Is it now "Check in all files when closing a project" in the Version Control tab?
        • 1. Re: Auto save in RH 2015
          Hi there
          Sounds like you are wanting to see the confirmation dialog when you close a file? If so, click the File tab and choose Options. Then click the General section on the left side of the dialog that appears. On the right side near the bottom is an option that governs this behavior. Enable this and click the OK button and you should be set.
          Cheers... Rick
          • 2. Re: Auto save in RH 2015
            daveh0714 Level 1
            We have that enabled. A user messed up the folder structure and we were wondering if there was a way out of the project without saving those messed up folders.
            • 3. Re: Auto save in RH 2015
              Ahhh, folders being moved around are an entirely different story. Those changes are immediate. About the only thing you could do would be to perform an undo. But assuming that were to work, it would pretty much need to happen almost immediately after the initial move occurred.
              Cheers... Rick
