11 Replies Latest reply on Dec 21, 2006 9:11 AM by Newsgroup_User
    QT movie refuses to leave stage...
    Level 7
      I have a QT movie that plays on stage with this lingo:
      on timeout
      go to "start"
      end
      property spriteNum
      on exitFrame me
      myMember = sprite(11).member
      myDuration = member(myMember).duration
      myMovietime = sprite(11).movieTime
      if myDuration > myMovietime then
      go to the frame
      else
      go to "start"
      end if
      end
      As long as I run it from within DW9 environment, it works fine. The
      movie plays when done, exits to the "start" marker as it should.
      However, as soon as I try to play the .dir outside of DW9 (from my exe),
      the movie plays, but at the end of the movie, the QT window remains
      (hangs)on stage.
      This is a kiosk app...
      Any ideas on this?
      Thanks.
      Dave
        • 1. Re: QT movie refuses to leave stage...
          Level 7
          You could move the video off the screen by changing it's locH value when
          it's done. That's what I've had to do in several cases, because the
          last frame of the video always stays resident on the screen.
          • 2. Re: QT movie refuses to leave stage...
            Level 7
            On Wed, 13 Dec 2006 18:30:37 GMT, Dave Anderson posted in
            macromedia.director.lingo:
            > else
            > go to "start"
            the stageColor = the stageColor --<<< Add this line
            > end if
            Mark A. Boyd
            Keep-On-Learnin' :)
            • 3. Re: QT movie refuses to leave stage...
              Level 7
              Sorry Mark, but that didn't seem to do it either. Any other ideas?
              Dave
              >> else
              >> go to "start"
              >> end if
              • 4. Re: QT movie refuses to leave stage...
                Level 7
                On Mon, 18 Dec 2006 12:50:23 GMT, Dave Anderson posted in
                That typically works for me. Did you try the other suggestions?
                Another method is to have a transparent shape sprite on your "start" frame.
                The sprite can fill the stage or it can be the same rect as the QT sprite.
                This new sprite should force Director to redraw those pixels.
                Mark A. Boyd
                Keep-On-Learnin' :)
                • 5. Re: QT movie refuses to leave stage...
                  Level 7
                  Sounds interesting. I'll give that a whirl. I didn't try the loc thing,
                  not sure if I'd know how.
                  What's weird is that it works fine when tested within DX, but not as a
                  projector... Hmmmm.
                  I'll report back.
                  • 6. Re: QT movie refuses to leave stage...
                    Level 7
                    on timeout
                    go to "start"
                    end
                    property spriteNum
                    on exitFrame me
                    if myDuration < myMovietime then
                    go to the frame
                    else
                    go to "start"
                    end if
                    end
                    I've tried: "myDuration < myMovietime", "myDuration = myMovietime", and
                    "myDuration > myMovietime"
                    In each instance, the same issue with QT not exiting the stage (the last
                    frame of the video stays visible in fact). I also tried the transparent
                    sprite in the start frame -- no luck.
                    Maybe this means that my exitFrame script is not right?
                    Dave
                    • 7. Re: QT movie refuses to leave stage...
                      Level 7
                      On Mon, 18 Dec 2006 19:24:16 GMT, Dave Anderson posted in
                      > property spriteNum
                      > on exitFrame me
                      > go to the frame
                      > else
                      > go to "start"
                      > end if
                      > end
                      > Dave
                      Seems OK to me. Are you certain that it's actually going to "start"?
                      A couple of notes that may not help, but worth trying.
                      You may need to provide a little slop tolerance
                      if (myDuration - 60) <= myMovieTime then
                      And there's no need to set the duration in every frame loop. Add a property
                      variable and set it once in a beginSprite event
                      property myDuration
                      on beginSprite me
                      myDuration = sprite(11).member.duration
                      -- myDuration = sprite(11).member.duration - 60 --<< if slop factor needed.
                      end
                      on exitFrame me
                      if sprite(11).movieTime <= myDuration then
                      go the frame
                      else
                      sprite(11).locV = - 1000
                      go to "start"
                      end if
                      end
                      Mark A. Boyd
                      Keep-On-Learnin' :)
                      • 8. Re: QT movie refuses to leave stage...
                        kalibahlutwo Level 1
                        How about just going to another frame that plays the QT on timeout? Then when you leave that frame, the movie will be gone.
                        • 9. Re: QT movie refuses to leave stage...
                          Level 7
                          > property myDuration
                          > on beginSprite me
                          > end
                          > on exitFrame me
                          > go the frame
                          > else
                          > go to "start"
                          > end if
                          > end
                          I think that I'm concluding that the movie is not going back to "start"
                          at the end. I tried your suggestion with no luck either. What I do know
                          is that after the QT piece has played, remaining on the screen, I can
                          click the "Stop" sprite and immediately the QT window goes away
                          indicating that the movie went back to "start".
                          ("Stop" sprite's script)
                          on mousedown me
                          go to "start"
                          end
                          So the question is why isn't the movie going back to the start marker
                          when the QT is finished?? In fact, it appears that when the movie
                          reaches a timeout, it doesn't reset back to start...
                          on startMovie
                          set the timeoutLength = 330*60
                          cursor 200
                          end
                          on mouseup me
                          end
                          on mousedown me
                          end
                          on exitFrame
                          end
                          • 10. Re: QT movie refuses to leave stage...
                            Level 7
                            Since the movie isn't going back to 'start', is there a way to force it
                            to do that based on the length of the QT? The QT clip is 5:26. So maybe
                            something with manually setting
                            myMovietime = sprite(11).movieTime - 315*60
                            Would that work?
                            property myDuration
                            on beginSprite me
                            end
                            on exitFrame me
                            if sprite(11).movieTime = 315*60 then
                            go the frame
                            else
                            go to "start"
                            end if
                            end
                            >> property spriteNum
                            >> on exitFrame me
                            >> go to the frame
                            >> else
                            >> go to "start"
                            >> end if
                            >> end
                            >> Dave
                            > property myDuration
                            > on beginSprite me
                            > end
                            > on exitFrame me
                            > go the frame
                            > else
                            > go to "start"
                            > end if
                            > end
                            • 11. Re: QT movie refuses to leave stage...
                              Level 7
                              On Thu, 21 Dec 2006 12:57:44 GMT, Dave Anderson posted in
                              I haven't caught anything fundamentally wrong with the scripts (can't get to
                              Director from this machine).
                              Is the script in a behavior script placed in the script channel of the
                              Score? If it's a movie script, then the property variables won't work this
                              way.
                              Before banging your head too much, I would try placing a breakpoint or some
                              strategic "put" commands in the script. Also, test in a bare-bones Director
                              file.
                              > on exitFrame me
                              > go the frame
                              Chances are extremely thin that a movieTime will exactly equal a given value
                              in an exitFrame event. It is best to use <= in this case.
                              Mark A. Boyd
                              Keep-On-Learnin' :)
