3 Replies Latest reply on Aug 25, 2015 11:00 AM by greenrookie
    relink problem
    JonnyDL Level 1
      Im writing a script that will take the color images from indesign, copy them, change them to grayscale (and rename them) then take those files and relink them (replace them with the grayscale). I've seen examples and it appears simple enough, but I can't get it to work *it still has a few bugs/and syntax issues Im looking to clean up
      here is the script. hopefully someone can see where the error is coming from and hopefully explain why.
      global picfolder
      global origimages
      global bwname
      set bwname to "color"
      tell application "Finder"
        set myhome to (path to home folder) as string
        set picfolder to myhome & "Documents:Dark Side:"
        if (exists (folder picfolder)) then
        movePics(picfolder) of me
        else
        make new folder at myhome & "Documents" with properties {name:"Dark Side"}
        end if
        set myPath to (path to home folder) as string
      end tell
      -------------------test to see if files are already there------------------------------------
      -------------------test to make sure original files still are there---------------------------
      on movePics()
        tell application "Adobe InDesign CS6"
        tell document 1
        set linkList to file path of every link
        repeat with linknumber from 1 to count of linkList
        set docimage to item linknumber of linkList
        set aName to name of file docimage
        end tell
        try
        copy file docimage to folder picfolder
        end try
        end tell
        end repeat
        end tell
        convertpics(picfolder) of me
        end tell
      end movePics
      on convertpics()
        tell application "Finder" to set origimages to files of entire contents of folder picfolder
        repeat with i in origimages
        set oneImage to i as string
        tell application "Adobe Photoshop CS6"
        open file oneImage
        change mode of current document to grayscale
        set fullname to name of current document as string
        try
        set AppleScript's text item delimiters to {"_"}
        set bwname to second text item of fullname
        end try
        if bwname ≠ "BW.TIF" then
        set AppleScript's text item delimiters to {"."}
        set fname to first text item of fullname
        set myFile to picfolder & fname & "_BW"
        save current document in file myFile as TIFF -- with options {byte order:Mac OS, embed color profile:false, image compression:LZW, save alpha channels:false, save layers:false, transparency:true} appending lowercase extension
        end if
        close document 1 without saving
        end tell
        end repeat
        indesignRelink()
      end convertpics
      on indesignRelink()
        set fname to name of file oneImage
        end tell
        set origlink to picfolder & fname
        set justname to first text item of fname
        set newpick to picfolder & justname & "_BW.TIF"
        display dialog newpick
        relink origlink to newpick
        end tell
        end repeat
      end indesignRelink
        • 1. Re: relink problem
          greenrookie Level 2
          Hi JonnyDL,
          I haven't gone through all the code and I presume that the other parts work and that you're stuck on the relinking at the end.
          Try this.
          On the 'on convertpics()' handler block:
          Change indesignRelink() to:
          my indesignRelink()
          On the 'on indesignRelink()' handler block:
                    set newpick to picfolder & justname & "_BW.TIF" as string
                  relink origlink to alias newpick
          greenrookie
          • 2. Re: relink problem
            JonnyDL Level 1
            greenrookie
            sorry for the slow response got tied up in other things. that didn't seem to work.
            I get  a very indescriptive  error. that it doesn't understand the relink command. I've tried caring combinations of the relink command, and I keeps giving me the same error. I'm thinking it is how the relink command is seeing the path (as not a acceptable path format?). I'll try and find some working relink code, and see if i can find were mine is gone wrong. Any suggestions otherwise would be appreciated.
            • 3. Re: relink problem
              greenrookie Level 2
              Right.
              We don't need to to loop in the Finder, we loop with try in InDesign, and InDesign will take care of the link for us (nice).
              I tested it for me, let me know how you get on.
              Replace the whole block.
              on indesignRelink()
                                           tell active document
                                                         set evGraphic to every link
                                                         repeat with i from 1 to count of evGraphic
        try
        set origlink to item i of evGraphic
        set fname to name of origlink
        --display dialog newpick
        end try
                                                         end repeat
                                           end tell
                            end tell
              end indesignRelink
