1 Reply Latest reply on Aug 21, 2015 3:40 PM by A.T. Romano
    Come faccio ha controllare se la mia versione di Premiere Elements è a 32 bit o a 64 bit?
    francescol99051930
      Ho da poco acquistato Premiere Elements e Photoshop Elements in bundle. Premesso che ho un SO Windows x64 recentemente aggiornato a Windows 10, ho notato che alcuni programmi di gestione del computer (Revo Unisaller, CCLeaner) segnano i due programmi come a 32 bit. Come faccio a contrllare se i due programmi istallati sono x64 o x32? Grazie per l'aiuto.
        • 1. Re: Come faccio ha controllare se la mia versione di Premiere Elements è a 32 bit o a 64 bit?
          A.T. Romano Level 7
          francesco
          If you have Windows 7, 8, , 8.1, or 10 64 bit computer and have Premiere Elements Windows 10, 11, 12, or 13 installed on one of those computers, Premiere Element is running as a 64 bit application in the 64 bit system.
          A quick and easy way to prove that to yourself is to right click the computer taskbar, select Start Task Manager/Processes and look at the name for the opened Premiere Elements process (.exe file).
          If 64 bit process, the you should not see anything after the name of the exe file
          If 32 bit process, you should see the name of the exe file with *32 at the end of its name
          If you wanted to spend more time, you could download and install the Process Explorer Sysinternals
          Process Explorer
          and look at the Image Type column for 32 or 64 bit.
          ATR
