4 Replies Latest reply on Aug 23, 2015 2:19 PM by fabienroche
    Double arbitrary mask question...
    fabienroche
      Hello,
      I have a field where I want the user to only input in the format N999 or R999, where 999 is any number between 000 and 999.
      Additionally I would like the letter to be upper-case always.
      I can handle a single mask and the upper-case bit.
      What I can't do is handle all of them together...
      Any help please?
      Thank you.
      Fabien
        • 1. Re: Double arbitrary mask question...
          One needs to use custom JavaScript and the RegExp  object to create a RegExp variable for the image of the format.
          The format and validation RegExp image could be:
          /^[NR]\d{3}$/
          One can then use the "test" method to see if the inputted string matches the format or not.
          Validation script:'
          // process non-empty values;
          if(event.value != "") {
          if( /^([NR]\d{3})$/.test(event.value) == false) {
          app.alert("Enter value in the format of N999 or R999.", 1, 0);
          event.rc = false;
          } // end RegExp test
          } // end non-empty value;
          With the RegExp this becomes one mask with an optional positional value that can have one of 2 values.
          Break down of values:
          /^ - start of RegExp
          [NR] - first position can have a value of "N" or 'R".
          \d{3} - positions 2-4 has a 3 digit value, leading digits are mandatory.
          $/ - end of RegExp.
          It is also possible to modify the expression to limit keystrokes and formatting of displayed data if needed.
          RegExp is a common object in many scripting and programing languages and many text editing programs.
          • 2. Re: Double arbitrary mask question...
            fabienroche Level 1
            Wow, thank you so much for your quick and amazing answer. It works a charm!
            If I in addition to the above (in order to prevent the popup from coming up all the time) I wanted to immediately capitalise the first letter how/where would I do so please...? :-)
            Thanks a lot for your help!
            Kind Regards,
            Fabien
            • 3. Re: Double arbitrary mask question...
              Here is a custom keystroke script that will force the entered values to upper case,  allow only N or R for the first character followed by 3 numeric digits.
              // custom keystroke
              // RegExp for keystroke entry;
              // N or R followed by 3 digits;
              var reks_entity =/^([NR])(\d{0,3})$/
              if(event.willCommit == false) {
              //force entry to upper case; // force keystroke to upper case;
              event.change = event.change.toUpperCase();
              // test keystroke entries for valid keys;
              if(reks_entity.test(event.value + event.change) == false) {
                // reject any that fail the test;
                app.beep();
                event.rc = false;
                } // end RegExp test;
              } // end commit == false;
              // end custom keystroke script
              • 4. Re: Double arbitrary mask question...
                fabienroche Level 1
                Thanks once again for this great script that works a miracle!
                You are a scripting God!
                Cheers,
                Fabien.
