3 Replies Latest reply on Aug 24, 2015 1:26 AM by EvaMartin
    relative links "unsupported path"
    EvaMartin
      Hello !
      I would like to link two edge docs in order to read the animations without any connexion, so everythng is local, and all my links must be relative.
      I have a folder with animation A, and another with animation B.
      I can successfully "descending" in the browser linking A to another A file or A folder  (with a "./ type link"), but i can't go up to re-descend into B folder with a "../B/B.html" link ... Is that normal ? is there anything I can do ?? The idea would be to have a main document that does shortcuts to other documents ... Thank you for your help, please ask if anything is unclear, english is not my mothertongue
      Cheers !
        • 1. Re: relative links "unsupported path"
          Dean Utian Adobe Community Professional
          Hi platypus8622,
          Here's an example that explains the relative links. Say I have an html called main.html at the top folder level, then have 2 subfolders called animA and animB with A.html and B.html in each respectively. Here's how you could link between them. Using: window.open("htmlLink", "_self");
          main.html linking to A.html
          window.open("animA/A.html", "_self");
          main.html linking to B.html
          window.open("animB/B.html", "_self");
          A.html or B.html linking to main.html
          window.open("../main.html", "_self");
          A.html linking to B.html
          window.open("../animB/B.html", "_self");
          The above should work. If it is not for you, there may be a typing mistake. If it's still not working, provide the exact code you've used.
          • 2. Re: relative links "unsupported path"
            EvaMartin Level 1
            Hi ! Thank you for answering !
            Now that's weird ... Today, if I retry my links, even the "descending" ones aren't working anymore :
            If i put :
            window.open("test-folder/test.html", "_blank");
            it goes loading forever, and nothing happens (but I don't see the "unsupported path" error)
            If i try to link in the same folder but to an image rather to an html file, it's works perfectly !! WTH ?
            And if I try go "go up" with :
            window.open("../plan-02.jpg", "_blank");
            Whatever file I try to load (html or image), I have the "unsupported path" error.
            The online urls like www.ggogle.com are working fine.
            Maybe there is a parameter I should activate to make the relative links work ?
            I'm going crazy with this
            Eva
            • 3. Re: relative links "unsupported path"
              Hi Eva,
              Are you testing from Animate with the 'Preview in Browser' option? If so, try just open the HTML directly in a browser (so not through Animate) and see if that works. It may be that the preview path is not happy with finding relative links.
              • 4. Re: relative links "unsupported path"
                EvaMartin Level 1
                Ohhhh ... I feel so silly not having tested that before !!
                You are right : works perfectly if the html are launched independantly from EA
                Thank you for making my day a nice day !!
                Cheers,
                Eva
