2 Replies Latest reply on Aug 21, 2015 1:47 PM by Test Screen Name
    JavaScript Syntax error
    Sean.twyman Level 1
      Im gettings a syntax erro and cant figure out why.
      var a = this.getField("P1.B1U"); //checkbox
      var b = this.getField("P1.EBreak1Min");
      var c = this.getField("P1.Break1Min");
      var d = this.getField("P1.Break1OK");
      if (a.value = "Yes"){ //if checkbox is checked
          if (c.value >= 8 && c.value <= 22){ // then if P1.Break1Min is greater than or equal 8 but less than or eaual to  22
          event.value = (.25);
          d.value = "";
          else if (c.value >= 23 && c.value <= 37){
          event.value = (.50);
          d.value = "";
          else if (c.value >= 38 && c.value <= 52){
          event.value = (.75);
          d.value = "";
          else if (c.value >= 53 && c.value <= 67){
          event.value = (1);
          d.value = "";
      else if (b.value >= 8 && b.value <= 22){ //P1.B1U not checked and P1.EBreak1Min is greater than or equal 8 but less than or eaual to  22
      d.value = "";
      else if (b.value >= 23 && b.value <= 37){
      d.value = "";
      else if (b.value >= 38 && b.value <= 52){
      d.value = "";
      else if (b.value >= 53 && b.value <= 67){
      event.value = (1);
      d.value = "";
      else{
      event.value = ("0");
      d.value = "Yes";
      this is the error I am getting from the java console:
      SyntaxError: syntax error
      12:Field:Calculate
      InvalidSetError: Set not possible, invalid or unknown.
      Field.value:6:Field P1.Break1D:Calculate
        • 1. Re: JavaScript Syntax error
          George_Johnson MVP & Adobe Community Professional
          It's probably due to this line:
          1. if (a.value = "Yes"){ //if checkbox is checked
          Which should be:
          1. if (a.value == "Yes"){ //if checkbox is checked
          or better yet:
          1. if (a.value === "Yes"){ //if checkbox is checked
          • 2. Re: JavaScript Syntax error
            Sean.twyman Level 1
            OK i took your suggestions nad used the last option you provided, but now I just get a  generic error....
            12:Field:Calculate
            and in another field that the question above references to I have problems with this code at line 5 i believe
            var strStart = this.getField("P1.Break1O").value;  //start time
            var strEnd = this.getField("P1.Break1I").value;  //end time
            var a = this.getField("P1.B1U").value//Checkbox
            if(var a === "Yes"){ //if checkbox is checked
            event.value = 0; //event value is automatically 0
            else if(strStart.length && strEnd.length){
                var timeStart = util.scand("h:MM tt m/d/yy", strStart + " " + util.printd("m/d/yy", new Date()));
                var timeEnd = util.scand("h:MM tt m/d/yy", strEnd + " " + util.printd("m/d/yy", new Date()));
                var diff = timeEnd - timeStart;
                var oneHour = 60 * 1000;
                var timeleft = (diff/oneHour);
              if(timeleft > 10){   //checkbox is not checked and timeleft is greater than 10
              event.value = 10;
                else  // checkbox not checked and timeleft is less than 10
                event.value = timeleft;
            else  //strEnd or strStart is empty
            event.value = 0
            • 3. Re: JavaScript Syntax error
              You use "var" once to create the variable. You are repeating the "var" incorrectly.
