4 Replies Latest reply on Aug 25, 2015 11:21 AM by birnerseff
    script access to item notes
    birnerseff Level 2
      I try to make use of the note attribute. The scripting reference (JS) just lists an editable "note" property for art items.
      Now, I can set the note via script, and it shows up in the attribute panel if it was otherwise unset. If I set the note via UI, the UI will show the user input, whereas a script reading the note will only read the values that were set by a script. Is there a way to access both user and script parts of the note? Also, is there a way to include the note to svg export?
