1 Reply Latest reply on Dec 12, 2006 10:39 AM by peterent
    Embed .swf question
    jlingwai Level 1
      I have a flash .swf file inwhich I embed into my flex application. In the flex application I have a login. In the flash file i have buttons which control the navigation of the flash file. I want to validate if the user is logged in before allowing the buttons to work. Is this possible?
      JoSh
        • 1. Re: Embed .swf question
          peterent Level 2
          If you flash SWF is a SWF9 then you will be able to communicate in a function-call fashion as if the flash SWF is a component. Using SWFLoader, the content child is the flash SWF.
          If you are using a SWF8 or anything earlier, you will need to use LocalConnection. The reason is the SWF9 is ActionScript 3, just like Flex, and they reside in the same Flash Player VM (virtual machine). SWF8 and earlier are ActionScript 2 and must run in a different virtual machine; this makes it possible for Flash Player 9 to play all previous Flash content.
          LocalConnection allows for one-way communication between any two Flash Players (or VMs).
