3 Replies Latest reply on Aug 27, 2015 2:00 AM by clunty
    How can I find the target/result of a photoshop event?
    clunty
      Hi all,
      Is there a method of retrieving information about the results of a Photoshop event? For example, after a Delete event ("Dlt ") can I get any information on what was deleted?
      Specifically my current needs are to find what layer was deleted after a delete event.
      The relevant js code in my project is:
      function registerPSEvent( typeIDs, clear ){
        // unregisters an even before adding it - prevents double events
        var regUnreg = null;
        if( clear ){
        console.log( 'Unregistering ' + typeIDs );
        regUnreg = 'PhotoshopUnRegisterEvent';
        } else {
        console.log( 'Registering ' + typeIDs );
        regUnreg = 'PhotoshopRegisterEvent';
        var e = new CSEvent(
        'com.adobe.' + regUnreg,
        'APPLICATION',
        csInterface.getApplicationID(),
        csInterface.getExtensionID()
        e.data = typeIDs;
        csInterface.dispatchEvent(e);
      // s2t is simply an abbreviation of stringIDToTypeID
      function addPSEventListener( typeStrings, callback, target ) {
        csInterface.evalScript( "s2t('"+typeStrings+"')", function(r){
        registerPSEvent( r, true );
        registerPSEvent( r );
        csInterface.addEventListener( 'PhotoshopCallback', callback.bind(target) );
      addPSEventListener( 'delete', delLayerEventHandler, this );
      delLayerEventHandler = function(e) {
        console.log(e);
        // here i would like to be able to get what was deleted
      Tom
        • 1. Re: How can I find the target/result of a photoshop event?
          clunty Level 1
          I have found this post which seems to be able to achieve this by using app.notifier:
          Re: How to get event target?
          Ideally I would like to achieve this by using CSEvents
          • 2. Re: How can I find the target/result of a photoshop event?
            Pedro Cortez Marques Level 3
            Using javascript on CC2014
            //  to catch each one event (notifiers) properties, use this:
            for (var a=0; a<app.notifiers.length; a++) {
                var event_ = app.notifiers[a].event;
                $.writeln(event_);
                var eventFile_ = app.notifiers[a].eventFile;
                $.writeln(eventFile_);
                var eventClass_ = app.notifiers[a].eventClass;
                $.writeln(eventClass_);
                // if you want to delete a specific one, reading 1,2 or 3 inner properties, use this:
                // if ([condition]) app.notifiers[a].remove();
            //~ // but you can remove all notifiers (events) at the same time like this
            //~ app.notifiers.removeAll();
            • 3. Re: How can I find the target/result of a photoshop event?
              clunty Level 1
              I've just discovered that when an event is received event.data holds 2 ints.
              I thought these 2 numbers were due to me using stringIDToTypeID rather than charIDToTypeID. However the second number is a way to access any attributes of the event. So I'm now using the below function to get info on the event:
              function get_event_descriptor( id ) {
                var desc = new ActionDescriptor();
                  try{
                      desc.fromID(id);
                      var aref = desc.getReference(s2t('null'));
                      var aref_obj = {
                          dclass : t2s( aref.getDesiredClass( s2t( 'null' ) ) ),
                          // id : aref.getContainer().getName()
                      return JSON.stringify( aref_obj );
                  } catch(e) {
                      //return false;
                      return JSON.stringify(e.message);
              id is the 2nd int returned in event.data.
              currently I've only dug around enough to ensure that the event paramater class is returned correctly but this is enough for my current needs.
