6 Replies Latest reply on Aug 25, 2015 1:14 AM by Ronald63
    move an indesign document
    aviR Level 1
      Hello All
      Can anyone please tell me How to move an indesign document to  SPECIFIED PATH?
      Is there any direct method?
      Please Please Help
      thanks.
        • 1. Re: move an indesign document
          Ronald63 Level 4
          Hello,
          Use this ...
          var sourcePath = File('~/Desktop/foo_1.indd');
          var targetPath = File('~/Documents/foo_2.indd');
          sourcePath.copy(targetPath);
          Regards
          • 2. Re: move an indesign document
            aviR Level 1
            Hii,
            Thanks for your immediate response. I will try this but through vb.net and get back to you soon.
            • 3. Re: move an indesign document
              aviR Level 1
              hi
              This doesnot move the document. Can u Please tell me any other method?
              Please help.
              Thank You
              • 4. Re: move an indesign document
                Ronald63 Level 4
                Can you post your code ...
                • 5. Re: move an indesign document
                  aviR Level 1
                  Dim idFiles As String = "E:\abcd\file4copy"
                              Directory.CreateDirectory(idFiles)
                              Directory.SetCurrentDirectory(idFiles)
                              For Each GetFiles As String In My.Computer.FileSystem.GetFiles(idFiles, Microsoft.VisualBasic.FileIO.SearchOption.SearchAllSubDirectories, "*.indd")
                                  Try
                                      Dim filename As String = GetFiles.Split("\").Last
                                      My.Computer.FileSystem.CopyFile(GetFiles, unprocessedpath + "\" + filename)
                                  Catch ex As Exception
                                  End Try
                              Next
                  I am using the copy method to copy the file in the target folder. And it's working but then I want to remove or delete the original file but it's not happening.
                  doc.delete() or doc.remove() is not coming. So what can I do now? How to delete the original file? Or is there any method to completely move the file without coping?
                  Please help.
                  • 6. Re: move an indesign document
                    Ronald63 Level 4
                    Another way from http://kasyan.ho.com.ua/snippets/file_folder.html
                    function MoveFile(myFile, myFolder) {
                        if (!myFile instanceof File || !myFolder instanceof Folder || !myFile.exists || !myFolder.exists) return false;
                        var myMovedFile = new File(myFolder.absoluteURI + "/" + myFile.name);
                        if (myMovedFile.exists) return false;
                        if (File.fs == "Windows")  {
                            var myVbScript = 'Set fs = CreateObject("Scripting.FileSystemObject")\r';
                            myVbScript +=  'fs.MoveFile "' + myFile.fsName + '", "' + myFolder.fsName + '\\"';
                            app.doScript(myVbScript, ScriptLanguage.visualBasic);
                        else if (File.fs == "Macintosh") {
                            var myAppleScript =
                            'tell application "Finder"\r' +
                            'move POSIX file "' + myFile.fsName + '"  to POSIX file "' + myFolder.fsName + '" with replacing\r' +
                            'end tell\r'
                            app.doScript(myAppleScript, ScriptLanguage.applescriptLanguage);
                        if (myMovedFile.exists) {
                            return true;
                        else {
                            return false;
