4 Replies Latest reply on Sep 2, 2015 3:43 AM by jfb00
    pass query to oracle
    jfb00 Level 3
      HI All,
      How can I pass a query to oracle using cfstoredprod?
      Try this:
      <cfstoredproc datasource="#application.dsn#" procedure="#importTable#">
        <cfprocparam type="in" cfsqltype="cf_sql_refcursor"  value="#myQuery#">
      Oracle code:
      Procedure importTable ( v_table IN SYS_REFCURSOR) is
      Getting error: [Oracle JDBC Driver]Unable to determine the type of the specified object.
      Any ideas?
      Thanks in advanced.
        • 1. Re: pass query to oracle
          WolfShade Level 4
          Why are you passing a query to a stored procedure?  Stored procedures are great for _running_ queries, but the query should already exist in the stored procedure.  You can pass variables in the cfprocparam for dynamic content.
          • 2. Re: pass query to oracle
            jfb00 Level 3
            Thanks for your reply and help.
            I am trying to do a bulk import of 100K records into Oracle.
            Doing a cfquery with a loop insert takes too long.
            Do you know a better way of doing bulk import?
            • 3. Re: pass query to oracle
              WolfShade Level 4
              Get your records and put them into a query object (if they are not already), call it getRecs, and:
              <cfquery name="bulkInsert" datasource="#application.yourDSN#">
              INSERT ALL
                 <cfoutput query="getRecs">
                    INTO schema.tableName(columnA, columnB, columnC, etc)
                    VALUES (<cfqueryparam value="#getRecs.column1#" />,<cfqueryparam value="#getRecs.column2#" />,<cfqueryparam value="#getRecs.column3#" />,<cfqueryparam value="#getRecs.column4#" />)
                 SELECT * FROM DUAL
              You must include the "SELECT * FROM DUAL" after the output loop.  This will make one connection to your database (Oracle), insert all the rows, and disconnect.  Place it within a CFTRANSACTION tag to make sure they are all inserted, or all rolled back.
              • 4. Re: pass query to oracle
                jfb00 Level 3
                Thanks for you reply and help!
