0 Replies Latest reply on Dec 7, 2006 12:51 PM by palhan
    Saving a file received from client in database
    palhan
      Code:
      <!--- Sets the file source --->
      <cfset rfsfile = "#form.accepted_attachedfile1#">
      <cfset rfsid = "#form.rfsid#">
      <!--- Reads The Files Binary Data --->
      <cffile action="readBinary" file="#rfsfile#" variable="MyVariable">
      <cfset MyBLOB = toBase64(#MyVariable#)>
      <!--- Save the file in database --->
      <cfquery datasource="manpower" username="devegov" password="dev@egov" name="insertfile">
      insert into TBL_RFS_ATTACHEDFILES (RFS_BLOB)
      values (<cfqueryparam value="#MyBLOB#" cfsqltype="cf_sql_blob">)
      </cfquery>
      <cfoutput query="insertfile">
      successfull!!!!!!!!!!!!!!!!!!
      </cfoutput>
      <cflocation url="/rfs_backend/RFS_detail.cfm">
      The table is :
      create table TBL_RFS_ATTACHEDFILES (
      RFS_BLOBID INT generated by default as identity (increment by 1,start with 1) not null,
      RFS_BLOBNAME VARCHAR (50),
      RFS_BLOB BLOB (500000),
      primary key (RFS_BLOBID));
      I am getting the following error in this code.........
      Error casting an object of type to an incompatible type. This usually indicates a programming error in Java, although it could also mean you have tried to use a foreign object in a different way than it was designed.
      The error occurred in C:\CFusionMX7\wwwroot\rfs_backend\RFS_SaveRFSDetails.cfm: line 22
      20 : <cfquery datasource="manpower" username="devegov" password="dev@egov" name="insertfile">
      21 : insert into TBL_RFS_ATTACHEDFILES (RFS_BLOB)
      22 : values (<cfqueryparam value="#MyBLOB#" cfsqltype="cf_sql_blob">)
      23 : </cfquery>
      24 : <cfoutput query="insertfile">
      Please try the following:
      * Check the ColdFusion documentation to verify that you are using the correct syntax.
      * Search the Knowledge Base to find a solution to your problem.
      Browser Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.1) Gecko/20061010 Firefox/2.0
      Remote Address 127.0.0.1
      Referrer http://localhost:8500/rfs_backend/RFS_detail.cfm?rfsid=3008
      Date/Time 07-Dec-06 03:48 PM
      Stack Trace
      at cfRFS_SaveRFSDetails2ecfm555042871.runPage(C:\CFusionMX7\wwwroot\rfs_backend\RFS_SaveRFSD etails.cfm:22)
      java.lang.ClassCastException
      at coldfusion.sql.InParameter.setStatement(InParameter.java:49)
