25 Replies Latest reply on Nov 30, 2015 9:09 AM by m_vargas
    Failed to Register when installing Flash Player
    cwsc94870102
      Hello,
           I am having the following issue.  When trying to install the most current "Flash Player"  I get the following on all 300 Plus of my Windows 7 PCs.
      I have tried the steps for the clean installed and the steps for giving permissions to the correct Keys in the registry and nothing has worked.  I have attached the log files from the latest machine I have encountered the error on.  Can someone please help! I am at my wits end on this.
      Shared Files - Acrobat.com
      Roger Desilets
      Charleston Water System
      Message was edited by: Roger Desilets
        • 2. Re: Failed to Register when installing Flash Player
          cwsc94870102 Level 1
          Hi Maria,
          I have done this already, but tried it again just to make sure, and I got a new error.
          This error and the one above are the 2 errors I am getting on all my computers.  Ever since Flash player 17 was released I have been getting the errors.  Is there a Microsoft update or another piece of software that may be causing this?
          Roger
          • 3. Re: Failed to Register when installing Flash Player
            m_vargas Adobe Employee
            That should be the same error as the other one.  The first screenshot is of the online installer, while the second screenshot is of the standalone/offline installer. Messaging space is limited in the online installer, so the message is shorter.  I can confirm by viewing the updated FlashInstall.log file.
            This error essentially means there is a permissions error in the file system and/or registry and Flash Player is not able to register the OCX component.  Until the permissions are fixed, Flash Player will not be able to register.  The file that we have (reset_fp.cmd) resets permissions on all files/registry entries associated with Flash Player.
            Can you please post a screenshot of the directory that contains SubInACL.exe and the reset_fp.cmd file?
            Maria
            • 4. Re: Failed to Register when installing Flash Player
              Here is the Flash install log:
              =O====== M/18.0.0.232 2015-08-24+20-22-56.926 ========
              0000 [I] 00000010 "C:\Users\SRV-PC~1\AppData\Local\Temp\InstallAX_18_0_0_232.exe" -install -msi
              0001 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
              0002 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
              0003 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
              0004 [W] 00001036 Software\Macromedia\FlashPlayer\SafeVersions/18.0 2
              0005 [I] 00000020 C:\Windows\system32\FlashPlayerCPLApp.cpl
              0006 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
              0007 [I] 00000013
              0008 [I] 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_18_0_0_232_ActiveX.exe
              0009 [I] 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_18_0_0_232_ActiveX.dll
              0010 [I] 00000023 C:\Windows\system32\Macromed\Flash\activex.vch
              0011 [I] 00000019 C:\Windows\system32\FlashPlayerCPLApp.cpl
              0012 [W] 00001024 C:\Windows\system32\FlashPlayerCPLApp.cpl 183
              0013 [W] 00001024 C:\Windows\system32\FlashPlayerApp.exe 183
              0014 [W] 00001032 C:\Windows\system32\Macromed\Flash\Flash32_18_0_0_232.ocx 80070005
              0015 [I] 00000018
              0016 [E] 00001032 C:\Windows\system32\Macromed\Flash\Flash32_18_0_0_232.ocx 80070005
              =X====== M/18.0.0.232 2015-08-24+20-22-58.783 ========
              =O====== M/18.0.0.232 2015-08-24+20-27-04.686 ========
              0004 [I] 00000020 C:\Windows\system32\FlashPlayerCPLApp.cpl
              0005 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
              0006 [W] 00001037 SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\\FlashUtil32_18_0_0_232_ActiveX.exe/ 2
              0007 [I] 00000013
              0015 [I] 00000018
              =X====== M/18.0.0.232 2015-08-24+20-27-06.526 ========
              =O====== M/18.0.0.232 2015-08-24+20-27-34.244 ========
              0000 [I] 00000010 "\\downtown\PCSupport\PCSupport\Flash Player\uninstall_flash_player.exe" -force
              0004 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
              0005 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
              0006 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
              0007 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
              0008 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
              0009 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
              0010 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
              0011 [W] 00001018
              0012 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
              0013 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
              0014 [W] 00001037 Software\Macromedia\FlashPlayerActiveX/ 2
              0015 [W] 00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
              0016 [W] 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
              0017 [W] 00001037 Software\Macromedia\FlashPlayerActiveXReleaseType/ 2
              0018 [W] 00001037 Software\Microsoft\Code Store Database\Distribution Units\{D27CDB6E-AE6D-11CF-96B8-444553540000}/ 2
              0019 [W] 00001021
              0020 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
              0021 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
              0022 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
              0023 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\System.ControlPanel.Category/C:\Windows\system32\FlashPlayerCPLApp.cpl 2
              0024 [W] 00001048
              0025 [I] 00000020 C:\Windows\system32\FlashPlayerCPLApp.cpl
              0026 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
              0027 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
              0028 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
              0029 [W] 00001037 SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\\FlashPlayerApp.exe/ 2
              0030 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\System.ControlPanel.Category/C:\Windows\system32\FlashPlayerCPLApp.cpl 2
              0031 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
              0032 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
              0033 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
              0034 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
              0035 [W] 00001018
              0036 [W] 00001036 SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayer/ 2
              0037 [W] 00001037 SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayer/ 2
              0038 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player NPAPI/ 2
              0039 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player Plugin/ 2
              0040 [W] 00001019
              0041 [W] 00001020
              0042 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
              0043 [W] 00001037 Software\Macromedia\FlashPlayerPlugin/ 2
              0044 [W] 00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
              0045 [W] 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
              0046 [W] 00001037 Software\Macromedia\FlashPlayerPluginReleaseType/ 2
              0047 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player Plugin/ 2
              0048 [W] 00001021
              0049 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
              0050 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
              0051 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
              0052 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\System.ControlPanel.Category/C:\Windows\system32\FlashPlayerCPLApp.cpl 2
              0053 [W] 00001048
              0054 [I] 00000020 C:\Windows\system32\FlashPlayerCPLApp.cpl
              0055 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
              0056 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
              0057 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
              0058 [W] 00001037 SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\\FlashPlayerApp.exe/ 2
              0059 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\System.ControlPanel.Category/C:\Windows\system32\FlashPlayerCPLApp.cpl 2
              0060 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
              0061 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
              0062 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
              0063 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
              0064 [W] 00001018
              0065 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player PPAPI/ 2
              0066 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player Pepper/ 2
              0067 [W] 00001019
              0068 [W] 00001020
              0069 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
              0070 [W] 00001037 Software\Macromedia\FlashPlayerPepper/ 2
              0071 [W] 00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
              0072 [W] 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
              0073 [W] 00001037 Software\Macromedia\FlashPlayerPepperReleaseType/ 2
              0074 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player Pepper/ 2
              0075 [W] 00001021
              0076 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
              0077 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
              0078 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
              0079 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\System.ControlPanel.Category/C:\Windows\system32\FlashPlayerCPLApp.cpl 2
              0080 [W] 00001048
              0081 [I] 00000020 C:\Windows\system32\FlashPlayerCPLApp.cpl
              0082 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
              0083 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
              0084 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
              0085 [W] 00001037 SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\\FlashPlayerApp.exe/ 2
              0086 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\System.ControlPanel.Category/C:\Windows\system32\FlashPlayerCPLApp.cpl 2
              0087 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
              0088 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
              0089 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
              0090 [W] 00001036 Software\Mozilla\Firefox\extensions/Plugins 2
              0091 [W] 00001036 Software\Mozilla\Mozilla Firefox\extensions/Plugins 2
              0092 [W] 00001036 Software\Opera Software/Last CommandLine 2
              0093 [W] 00001036 Software\Opera Software/Last CommandLine 2
              0094 [W] 00001036 Software\Opera Software/Plugin Path 2
              0095 [W] 00001036 Software\Opera Software/Plugin Path 2
              0096 [W] 00001037 SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\\FlashUtil32_18_0_0_232_ActiveX.exe/ 2
              =X====== M/18.0.0.232 2015-08-24+20-27-38.144 ========
              =O====== M/18.0.0.232 2015-08-24+20-30-05.689 ========
              0007 [I] 00000013
              0012 [W] 00001032 C:\Windows\system32\Macromed\Flash\Flash32_18_0_0_232.ocx 80070005
              0013 [I] 00000018
              0014 [E] 00001032 C:\Windows\system32\Macromed\Flash\Flash32_18_0_0_232.ocx 80070005
              =X====== M/18.0.0.232 2015-08-24+20-30-07.263 ========
              =O====== M/18.0.0.203 2015-08-25+13-26-47.143 ========
              0000 [I] 00000010 "\\downtown\PCSupport\PCSupport\Flash Player\Flash Player 18\flashplayer_18_ax_debug.exe"
              0004 [E] 00001013
              =X====== M/18.0.0.203 2015-08-25+13-26-54.175 ========
              =O====== M/13.0.0.309 2015-08-25+13-28-13.841 ========
              0000 [I] 00000010 "C:\Users\srv-pcsuppt\Downloads\install_flash_player_13_active_x.exe"
              0001 [E] 00001013
              =X====== M/13.0.0.309 2015-08-25+13-28-20.795 ========
              =O====== M/18.0.0.232 2015-08-25+13-28-31.608 ========
              0004 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
              0005 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
              0006 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
              0007 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
              0008 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
              0009 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
              0010 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
              0011 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
              0012 [W] 00001018
              0013 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
              0014 [W] 00001015 C:\Windows\system32\Macromed\Flash\Flash32_18_0_0_232.ocx 5
              0015 [I] 00000018
              0016 [W] 00001015 C:\Windows\system32\Macromed\Flash\Flash32_18_0_0_232.ocx 5
              0017 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
              0018 [W] 00001037 Software\Macromedia\FlashPlayerActiveX/ 2
              0019 [W] 00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
              0020 [W] 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
              0021 [W] 00001037 Software\Macromedia\FlashPlayerActiveXReleaseType/ 2
              0022 [W] 00001037 Software\Microsoft\Code Store Database\Distribution Units\{D27CDB6E-AE6D-11CF-96B8-444553540000}/ 2
              0023 [W] 00001021
              0024 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
              0025 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
              0026 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
              0027 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\System.ControlPanel.Category/C:\Windows\system32\FlashPlayerCPLApp.cpl 2
              0028 [W] 00001048
              0029 [I] 00000020 C:\Windows\system32\FlashPlayerCPLApp.cpl
              0030 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
              0031 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
              0032 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
              0033 [W] 00001037 SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\\FlashPlayerApp.exe/ 2
              0034 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\System.ControlPanel.Category/C:\Windows\system32\FlashPlayerCPLApp.cpl 2
              0035 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
              0036 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
              0037 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
              0038 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
              0039 [W] 00001018
              0040 [W] 00001036 SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayer/ 2
              0041 [W] 00001037 SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayer/ 2
              0042 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player NPAPI/ 2
              0043 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player Plugin/ 2
              0044 [W] 00001019
              0045 [W] 00001020
              0046 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
              0047 [W] 00001037 Software\Macromedia\FlashPlayerPlugin/ 2
              0048 [W] 00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
              0049 [W] 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
              0050 [W] 00001037 Software\Macromedia\FlashPlayerPluginReleaseType/ 2
              0051 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player Plugin/ 2
              0052 [W] 00001021
              0053 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
              0054 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
              0055 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
              0056 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\System.ControlPanel.Category/C:\Windows\system32\FlashPlayerCPLApp.cpl 2
              0057 [W] 00001048
              0058 [I] 00000020 C:\Windows\system32\FlashPlayerCPLApp.cpl
              0059 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
              0060 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
              0061 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
              0062 [W] 00001037 SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\\FlashPlayerApp.exe/ 2
              0063 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\System.ControlPanel.Category/C:\Windows\system32\FlashPlayerCPLApp.cpl 2
              0064 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
              0065 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
              0066 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
              0067 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
              0068 [W] 00001018
              0069 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player PPAPI/ 2
              0070 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player Pepper/ 2
              0071 [W] 00001019
              0072 [W] 00001020
              0073 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
              0074 [W] 00001037 Software\Macromedia\FlashPlayerPepper/ 2
              0075 [W] 00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
              0076 [W] 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
              0077 [W] 00001037 Software\Macromedia\FlashPlayerPepperReleaseType/ 2
              0078 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player Pepper/ 2
              0079 [W] 00001021
              0080 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
              0081 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
              0082 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
              0083 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\System.ControlPanel.Category/C:\Windows\system32\FlashPlayerCPLApp.cpl 2
              0084 [W] 00001048
              0085 [I] 00000020 C:\Windows\system32\FlashPlayerCPLApp.cpl
              0086 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
              0087 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
              0088 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
              0089 [W] 00001037 SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\\FlashPlayerApp.exe/ 2
              0090 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\System.ControlPanel.Category/C:\Windows\system32\FlashPlayerCPLApp.cpl 2
              0091 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
              0092 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
              0093 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
              0094 [W] 00001036 Software\Mozilla\Firefox\extensions/Plugins 2
              0095 [W] 00001036 Software\Mozilla\Mozilla Firefox\extensions/Plugins 2
              0096 [W] 00001036 Software\Opera Software/Last CommandLine 2
              0097 [W] 00001036 Software\Opera Software/Last CommandLine 2
              0098 [W] 00001036 Software\Opera Software/Plugin Path 2
              0099 [W] 00001036 Software\Opera Software/Plugin Path 2
              0100 [W] 00001015 C:\Windows\system32\Macromed\Flash\Flash32_18_0_0_232.ocx 5
              0101 [I] 00000018
              0102 [W] 00001015 C:\Windows\system32\Macromed\Flash\Flash32_18_0_0_232.ocx 5
              0103 [W] 00001037 SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\\FlashUtil32_18_0_0_232_ActiveX.exe/ 2
              =X====== M/18.0.0.232 2015-08-25+13-28-37.163 ========
              =O====== M/13.0.0.309 2015-08-25+13-28-51.367 ========
              0000 [I] 00000010 "C:\Windows\system32\Macromed\Flash\FlashUtil32_13_0_0_309_ActiveX.exe" -refreshIEElevationPolicies
              =X====== M/13.0.0.309 2015-08-25+13-28-51.398 ========
              =O====== M/13.0.0.309 2015-08-25+13-28-51.352 ========
              =O====== M/13.0.0.309 2015-08-25+13-28-46.575 ========
              0001 [W] 00001036 Software\Macromedia\FlashPlayer\SafeVersions/13.0 2
              0003 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
              0004 [W] 00001036 Software\Macromedia\FlashPlayer\SafeVersions/13.0 2
              0007 [I] 00000020 C:\Windows\system32\FlashPlayerCPLApp.cpl
              0008 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
              0009 [W] 00001015 C:\Windows\system32\Macromed\Flash\Flash32_18_0_0_232.ocx 5
              0010 [I] 00000018
              0011 [W] 00001015 C:\Windows\system32\Macromed\Flash\Flash32_18_0_0_232.ocx 5
              0012 [I] 00000013 C:\Windows\system32\Macromed\Flash\Flash32_13_0_0_309.ocx
              0013 [I] 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_13_0_0_309_ActiveX.exe
              0014 [I] 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_13_0_0_309_ActiveX.dll
              0015 [I] 00000023 C:\Windows\system32\Macromed\Flash\activex.vch
              0016 [I] 00000019 C:\Windows\system32\FlashPlayerCPLApp.cpl
              0017 [W] 00001032 C:\Windows\system32\Macromed\Flash\Flash32_13_0_0_309.ocx 80070005
              0018 [I] 00000018
              0019 [E] 00001032 C:\Windows\system32\Macromed\Flash\Flash32_13_0_0_309.ocx 80070005
              0020 [I] 00000021 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe
              =X====== M/13.0.0.309 2015-08-25+13-33-09.330 ========
              And here is the screen shot of the file location you asked for.
              I will restart with the clean install method and then try the install using the offline installed and then try the reset_fp method if I get an error.  I will let you know if that works,
              Roger
              • 5. Re: Failed to Register when installing Flash Player
                Maria,
                     For good measure I copied the reset_rp Dos info:
                SOFTWARE\Classes\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\MiscStatus : new a
                ce for builtin\users
                HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}
                \MiscStatus : 2 change(s)
                SOFTWARE\Classes\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\MiscStatus\1 : del
                ete Perm. ACE 0 builtin\users
                SOFTWARE\Classes\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\MiscStatus\1 : new
                ace for builtin\users
                \MiscStatus\1 : 2 change(s)
                SOFTWARE\Classes\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\ProgID : delete Pe
                SOFTWARE\Classes\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\ProgID : new ace f
                or builtin\users
                \ProgID : 2 change(s)
                SOFTWARE\Classes\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\Programmable : del
                SOFTWARE\Classes\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\Programmable : new
                \Programmable : 2 change(s)
                SOFTWARE\Classes\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\ToolboxBitmap32 :
                delete Perm. ACE 0 builtin\users
                new ace for builtin\users
                \ToolboxBitmap32 : 2 change(s)
                SOFTWARE\Classes\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\TypeLib : delete P
                SOFTWARE\Classes\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\TypeLib : new ace
                for builtin\users
                \TypeLib : 2 change(s)
                SOFTWARE\Classes\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\Version : delete P
                SOFTWARE\Classes\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\Version : new ace
                for builtin\users
                \Version : 2 change(s)
                SOFTWARE\Classes\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\VersionIndependent
                ProgID : delete Perm. ACE 0 builtin\users
                ProgID : new ace for builtin\users
                \VersionIndependentProgID : 2 change(s)
                Elapsed Time: 00 00:00:00
                Done:       20, Modified       20, Failed        0, Syntax errors        0
                Last Done  : HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{D27CDB6E-AE6D-11cf-96B8-
                444553540000}\VersionIndependentProgID
                HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Classes\CLSID\{D27CDB6E-AE6D-11cf-96B8-4
                44553540000} : 2 The system cannot find the file specified.
                Done:        1, Modified        0, Failed        1, Syntax errors        0
                Last Done  : HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Classes\CLSID\{D27CDB6E-AE6
                Last Failed: HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Classes\CLSID\{D27CDB6E-AE6
                D-11cf-96B8-444553540000} : 2 The system cannot find the file specified.
                Repairing Flash Player File System Permissions. One moment please...
                C:\Windows\System32\Macromed : delete Perm. ACE 11 builtin\administrators
                C:\Windows\System32\Macromed : delete Perm. ACE 10 builtin\administrators
                C:\Windows\System32\Macromed : delete Perm. ACE 1 builtin\administrators
                C:\Windows\System32\Macromed : delete Perm. ACE 0 builtin\administrators
                C:\Windows\System32\Macromed : new ace for builtin\administrators
                C:\Windows\System32\Macromed : 6 change(s)
                Done:        1, Modified        1, Failed        0, Syntax errors        0
                Last Done  : C:\Windows\System32\Macromed
                C:\Windows\System32\Macromed\Flash : delete Perm. ACE 9 builtin\administrators
                C:\Windows\System32\Macromed\Flash : delete Perm. ACE 1 builtin\administrators
                C:\Windows\System32\Macromed\Flash : delete Perm. ACE 0 builtin\administrators
                C:\Windows\System32\Macromed\Flash : new ace for builtin\administrators
                C:\Windows\System32\Macromed\Flash : 5 change(s)
                C:\Windows\System32\Macromed\Flash\activex.vch : delete Perm. ACE 0 builtin\admi
                nistrators
                C:\Windows\System32\Macromed\Flash\activex.vch : new ace for builtin\administrat
                ors
                C:\Windows\System32\Macromed\Flash\activex.vch : 2 change(s)
                C:\Windows\System32\Macromed\Flash\Flash32_18_0_0_203.ocx : delete Perm. ACE 0 b
                C:\Windows\System32\Macromed\Flash\Flash32_18_0_0_203.ocx : new ace for builtin\
                administrators
                C:\Windows\System32\Macromed\Flash\Flash32_18_0_0_203.ocx : 2 change(s)
                C:\Windows\System32\Macromed\Flash\FlashInstall.log : delete Perm. ACE 0 builtin
                \administrators
                C:\Windows\System32\Macromed\Flash\FlashInstall.log : new ace for builtin\admini
                strators
                C:\Windows\System32\Macromed\Flash\FlashInstall.log : 2 change(s)
                C:\Windows\System32\Macromed\Flash\FlashUtil32_18_0_0_203_ActiveX.dll : delete P
                C:\Windows\System32\Macromed\Flash\FlashUtil32_18_0_0_203_ActiveX.dll : new ace
                C:\Windows\System32\Macromed\Flash\FlashUtil32_18_0_0_203_ActiveX.dll : 2 change
                (s)
                C:\Windows\System32\Macromed\Flash\FlashUtil32_18_0_0_203_ActiveX.exe : delete P
                C:\Windows\System32\Macromed\Flash\FlashUtil32_18_0_0_203_ActiveX.exe : new ace
                C:\Windows\System32\Macromed\Flash\FlashUtil32_18_0_0_203_ActiveX.exe : 2 change
                (s)
                Done:        6, Modified        6, Failed        0, Syntax errors        0
                Last Done  : C:\Windows\System32\Macromed\Flash\FlashUtil32_18_0_0_203_ActiveX.e
                xe
                C:\Windows\System32\Macromed : delete Perm. ACE 11 builtin\users
                C:\Windows\System32\Macromed : delete Perm. ACE 10 builtin\users
                C:\Windows\System32\Macromed : delete Perm. ACE 3 builtin\users
                C:\Windows\System32\Macromed : delete Perm. ACE 2 builtin\users
                C:\Windows\System32\Macromed : new ace for builtin\users
                C:\Windows\System32\Macromed\Flash : delete Perm. ACE 9 builtin\users
                C:\Windows\System32\Macromed\Flash : delete Perm. ACE 5 builtin\users
                C:\Windows\System32\Macromed\Flash : delete Perm. ACE 4 builtin\users
                C:\Windows\System32\Macromed\Flash : new ace for builtin\users
                C:\Windows\System32\Macromed\Flash\activex.vch : delete Perm. ACE 2 builtin\user
                s
                C:\Windows\System32\Macromed\Flash\activex.vch : new ace for builtin\users
                C:\Windows\System32\Macromed\Flash\Flash32_18_0_0_203.ocx : delete Perm. ACE 2 b
                uiltin\users
                users
                C:\Windows\System32\Macromed\Flash\FlashInstall.log : delete Perm. ACE 2 builtin
                \users
                C:\Windows\System32\Macromed\Flash\FlashInstall.log : new ace for builtin\users
                for builtin\users
                (s)
                for builtin\users
                (s)
                xe
                C:\Windows\System32\Macromed : delete Perm. ACE 9 nt authority\system
                C:\Windows\System32\Macromed : delete Perm. ACE 8 nt authority\system
                C:\Windows\System32\Macromed : delete Perm. ACE 1 nt authority\system
                C:\Windows\System32\Macromed : delete Perm. ACE 0 nt authority\system
                C:\Windows\System32\Macromed : new ace for nt authority\system
                C:\Windows\System32\Macromed\Flash : delete Perm. ACE 8 nt authority\system
                C:\Windows\System32\Macromed\Flash : delete Perm. ACE 5 nt authority\system
                C:\Windows\System32\Macromed\Flash : delete Perm. ACE 4 nt authority\system
                C:\Windows\System32\Macromed\Flash : new ace for nt authority\system
                C:\Windows\System32\Macromed\Flash\activex.vch : delete Perm. ACE 2 nt authority
                \system
                C:\Windows\System32\Macromed\Flash\activex.vch : new ace for nt authority\system
                C:\Windows\System32\Macromed\Flash\Flash32_18_0_0_203.ocx : delete Perm. ACE 2 n
                t authority\system
                C:\Windows\System32\Macromed\Flash\Flash32_18_0_0_203.ocx : new ace for nt autho
                rity\system
                C:\Windows\System32\Macromed\Flash\FlashInstall.log : delete Perm. ACE 2 nt auth
                ority\system
                C:\Windows\System32\Macromed\Flash\FlashInstall.log : new ace for nt authority\s
                ystem
                erm. ACE 2 nt authority\system
                (s)
                (s)
                xe
                C:\Windows\System32\Macromed : 4 change(s)
                C:\Windows\System32\Macromed\Flash : delete Perm. ACE 3 builtin\users
                C:\Windows\System32\Macromed\Flash : delete Perm. ACE 2 builtin\users
                C:\Windows\System32\Macromed\Flash : 4 change(s)
                C:\Windows\System32\Macromed\Flash\activex.vch : delete Perm. ACE 1 builtin\user
                s
                C:\Windows\System32\Macromed\Flash\Flash32_18_0_0_203.ocx : delete Perm. ACE 1 b
                uiltin\users
                users
                C:\Windows\System32\Macromed\Flash\FlashInstall.log : delete Perm. ACE 1 builtin
                \users
                erm. ACE 1 builtin\users
                for builtin\users
                (s)
                for builtin\users
                (s)
                xe
                Done:        0, Modified        0, Failed        0, Syntax errors        0
                Finished.
                Press any key to continue . . .
                I am now rebooting as instructed in the directions. After reboot I install Flash player again and receive the same 2nd error message.
                Roger
                • 6. Re: Failed to Register when installing Flash Player
                  Hi Roger,
                  I am seeing some failures in the output you posted.  I've prepared a file, reset_fp_debug.cmd (uploaded at Shared Files - Acrobat.com) that will display the result of each command executed.  Please run this file and post the output as you did in your previous post. Hopefully the results will enable us to troubleshoot the failures.
                  Maria
                  • 7. Re: Failed to Register when installing Flash Player
                    Here you go:
                    @echo off
                    @setlocal enableextensions
                    @cd /d "%~dp0"
                    Echo =========================
                    Echo Repairing Flash Player HKEY_CLASSES_ROOT Registry Permissions. One moment please...
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\CLSID\{D4304BCF-B8E9-4B35-BEA0-DC5B522670C2} /grant=administrators=f
                    echo ERRORLEVEL = %ERRORLEVEL%
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Classes\CLSID\{D4304BCF-B8E9-4B35-BEA0-DC5B522670 C2} /grant=administrators=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000} /grant=administrators=f
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Classes\CLSID\{D27CDB6E-AE6D-11cf-96B8-4445535400 00} /grant=administrators=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\CLSID\{1171A62F-05D2-11D1-83FC-00A0C9089C5A} /grant=administrators=f
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Classes\CLSID\{1171A62F-05D2-11D1-83FC-00A0C9089C 5A} /grant=administrators=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\Interface\{2E4BB6BE-A75F-4DC0-9500-68203655A2C4} /grant=administrators=f
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Classes\Interface\{2E4BB6BE-A75F-4DC0-9500-682036 55A2C4} /grant=administrators=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\TypeLib\{FAB3E735-69C7-453B-A446-B6823C6DF1C9} /grant=administrators=f
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Classes\TypeLib\{FAB3E735-69C7-453B-A446-B6823C6D F1C9} /grant=administrators=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\TypeLib\{57A0E746-3863-4D20-A811-950C84F1DB9B} /grant=administrators=f
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Classes\TypeLib\{57A0E746-3863-4D20-A811-950C84F1 DB9B} /grant=administrators=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\.spl /grant=administrators=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\.swf /grant=administrators=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\.mfp /grant=administrators=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\.sol /grant=administrators=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\.sor /grant=administrators=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\FlashFactory.FlashFactory /grant=administrators=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\FlashFactory.FlashFactory.1 /grant=administrators=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\FlashProp.FlashProp /grant=administrators=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\FlashProp.FlashProp.1 /grant=administrators=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash /grant=administrators=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.1 /grant=administrators=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.3 /grant=administrators=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.4 /grant=administrators=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.5 /grant=administrators=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.6 /grant=administrators=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.7 /grant=administrators=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.8 /grant=administrators=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.9 /grant=administrators=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.10 /grant=administrators=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.11 /grant=administrators=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.12 /grant=administrators=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.13 /grant=administrators=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.14 /grant=administrators=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.15 /grant=administrators=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.16 /grant=administrators=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.17 /grant=administrators=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.18 /grant=administrators=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.19 /grant=administrators=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.20 /grant=administrators=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\MacromediaFlashPaper.MacromediaFlashPaper  /grant=administrators=f
                    subinacl /subkeyreg "HKEY_CLASSES_ROOT\MIME\Database\Content Type\application/futuresplash"  /grant=administrators=f
                    subinacl /subkeyreg "HKEY_CLASSES_ROOT\MIME\Database\Content Type\application/x-shockwave-flash"  /grant=administrators=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\CLSID\{D4304BCF-B8E9-4B35-BEA0-DC5B522670C2} /grant=system=f
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Classes\CLSID\{D4304BCF-B8E9-4B35-BEA0-DC5B522670 C2} /grant=system=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000} /grant=system=f
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Classes\CLSID\{D27CDB6E-AE6D-11cf-96B8-4445535400 00} /grant=system=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\CLSID\{1171A62F-05D2-11D1-83FC-00A0C9089C5A} /grant=system=f
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Classes\CLSID\{1171A62F-05D2-11D1-83FC-00A0C9089C 5A} /grant=system=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\Interface\{2E4BB6BE-A75F-4DC0-9500-68203655A2C4} /grant=system=f
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Classes\Interface\{2E4BB6BE-A75F-4DC0-9500-682036 55A2C4} /grant=system=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\TypeLib\{FAB3E735-69C7-453B-A446-B6823C6DF1C9} /grant=system=f
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Classes\TypeLib\{FAB3E735-69C7-453B-A446-B6823C6D F1C9} /grant=system=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\TypeLib\{57A0E746-3863-4D20-A811-950C84F1DB9B} /grant=system=f
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Classes\TypeLib\{57A0E746-3863-4D20-A811-950C84F1 DB9B} /grant=system=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\.spl /grant=system=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\.swf /grant=system=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\.mfp /grant=system=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\.sol /grant=system=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\.sor /grant=system=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\FlashFactory.FlashFactory /grant=system=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\FlashFactory.FlashFactory.1 /grant=system=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\FlashProp.FlashProp /grant=system=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\FlashProp.FlashProp.1 /grant=system=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash /grant=system=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.1 /grant=system=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.3 /grant=system=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.4 /grant=system=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.5 /grant=system=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.6 /grant=system=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.7 /grant=system=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.8 /grant=system=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.9 /grant=system=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.10 /grant=system=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.11 /grant=system=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.12 /grant=system=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.13 /grant=system=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.14 /grant=system=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.15 /grant=system=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.16 /grant=system=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.17 /grant=system=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.18 /grant=system=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\MacromediaFlashPaper.MacromediaFlashPaper  /grant=system=f
                    subinacl /subkeyreg "HKEY_CLASSES_ROOT\MIME\Database\Content Type\application/futuresplash"  /grant=system=f
                    subinacl /subkeyreg "HKEY_CLASSES_ROOT\MIME\Database\Content Type\application/x-shockwave-flash"  /grant=system=f
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\CLSID\{D4304BCF-B8E9-4B35-BEA0-DC5B522670C2} /grant=users=r
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Classes\CLSID\{D4304BCF-B8E9-4B35-BEA0-DC5B522670 C2} /grant=users=r
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000} /grant=users=r
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Classes\CLSID\{D27CDB6E-AE6D-11cf-96B8-4445535400 00} /grant=users=r
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\CLSID\{1171A62F-05D2-11D1-83FC-00A0C9089C5A} /grant=users=r
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Classes\CLSID\{1171A62F-05D2-11D1-83FC-00A0C9089C 5A} /grant=users=r
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\Interface\{2E4BB6BE-A75F-4DC0-9500-68203655A2C4} /grant=users=r
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Classes\Interface\{2E4BB6BE-A75F-4DC0-9500-682036 55A2C4} /grant=users=r
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\TypeLib\{FAB3E735-69C7-453B-A446-B6823C6DF1C9} /grant=users=r
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Classes\TypeLib\{FAB3E735-69C7-453B-A446-B6823C6D F1C9} /grant=users=r
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\TypeLib\{57A0E746-3863-4D20-A811-950C84F1DB9B} /grant=users=r
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Classes\TypeLib\{57A0E746-3863-4D20-A811-950C84F1 DB9B} /grant=users=r
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\.spl /grant=users=r
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\.swf /grant=users=r
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\.mfp /grant=users=r
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\.sol /grant=users=r
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\.sor /grant=users=r
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\FlashFactory.FlashFactory /grant=users=r
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\FlashFactory.FlashFactory.1 /grant=users=r
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\FlashProp.FlashProp /grant=users=r
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\FlashProp.FlashProp.1 /grant=users=r
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash /grant=users=r
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.1 /grant=users=r
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.3 /grant=users=r
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.4 /grant=users=r
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.5 /grant=users=r
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.6 /grant=users=r
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.7 /grant=users=r
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.8 /grant=users=r
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.9 /grant=users=r
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.10 /grant=users=r
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.11 /grant=users=r
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.12 /grant=users=r
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.13 /grant=users=r
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.14 /grant=users=r
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.15 /grant=users=r
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.16 /grant=users=r
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.17 /grant=users=r
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.18 /grant=users=r
                    subinacl /subkeyreg HKEY_CLASSES_ROOT\MacromediaFlashPaper.MacromediaFlashPaper  /grant=users=r
                    subinacl /subkeyreg "HKEY_CLASSES_ROOT\MIME\Database\Content Type\application/futuresplash"  /grant=users=r
                    subinacl /subkeyreg "HKEY_CLASSES_ROOT\MIME\Database\Content Type\application/x-shockwave-flash"  /grant=users=r
                    Echo Repairing Flash Player HKEY_LOCAL_MACHINE Registry Permissions. One moment please...
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash /grant=administrators=f
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.1 /grant=administrators=f
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.3 /grant=administrators=f
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.4 /grant=administrators=f
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.5 /grant=administrators=f
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.6 /grant=administrators=f
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.7 /grant=administrators=f
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.8 /grant=administrators=f
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.9 /grant=administrators=f
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.10 /grant=administrators=f
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.11 /grant=administrators=f
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.12 /grant=administrators=f
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.13 /grant=administrators=f
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.14 /grant=administrators=f
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.15 /grant=administrators=f
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.16 /grant=administrators=f
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.17 /grant=administrators=f
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.18 /grant=administrators=f
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000} /grant=administrators=f
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash /grant=system=f
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.1 /grant=system=f
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.3 /grant=system=f
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.4 /grant=system=f
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.5 /grant=system=f
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.6 /grant=system=f
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.7 /grant=system=f
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.8 /grant=system=f
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.9 /grant=system=f
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.10 /grant=system=f
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.11 /grant=system=f
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.12 /grant=system=f
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.13 /grant=system=f
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.14 /grant=system=f
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.15 /grant=system=f
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.16 /grant=system=f
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.17 /grant=system=f
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.18 /grant=system=f
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000} /grant=system=f
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash /grant=users=r
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.1 /grant=users=r
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.3 /grant=users=r
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.4 /grant=users=r
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.5 /grant=users=r
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.6 /grant=users=r
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.7 /grant=users=r
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.8 /grant=users=r
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.9 /grant=users=r
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.10 /grant=users=r
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.11 /grant=users=r
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.12 /grant=users=r
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.13 /grant=users=r
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.14 /grant=users=r
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.15 /grant=users=r
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.16 /grant=users=r
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.17 /grant=users=r
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.18 /grant=users=r
                    subinacl /subkeyreg HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000} /grant=users=r
                    Echo Repairing Flash Player File System Permissions. One moment please...
                    subinacl /subdirectories %WINDIR%\System32\Macromed /grant=administrators=f
                    subinacl /subdirectories %WINDIR%\System32\Macromed\* /grant=administrators=f
                    subinacl /subdirectories %WINDIR%\System32\Macromed /grant=users=r
                    subinacl /subdirectories %WINDIR%\System32\Macromed\* /grant=users=r
                    subinacl /subdirectories %WINDIR%\System32\Macromed /grant=system=f
                    subinacl /subdirectories %WINDIR%\System32\Macromed\* /grant=system=f
                    subinacl /subdirectories %WINDIR%\SysWow64\Macromed /grant=administrators=f
                    subinacl /subdirectories %WINDIR%\SysWow64\Macromed\* /grant=administrators=f
                    subinacl /subdirectories %WINDIR%\SysWow64\Macromed /grant=users=r
                    subinacl /subdirectories %WINDIR%\SysWow64\Macromed\* /grant=users=r
                    subinacl /subdirectories %WINDIR%\SysWow64\Macromed /grant=system=f
                    subinacl /subdirectories %WINDIR%\SysWow64\Macromed\* /grant=system=f
                    Echo Finished.
                    pause
                    exit
                    • 8. Re: Failed to Register when installing Flash Player
                      Hi Roger,
                      Something didn't go right.  Instead of seeing echo ERRORLEVEL = %ERRORLEVEL% it should be ERRORLEVEL = 0 (or some other number if there is an error).  From a previous screenshot it appears you may be running SubInACL from a network location.  Is that correct?  If so, I'm wondering if it could be the reason for the behaviour we're observing.  I'm used to running SubInACL with it installed locally, not on a network share.  Can you please try installing it locally on a system and running it that way?  Also, are  you right-clicking on the batch file and selecting 'Run as Administrator' or are you opening the command-prompt window (as Administrator) and running the script that way?
                      Maria
                      • 9. Re: Failed to Register when installing Flash Player
                        Maria,
                             I did run the SubInACL locally not from a network location (The screen shot was a mapped drive from my PC to the one in question just for the screen shot only), and I am right clicking on the file you sent and running as admin.
                        Roger
                        • 11. Re: Failed to Register when installing Flash Player
                          Maria,
                               I realized that I did not run the reset_debug program from my local computer.  So here is the updated debug info.
                          for builtin\users
                          for builtin\users
                          ERRORLEVEL = 0
                          ERRORLEVEL = 0
                          ERRORLEVEL = 0
                          C:\Windows\System32\Macromed\Flash : delete Perm. ACE 15 builtin\administrators
                          C:\Windows\System32\Macromed\Flash : delete Perm. ACE 7 builtin\administrators
                          C:\Windows\System32\Macromed\Flash : delete Perm. ACE 6 builtin\administrators
                          C:\Windows\System32\Macromed\Flash : 7 change(s)
                          nistrators
                          ors
                          administrators
                          C:\Windows\System32\Macromed\Flash\FlashInstall.log : delete Perm. ACE 3 builtin
                          \administrators
                          \administrators
                          strators
                          C:\Windows\System32\Macromed\Flash\FlashInstall.log : 3 change(s)
                          (s)
                          (s)
                          xe
                          ERRORLEVEL = 0
                          ERRORLEVEL = 0
                          C:\Windows\System32\Macromed\Flash : delete Perm. ACE 13 builtin\users
                          C:\Windows\System32\Macromed\Flash : delete Perm. ACE 8 builtin\users
                          s
                          uiltin\users
                          users
                          C:\Windows\System32\Macromed\Flash\FlashInstall.log : delete Perm. ACE 4 builtin
                          \users
                          \users
                          for builtin\users
                          (s)
                          for builtin\users
                          (s)
                          xe
                          ERRORLEVEL = 0
                          ERRORLEVEL = 0
                          C:\Windows\System32\Macromed\Flash : delete Perm. ACE 10 nt authority\system
                          C:\Windows\System32\Macromed\Flash : delete Perm. ACE 7 nt authority\system
                          C:\Windows\System32\Macromed\Flash : delete Perm. ACE 6 nt authority\system
                          C:\Windows\System32\Macromed\Flash : delete Perm. ACE 1 nt authority\system
                          C:\Windows\System32\Macromed\Flash : delete Perm. ACE 0 nt authority\system
                          \system
                          t authority\system
                          rity\system
                          C:\Windows\System32\Macromed\Flash\FlashInstall.log : delete Perm. ACE 3 nt auth
                          ority\system
                          C:\Windows\System32\Macromed\Flash\FlashInstall.log : delete Perm. ACE 0 nt auth
                          ority\system
                          ystem
                          (s)
                          (s)
                          xe
                          ERRORLEVEL = 0
                          ERRORLEVEL = 0
                          s
                          uiltin\users
                          users
                          \users
                          for builtin\users
                          (s)
                          for builtin\users
                          (s)
                          xe
                          ERRORLEVEL = 0
                          ERRORLEVEL = 0
                          ERRORLEVEL = 0
                          ERRORLEVEL = 0
                          ERRORLEVEL = 0
                          ERRORLEVEL = 0
                          ERRORLEVEL = 0
                          ERRORLEVEL = 0
                          ERRORLEVEL = 0
                          Finished.
                          Roger Desilets
                          • 12. Re: Failed to Register when installing Flash Player
                            PWillener,
                                 I Ran the MSI before and got the error: Error 1722. There is an error with this Windows Installer Package
                            Roger
                            • 13. Re: Failed to Register when installing Flash Player
                              Hi Roger,
                              Error 1722 in an MSI is a generic error. The true error will be in the MSI install log file and the FlashInstall.log file, which based on the log file you posted previously is the 'Failed to Register' error.
                              Please post screenshots of the following:
                              • C:\Windows\system32\Macromed\Flash\ directory
                              • The value of the HKEY_CLASSES_ROOT\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\InprocServer32 registry entry
                              Thank you.
                              Maria
                              • 14. Re: Failed to Register when installing Flash Player
                                Maria,
                                Here are the screenshots you asked for.
                                There are 2 entries for the registry key.
                                Here is the install log just in case you need it.
                                =O====== M/18.0.0.203 2015-08-25+17-12-12.857 ========
                                0000 [W] 00001113 C:\Windows\system32\Macromed\Flash\\* 3
                                0001 [I] 00000010 "\\downtown\PCSupport\PCSupport\Flash Player\Flash Player 18\flashplayer_18_ax_debug.exe"
                                0002 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                                0004 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                                0005 [W] 00001036 Software\Macromedia\FlashPlayer\SafeVersions/18.0 2
                                0006 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
                                0007 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                                0008 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                                0009 [W] 00001036 Software\Macromedia\FlashPlayer\SafeVersions/18.0 2
                                0010 [I] 00000020 C:\Windows\system32\FlashPlayerCPLApp.cpl
                                0011 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
                                0012 [I] 00000013
                                0013 [I] 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_18_0_0_203_ActiveX.exe
                                0014 [I] 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_18_0_0_203_ActiveX.dll
                                0017 [W] 00001032 C:\Windows\system32\Macromed\Flash\Flash32_18_0_0_203.ocx 80070005
                                0018 [I] 00000018
                                0019 [E] 00001032 C:\Windows\system32\Macromed\Flash\Flash32_18_0_0_203.ocx 80070005
                                =X====== M/18.0.0.203 2015-08-25+17-12-32.934 ========
                                =O====== M/18.0.0.203 2015-08-25+17-17-35.087 ========
                                0000 [I] 00000010 "\\downtown\pcsupport\PCSupport\Flash Player\Flash Player 18\flashplayer_18_ax_debug.exe"
                                0009 [W] 00001037 SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\\FlashUtil32_18_0_0_203_ActiveX.exe/ 2
                                0010 [I] 00000013
                                0011 [I] 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_18_0_0_203_ActiveX.exe
                                0012 [I] 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_18_0_0_203_ActiveX.dll
                                0013 [I] 00000023 C:\Windows\system32\Macromed\Flash\activex.vch
                                0014 [I] 00000019 C:\Windows\system32\FlashPlayerCPLApp.cpl
                                0015 [W] 00001024 C:\Windows\system32\FlashPlayerCPLApp.cpl 183
                                0016 [W] 00001024 C:\Windows\system32\FlashPlayerApp.exe 183
                                0018 [I] 00000018
                                =X====== M/18.0.0.203 2015-08-25+17-19-02.716 ========
                                Roger
                                m_vargas wrote:
                                Hi Roger,
                                Thank you.
                                Maria
                                • 15. Re: Failed to Register when installing Flash Player
                                  I need the actual value for HKEY_CLASSES_ROOT\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\InprocServer32, similar to the following:
                                  I also would like to get a screenshot of the Security tab for the C:\Windows\SysWOW64\Macromed\Flash file (right-click, select Properties > Security), similar to:
                                  I'm thinking it might be a good idea to perform a screenshare session with you so that we can take a look at various items on the system.  Would you be willing/available to do this?
                                  Maria
                                  • 16. Re: Failed to Register when installing Flash Player
                                    Yes, lets do the screen share session.  I am available now.
                                    • 17. Re: Failed to Register when installing Flash Player
                                      m_vargas
                                      Maria,
                                           I ran the SubInacl and created the new reset.cmd and rebooted.  I then tried the Flash player installer you downloaded to my desktop and received the same error message.
                                      Roger
                                      • 18. Re: Failed to Register when installing Flash Player
                                        Hi Roger,
                                        Thank you for the update.  The installer engineer is still going through the Process Monitor log file.
                                        Maria
                                        • 19. Re: Failed to Register when installing Flash Player
                                          Hi Roger,
                                          The installer engineer identified several registry entries we'd like to get permission information on.  Are you available for a quick screen-share?  Shouldn't take very long.
                                          Maria
                                          • 21. Re: Failed to Register when installing Flash Player
                                            cwsc94870102 wrote:
                                            Yes
                                            Sorry, I waited as long as I could.  Maybe we can pick this backup next week.
                                            • 22. Re: Failed to Register when installing Flash Player
                                              Hi Roger,
                                              Sorry, not sure what happened there with your forum post.  I didn't get an email that you replied until now (two came through).
                                              I'll message you Monday morning when I arrive and see if you're available then.
                                              Maria
                                              • 23. Re: Failed to Register when installing Flash Player
                                                Maria, Thanks for the help.  I will figure out a way for McAfee to allow the install of Flash Player or White list the Reg Keys below.
                                                HKLM\SOFTWARE\Microsoft\Internet Explorer\ActiveX Compatibility\{D27CDB70-AE6D-11cf-96B8-444553540000}\Compatibility Flags
                                                HKLM\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{FAF199D2-BFA7-4394-A4DE-044A08E59B32}\Policy
                                                HKLM\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{FAF199D2-BFA7-4394-A4DE-044A08E59B32}\AppPath
                                                HKLM\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{FAF199D2-BFA7-4394-A4DE-044A08E59B32}\AppName
                                                Roger
                                                m_vargas wrote:
                                                Hi Roger,
                                                • 24. Re: Failed to Register when installing Flash Player
                                                  For anyone who may come across this thread with similar issue (and still getting 'Failed to Register' error after running the SubInACL tool to fix permissions):
                                                  We're identified the issue as McAfee. Specifically, McAfee was preventing access to the following registry entries:
                                                  When McAfee was uninstalled, Flash Player ActiveX registered.  Could be some  policy setting in the McAfee configuration.  OP is going to investigate.
                                                  Maria
                                                  • 25. Re: Failed to Register when installing Flash Player
                                                    martin_stettler
                                                    Hi Maria
                                                    I have the same Problem .... but ... by is NOT installed the McAfee.
                                                    And have read and make all instuctions in this message three.
                                                    Windows 7 Ultimate - German x64
                                                    The Problem is since Update from 18.0.0.232 to 19.0.0.185.
                                                    Can not make Adobe a FIXING-Programm?
                                                    Thanks - Bye
                                                    Stettler Martin
                                                    • 26. Re: Failed to Register when installing Flash Player
                                                      Hi martin_stettler,
                                                      Do you use any anti-virus software?  If so, try disabling the software and then run the installer again.
                                                      Have you followed the steps in How do I fix Windows permission problems with Flash Player??
                                                      Maria
                                                      • 27. Re: Failed to Register when installing Flash Player
                                                        martin_stettler Level 1
                                                        Hi Maria
                                                        No Antivirus SW.
                                                        Yes - I have make ALL your tips ...
                                                        :-) I have a ZyXEL USG310 with AV - but this make NO access to my computers.
                                                        Bye
                                                        Martin
                                                        • 28. Re: Failed to Register when installing Flash Player
                                                          Hi Maria
                                                          No solutions?
                                                          Is that's all now? Since
                                                          Greatings from Switzerland
                                                          Martin
                                                          • 29. Re: Failed to Register when installing Flash Player
                                                            Carm01 Level 4
                                                            Ironically it is McAfee that Adobe is trying to pawn off on us as "certified bloatware" from their installer page, yet it is the cause of the problems, yet it is still being pawned off on users thus causing potential problems
                                                            Does anyone see the problem?
                                                            • 30. Re: Failed to Register when installing Flash Player
                                                              Again! In my System Windows 7 Ultimate x64 is NO AV acctive --- I say NO AV.
                                                              This Jop make my ZyXEL USG 310. And this have no impact in my system.
                                                              Will not make Adobe a solution - to solve this problem?
                                                              Bye - Martin
                                                              • 31. Re: Failed to Register when installing Flash Player
        Hi martin_stettler,
        I apologize for missing your post from Nov 9.
        I'd like to review the FlashInstall.log file from your system. Please provide the FlashInstall.log files saved at C:\Windows\System32\Macromed\Flash AND C:\Windows\SysWOW64\Macromed\Flash.  The files will be fairly large, as such, please upload them to cloud.acrobat.com using the instructions The specified item was not found. or post them to some other file sharing service of your choice.  Please post the link to the uploaded files in your reply.
        Maria
