• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
One dynamic drop down
Engaged ,
Aug 25, 2015 Aug 25, 2015
Hi everyone.
I have a page that has 2 dynamic drop down menus in that depending what is selected in the first drop down will display certain criteria in the 2nd drop down. I have this working in one table just fine, but then I tried it in another table and I can't get the code to work for some reason. I can choose the first drop down menu, but then it has a timed out error that displays after I make my first choice. I can't see the Cold Fusion error, so I'm not sure what's wrong. Here's what I have in my table called Elastomer_Cut_Size:
Column Name                    Data Type
ItemID                                   Int
Elastomer Part_Number     nvarchar(50)
X_mm                                   Int
Y_mm                                   Int
Elastomer_Cost                    Money
Cutting_Cost                         Money
K_Factor                            numeric(18,1)
Sell_Price                              Money
Here's the code I have:
<!--- store the selected Main_Group variable variable after the first select boxes submits itself --->
<cfif isDefined('form.select_Elastomer_Part_Number')>
    <cfset page.select_Elastomer_Part_Number = form.select_Elastomer_Part_Number>
</cfif>
<cfoutput>
  <form name="DropDown" method="post">
  <!--- query DB for the first drop down list --->
  <cfquery name="get_Elastomer_Part_Number" datasource="#application.DataSource#">
     SELECT DISTINCT Elastomer_Part_Number
     FROM Elastomer_Cut_Size
     ORDER BY Elastomer_Part_Number
  </cfquery>
  <!--- first drop down list --->
  <!--- NOTICE the onChange javascript event in the select tag, this is what submits the form after the first selection --->
  <select name="select_Elastomer_Part_Number" required="yes" onchange="this.form.submit()">
     <option>Select Part Number</option>
     <!--- dynamically populate the first drop down list based on the get_Part_Number query --->
     <!--- NOTICE the CFIF within the option tag, this says, if the first selection has been made, display the chosen option when the page reloads --->
     <cfloop query="get_Elastomer_Part_Number">
         <option value="#Elastomer_Part_Number#" <cfif isDefined('form.select_Elastomer_Part_Number')><cfif form.select_Elastomer_Part_Number eq "#Elastomer_Part_Number#">selected</cfif></cfif>>#Elastomer_Part_Number#</option>
     </cfloop>
</select>
<p>
<!--- if the first selection has been made, display the second drop down list with the appropriate results --->
<cfif isDefined('page.select_Elastomer_Part_Number')>
   <!--- query DB for second drop down list, based on the selected item from the first list --->
   <cfquery name="get_Y" datasource="#application.DataSource#">
        SELECT DISTINCT Y_mm
        WHERE Elastomer_Part_Number = #page.select_Elastomer_Part_Number#
        ORDER BY Y_mm
   </cfquery>
   <!--- second drop down list --->
   <select name="select_Y" required="yes">
      <option>Select Y</option>
      <!--- dynamically populate the second drop down list based on the get_X query --->
      <cfloop query="get_Y">
         <option value="#Y_mm#">#Y_mm#</option>
      </cfloop>
   </select>
</cfif>
</form>
</cfoutput>
Can anyone tell me what I'm doing wrong? When I try to run a query for the 2nd drop down is when I have problems.I actually don't even need another drop down to display. I just want whatever part number is chosen in the first drop down, to run a calculation. Each part number has a different calcualation. I can get this to work if I just choose a Part number and display some text under the cfif isDefined('page.select_Elastomer_Part_Number'). But if I try to put a CFQuery after this isDefined, the timed out error displays. Can someone please help me? Thanks.
Andy
Views
351
Translate
Translate
Report
Report
Community guidelines
community guidelines
Engaged ,
LATEST
I think I know why this isn't working. I need both drop down menus to be numbers. It doesn't work if I choose a part number first and then a dimension number. The Part Number has letters and numbers. How do I just be able to choose a part number in a drop down menu and then depending what was chosen, it will run a calculation for that part number?
Andy
Votes
Translate
Translate
Report
Report
Resources
Documentation
