9 Replies Latest reply on Sep 1, 2015 10:41 AM by DrDaveJ
    RemoveMenu, not working
    DrDaveJ
      Whether I AutoRun at startup, or wait and run manually when needed,
      I add a menu to the main menu bar with this:
      //Create menu
      var myMenu = DefineMenu("Daves_ScriptingMenu", "Dave's Scripts");
      //Get the main FM document menu, so we can
      //add our custom menu, then add it.
      var fmMenu = app.GetNamedMenu ("!MakerMainMenu");
      fmMenu.AddMenuToMenu (myMenu);
      . . . I add commands, etc. that are working.
      The problem is removing the menu when I don't want it there.
      I'm trying this code. It appears to run, but nothing happens. And there are no
      messages generated in the Console.
      Notice I tried using the menu name as well as its label.
      //Get the main FM document menu, and then remove custom menu.
      //Using Label
      RemoveMenu(fmMenu, "Dave's Scripts");
      //Using Name
      //RemoveMenu(fmMenu, "Daves_ScriptingMenu");
      UpdateMenus();
      Can I get a hint as to what's up here?
      Dave
        • 1. Re: RemoveMenu, not working
          Russ Ward Level 4
          Dave,
          Some time ago, I had a similar frustration with deleting commands (that is, it didn't work). See the following post... there is a link to an FM12 patch release notes that might be informative. But I'm not sure because I never got the patch   You don't mention your version of FM, so I don't know if this will be helpful or not.
          Command object Delete() and CommandNum property issues
          Russ
          • 2. Re: RemoveMenu, not working
            DrDaveJ Level 1
            Running FM v12.0.4.445 on Win 7 pc.
            When I run the script using Run Button in script catalog, it would register my click, but nothing happened.
            Now, thinking maybe there are issues with the Script Library/Catalog, I run the script from within the Editor.
            This generates an error I had not noticed previously:
            "app.GetNamedMenu is not a function"
            However, according to the scripting guide (last updated 4/8/2014), I have this syntax correct. The line is shown in my initial post.
            Help please?
            Dave
            • 4. Re: RemoveMenu, not working
              Russ Ward Level 4
              Dave, I can't duplicate the problem with app.GetNamedMenu(). I even copied the line directly from your post and ran it... worked fine. Are you still having the problem?
              Russ
              • 5. Re: RemoveMenu, not working
                DrDaveJ Level 1
                Yes, still stuck here. Here are my test conditions.
                _The menu I want to remove can get added via
                AutoRun or added manually. Results below are the same either way.
                _I can run from the Editor, with FMv12 set as connected target; and/or run from
                File Menu > Script > Run.
                _Below is  four ways I've tried to remove the daves menu.
                *In all cases, the script will run, but the menu does not get removed. They all generate the console message in the editor, "Result: undefined".
                (1)
                //Oiriginal attempt, using Daves Menu Label. Also tried using Menu NAME.
                var fmMenu = app.GetNamedMenu("!MakerMainMenu");
                RemoveMenu("!MakerMainMenu", "Dave's Scripts"); //Daves Menu LABEL
                fmDavesMenu.delete();  //Causes Error: "fmDavesMenu.delete is not a function".  Tried this line in all versions.
                //  In all cases, they all run without this line, but do not remove the menu.
                UpdateMenus();
                (2)
                //Loading var's then addressing them to remove menu
                var fmDavesMenu = app.GetNamedMenu("Daves_ScriptingMenu"); //Menu NAME
                RemoveMenu(fmMenu, fmDavesMenu);
                UpdateMenus();
                (3)
                //Loading var's, in case they somehow need to be declared, but not
                //  using them for the removal.
                RemoveMenu("!MakerMainMenu", "Dave's Scripts"); //Menu LABEL
                UpdateMenus();
                (4)
                //Without first declaring var("!MakerMainMenu"). Tried both Remove lines, one at a time.  No Joy.
                RemoveMenu("!MakerMainMenu", "Daves_ScriptingMenu");//Menu NAME
                //RemoveMenu("!MakerMainMenu", "Dave's Scripts"); //Menu LABEL
                UpdateMenus();
                • 6. Re: RemoveMenu, not working
                  Russ Ward Level 4
                  Dave, I finally got a minute to look at this. I've discovered that the documentation on RemoveMenu() is not correct. It makes no sense to pass a menu label as an identifier, since these do not need to be unique. However, the menu Name does need to be unique, so I tried that and it worked. So, at least the documentation was accurate in that the arguments must be strings, not menu objects.
                  I think this variation of your code should work... give it a try:
                  (2)
                  RemoveMenu(fmMenu.Name, fmDavesMenu.Name);
                  ...or, I guess maybe just:
                  Russ
                  • 7. Re: RemoveMenu, not working
                    DrDaveJ Level 1
                    Alas, none of that worked.
                    You gave me ideas about mixing and matching .properties, menu names/labels, etc.  No joy.
                    Now, I am off this project and onto something else for a couple days. Will tackle this again while I am on vacation, starting Thurs/3rd.
                    My next guess is to remove Commands from the Menu, and then see if the Menu will Remove.
                    Thanks for the feedback!
                    Dave
                    • 8. Re: RemoveMenu, not working
                      Russ Ward Level 4
                      It works fine here. The only other thing I could suggest is the obvious... make sure you have the right name of your menu. You could test with alert(fmDavesMenu.Label).
                      Russ
                      • 9. Re: RemoveMenu, not working
                        DrDaveJ Level 1
                        Russ,
                        The obvious turns out to be the correct answer!
                        Gee whiz. Pass me the dunce cap! Rookies, move over.
                        I had the Add Menu Script located in two places.
                        1. Startup, in AppData; and
                        2. Its "Master Directory", where I keep the scripts. And where I made changes!
                        I then I wrote RemoveMenu script using menu names/labels as written/tweaked in #2, above. Totally forgetting the Startup version that actually adds the menu!
                        I copied current version of AddMenu to Startup and now, RemoveMenu works like a charm! Like so:
                        RemoveMenu("!MakerMainMenu", "Daves_ScriptingMenu"); //Menu NAME
                        UpdateMenus();
                        Thanks all the help!
                        [* name withheld to protect the thick-headed  *]
