I have no version of Adobe Flash Player installed.
Hi KNOB44,
This is the online installer that appears to be failing to download the installer further. The online installer log files should provide information was to why this is happening, presuming you have a good/solid internet connection. To obtain the log files, please do the following:
In the mean time, the offline installer, posted at the bottom of the Installation problems | Flash Player | Windows should work fine. Please do provide the online installer log files to enable us to troubleshoot the failure.
Thank you.
Maria
URL to uploaded files: https://cloud.acrobat.com/folder/31ef6470-ef9b-45d6-aa50-ae042bd7d44e
KNOB44
I tested my posted URL and it connects for me. Here it is again:
Update: I attempted to use the offline installer posted at the bottom of Installation problems|Flash Player|Windows. The installation failed – error message: The install_flash_player_ax.exe download was interrupted.
KNOB44
Hi KNOB44,
For some reason I'm still getting 'file not found' error. Did you select 'public link'?
If you're getting 'download was interrupted' error trying to download the offline installer, the issue may not be related to the online installer, and appears to be something else.
Do you have a firewall enabled?
Do you have anti-virus software installed, if so, which one?
Are you using a proxy server?
All installers are downloaded via HTTPS, are you able to download other files (via https) using IE or is this only happening to Flash Player installer files?
Have you tried using a different browser to download the installer?
Maria
I did not select the public link. The instructions were somewhat vague and out of date - I did not see that option. If you could give me some guidance, will try again.
I have Norton Internet Security installed with firewall enabled. Have not experienced problems with Norton current version or with firewall.
Not using proxy server
I frequently use IE to download update files, most recent:
Adobe Air 7/15
Adobe Reader 7/15
Adobe Shockwave 8/17
iTunes 8/19
I have Chrome installed, already has the latest Adobe Flash installed. Attempted to use Chrome to download/install Adobe Flash Player for IE 11. Download disconnected at about 30%, same as HTTPS.
KNOB44
As of yesterday afternoon I was able to select the public link and uploaded my files: Adobe_ADM.log and Adobe_GDE.log. Am using Norton Internet Security with firewall enabled. Am able to frequently download other files using IE including Adobe Reader and Shockwave. Only issue is with Flash Player installer. I tried to use Chrome (which has Flash enabled) to download the Flash installer for IE. Same issue: disconnected during download. I attempted to update our previous discussion thread and was no longer active, update failed. KNOB44
https://files.acrobat.com/a/preview/1bb9fc61-5d10-4ea6-b6b3-77b829c0bf5f ink to shared uploaded log files. KNOB44
Hi KNOB44
I do see a download error in the online installer log file and have forwarded the log file to the online installer team.
Can you try downloading the offline installer again (Flash Player for Internet Explorer - ActiveX)‌ using a browser other than IE?
Maria
I used Chrome to successfully download and install Adobe Flash Player for IE. It appears in my control panel list of installed programs, version 18.0.0.232. installed today. I closed and re-opened IE. IE Add-ons now lists under Adobe Systems:
Shockwave Flash Object. Enabled
Previously Adobe Shockwave was listed and no longer is. (was installed on 8/17/15 and still appears on my control panel list of installed programs.
Does "Shockwave Flash Object include both Shockwave and Flash Player in IE?
KNOB44
Have gone to Adobe test web sites for both Flash & Shockwave and confirmed I now have the latest versions of both Adobe Flash and Shockwave in my IE 11.
The IE "Manage Add-ons" under Adobe Systems now shows:
Shockwave Active X Control v 12.1.9
Shockwave Flash Object v 18.0.0.232
Flash working fine now in IE. Thanks for your help.
Will continue using the offline installer with Chrome to update Flash in IE until the download disconnect in IE issue is resolved.
Maria
I just noted that I cannot download PDF files in Adobe Reader using IE 11. Download disconnects before completion.
KNOB44
HI KNOB44,
If you're not able to download anything using IE, the issue is with some setting in IE that is configured to not download anything. One place to look is in the Security Settings for Internet Zone and ensure that File Downloads is enabled (Internet Options > Security > Internet > Custom level > Downloads > File Download = enabled)
If it is enabled you may want to try resetting IE (see Change or reset Internet Explorer settings - Windows Help). Note that resetting IE will reset IE to it's original settings, resulting in the loss of any bookmarks, add-ons, etc.
Maria
My file downloads in IE is enabled. Am reluctant to reset IE at this time. Restoring loss of bookmarks and add-ons would be a real hassle. Will continue for the time being to use Chrome as a workaround and will work more with the IE download issue as time permits.
KNOB44
