2 Replies Latest reply on Aug 25, 2015 4:07 PM by erfans57887370
    Export settings ?
      Hi all,
      I'm trying to export some GoPro footage out of AE, using Media Encoder, and trying to do the least amount of compressing on the exported file as I'll be running it through another application.
      So the original file is 1920x1440 @ 50 fps, with the Mbps around 61-62 with h264 codec in a mp4 container.
      I've done a bit of experimenting, and currently the one that makes the most sense is Quicktime, ProRes 422, SAME AS SOURCE for resolution, fps and pretty much everything, with no limit on the bitrate, and maximum depth and render quality checked.
      Was wondering if anyone has a better solution?
      Thanks in advance.
