2 Replies Latest reply on Dec 6, 2006 8:35 AM by mcd
    cfml-tags in string variables and outputting
      i'm implementing a small content-managment system in my web-application, based on cf-mx7.
      i have an html-editor for editing the web-content (FCKeditor). The content is then saved to the database.
      Now my application simpliefied loads the content from database and outputs it with <cfoutput>#mycontent#</cfoutput> where mycontent is the variable where the content is loaded to via cfquery-tag.
      So far so good. This works fine.
      Now i want to integrate some cfml-tags into the web-content. so that variabe mycontent contains html-code mixed with cfml-tags. but now the cfml-tags are only outputted to the browser as they are and are not processed by coldfusion.
      does anybody now how to implement that?
      may regards and thanks for your help
        • 1. Re: cfml-tags in string variables and outputting
          Kevin Schmidt Level 1
          What tags do you want to put into the content and why?
          Perhaps there is a better way to do what you want to accomplish.
          • 2. Re: cfml-tags in string variables and outputting
            mcd Level 1
            thanks for your answer.
            The reason is following:
            I show my content on a cfml web page using a <cfmodule>-tag, where the template-parameter identifies a custom-tag which gets the id of my content-object in the database. that tag has some additional funcitionality such a show links for editing the content when the actual user is the content-owner and show header and footers. It also loads the content, identified by the id of the content in the database, and outputs it using <cfoutput>#mycontent#</cfoutput>
            Now my intention is, that i want to use cf-tags in the content. with that i want to indirectly nest some <cfmodule>-tags. The result should be, that my content itself contains content-objects, but for that my first content has to contain that <cfmodule>tags
            i hope i could descripe to you what my intention is.
