I am using Windows 10 with both Microsoft Edge and IE11. When I open a site that uses flash player it tells me I need to install it. When I go to Adobe help page it tells me that Flash Player is not installed. If I try to download it tells me that flash player is integrated in windows 10 and I have the latest version. I tried disabling ActiveX in IE but no joy. Now what do I do?
Hi
Can you please try the instructions on the below link for Microsoft Edge:
Flash Player Issues | Windows 10 | Microsoft Edge
And for IE, please check the below link:
ActiveX Filtering in Internet Explorer
Jasbeer,
I have followed both instructions for IE and Edge. ActiveX control is disabled in IE. Flash Player is ON in Edge. But Flash Player is not responding. Is there any way to re-install it inside Windows 10?
I am hoping for some expert help. I will try posting a question to Microsoft.
Hi
Can you please share the dxdiag of your machine.
Below are the steps to obtain dxdiag:
1. press Window key + R
2. type dxdiag and press Enter
3. A window will pop up
4. press "save all informantion" button on the lower side of the windows
5. Save the report and please share the same.
System Information
Time of this report: 8/28/2015, 10:01:35
Machine name: JULIAN-HP
Operating System: Windows 10 Home 64-bit (10.0, Build 10240) (10240.th1.150810-2333)
Language: English (Regional Setting: English)
System Manufacturer: Hewlett-Packard
System Model: HP Pavilion g6 Notebook PC
BIOS: InsydeH2O Version CCB.03.61.17F.49
Processor: AMD A6-3400M APU with Radeon(tm) HD Graphics (4 CPUs), ~1.4GHz
Memory: 6144MB RAM
Available OS Memory: 5610MB RAM
Page File: 2349MB used, 8893MB available
Windows Dir: C:\WINDOWS
DirectX Version: 11.1
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
Miracast: Not Available
Microsoft Graphics Hybrid: Not Supported
DxDiag Version: 10.00.10240.16384 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: AMD Radeon HD 6520G
Manufacturer: Advanced Micro Devices, Inc.
Chip type: AMD Radeon Graphics Processor (0x9647)
DAC type: Internal DAC(400MHz)
Device Type: Full Device
Device Key: Enum\PCI\VEN_1002&DEV_9647&SUBSYS_169B103C&REV_00
Display Memory: 3057 MB
Dedicated Memory: 497 MB
Shared Memory: 2560 MB
Current Mode: 1366 x 768 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: unknown
Monitor Id: LGD02F2
Native Mode: 1366 x 768(p) (60.031Hz)
Output Type: Internal
Driver Name: aticfx64.dll,aticfx64.dll,aticfx64.dll,aticfx32,aticfx32,aticfx32,atiumd64.dll,atidxx64.dll,atidxx64.dll,atiumdag,atidxx32,atidxx32,atiumdva,atiumd6a.cap,atitmm64.dll
Driver File Version: 8.17.0010.1404 (English)
Driver Version: 15.200.1062.1004
DDI Version: 11.1
Feature Levels: 11.0,10.1,10.0,9.3,9.2,9.1
Driver Model: WDDM 1.2
Graphics Preemption: DMA
Compute Preemption: DMA
Miracast: Not Supported by Graphics driver
Hybrid Graphics GPU: Not Applicable
Power P-states: Not Applicable
Driver Attributes: Final Retail
Driver Date/Size: 8/22/2015 15:21:12, 1466712 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B71EE2-D507-11CF-F076-9136BEC2C535}
Vendor ID: 0x1002
Device ID: 0x9647
SubSys ID: 0x169B103C
Revision ID: 0x0000
Driver Strong Name: oem47.inf:cb0ae414e94bfb4f:ati2mtag_Sumo_Mobile:15.200.1062.1004:pci\ven_1002&dev_9647
Rank Of Driver: 00DA2001
Video Accel: ModeMPEG2_A ModeMPEG2_C
DXVA2 Modes: DXVA2_ModeMPEG2_VLD DXVA2_ModeMPEG2_IDCT DXVA2_ModeH264_VLD_NoFGT DXVA2_ModeH264_VLD_Stereo_Progressive_NoFGT DXVA2_ModeH264_VLD_Stereo_NoFGT DXVA2_ModeVC1_VLD DXVA2_ModeMPEG4pt2_VLD_AdvSimple_NoGMC
Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{3C5323C1-6FB7-44F5-9081-056BF2EE449D}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{552C0DAD-CCBC-420B-83C8-74943CF9F1A6}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
D3D9 Overlay: Not Supported
DXVA-HD: Not Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Description: Speakers and Headphones (IDT High Definition Audio CODEC)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_111D&DEV_7605&SUBSYS_103C169B&REV_1001
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: stwrt64.sys
Driver Version: 6.10.6341.0000 (English)
WHQL Logo'd: Yes
Date and Size: 6/8/2011 15:58:52, 528384 bytes
Other Files:
Driver Provider: IDT
HW Accel Level: Basic
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Description: Communications Headphones (IDT High Definition Audio CODEC)
Default Sound Playback: No
Default Voice Playback: No
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: Yes
Other Files:
Cap Flags: 0xF1F
HW Memory: 0
Sound Capture Devices
Description: Internal Mic (IDT High Definition Audio CODEC)
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x1
Format Flags: 0xFFFFF
Description: External Mic (IDT High Definition Audio CODEC)
Default Sound Capture: No
Default Voice Capture: No
Cap Flags: 0x1
Description: Stereo Mix (IDT High Definition Audio CODEC)
Cap Flags: 0x1
Video Capture Devices
Number of Devices: 2
FriendlyName: HP Webcam-101
SymbolicLink: \\?\usb#vid_0c45&pid_6321&mi_00#6&305fd072&0&0000#{e5323777-f976-4f5b-9b55-b94699c46e44}\global
Manufacturer: Microsoft
HardwareID: USB\VID_0C45&PID_6321&REV_1804&MI_00,USB\VID_0C45&PID_6321&MI_00
DriverDesc: USB Video Device
DriverProvider: Microsoft
DriverVersion: 10.0.10240.16384
DriverDateEnglish: 6/21/2006 00:00:00
DriverDateLocalized: 6/21/2006 12:00:00 AM
Service: usbvideo
Class: Image
DevNodeStatus: 180200A[DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
ContainerId: {00000000-0000-0000-FFFF-FFFFFFFFFFFF}
ProblemCode: No Problem
BusReportedDeviceDesc: HP Webcam-101
Parent: USB\VID_0C45&PID_6321\5&1ec07c0e&0&2
DriverProblemDesc: n/a
UpperFilters: n/a
LowerFilters: n/a
Stack: \FileSystem\KLIF,\Driver\ksthunk,\Driver\usbvideo,\Driver\usbfilter,\Driver\usbccgp
ContainerCategory: Imaging
FriendlyName: CyberLink Webcam Splitter
SymbolicLink: \\?\root#media#0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global
Manufacturer: CyberLink
HardwareID: clwvd
DriverDesc: CyberLink WebCam Virtual Driver
DriverProvider: CyberLink
DriverVersion: 6.0.5600.0
DriverDateEnglish: 1/11/2010 00:00:00
DriverDateLocalized: 1/11/2010 12:00:00 AM
Service: clwvd
Class: MEDIA
DevNodeStatus: 180200B[DN_ROOT_ENUMERATED|DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
BusReportedDeviceDesc: n/a
Parent: HTREE\ROOT\0
UpperFilters: n/a
LowerFilters: n/a
Stack: \Driver\ksthunk,\Driver\clwvd,\Driver\PnpManager
ContainerCategory: n/a
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: Micr
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x045E, 0x07B2
FF Driver: n/a
Device Name: HP Wireless Button Driver
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x0001, 0x0001
FF Driver: n/a
Device Name: Micr
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: Micr
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: Microsoft Hardware USB Mouse
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: Micr
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x1022, 0x7807
| Matching Device ID: USB\ROOT_HUB
| Service: usbhub
| Driver: usbhub.sys, 7/23/2015 23:30:58, 498016 bytes
| Driver: usbd.sys, 7/10/2015 06:59:39, 29536 bytes
+-+ Microsoft Mouse and Keyboard Detection Driver (USB)
| | Matching Device ID: USB\VID_045E&PID_07B2
| | Upper Filters: dc3d
| | Service: usbccgp
| | Driver: dc3d.sys, 3/19/2014 15:27:44, 76496 bytes
| | Driver: usbccgp.sys, 7/10/2015 06:59:39, 159072 bytes
| | Driver: WdfCoInstaller01011.dll, 7/30/2015 17:18:30, 1804696 bytes
| +-+ Microsoft Hardware USB Keyboard
| | | Matching Device ID: usb\vid_045e&pid_07b2&mi_00
| | | Service: HidUsb
| | | Driver: hidusb.sys, 7/10/2015 06:59:38, 38400 bytes
| | | Driver: hidclass.sys, 7/10/2015 06:59:38, 153088 bytes
| | | Driver: hidparse.sys, 7/10/2015 06:59:38, 39936 bytes
| | | Driver: coin95itp.dll, 1/7/2014 09:12:06, 2276560 bytes
| | +-+ Microsoft USB Dual Receiver Wireless Keyboard (Mouse and Keyboard Center)
| | | | Matching Device ID: HID\VID_045E&PID_07B2&MI_00
| | | | Service: kbdhid
| | | | Driver: kbdhid.sys, 7/10/2015 06:59:38, 36864 bytes
| | | | Driver: kbdclass.sys, 7/10/2015 06:59:38, 62304 bytes
| +-+ Microsoft Hardware USB Mouse
| | | Matching Device ID: usb\vid_045e&pid_07b2&mi_01
| | | Service: HidUsb
| | | Driver: coin95ip.dll, 1/7/2014 08:52:24, 2276560 bytes
| | +-+ Microsoft USB Dual Receiver Wireless Mouse (Mouse and Keyboard Center)
| | | | Matching Device ID: HID\VID_045E&PID_07B2&MI_01&Col01
| | | | Upper Filters: Point64
| | | | Service: mouhid
| | | | Driver: point64.sys, 3/19/2014 15:23:14, 50896 bytes
| | | | Driver: mouhid.sys, 7/10/2015 06:59:39, 32256 bytes
| | | | Driver: mouclass.sys, 7/10/2015 06:59:39, 59232 bytes
Gameport Devices
PS/2 Devices
+ Standard PS/2 Keyboard
| Matching Device ID: *PNP0303
| Service: i8042prt
| Driver: i8042prt.sys, 7/10/2015 06:59:38, 114688 bytes
+ Synaptics PS/2 Port TouchPad
| Matching Device ID: acpi\syn1e49
| Upper Filters: SynTP
| Service: i8042prt
| Driver: SynTP.sys, 7/30/2015 17:18:25, 614088 bytes
| Driver: Smb_driver_Intel_Aux.sys, 7/30/2015 17:18:19, 42696 bytes
| Driver: Smb_driver_AMDASF_Aux.sys, 7/30/2015 17:18:19, 42184 bytes
| Driver: SynTPAPI.dll, 7/30/2015 17:18:25, 269000 bytes
| Driver: SynCOM.dll, 7/30/2015 17:18:21, 764616 bytes
| Driver: SynTPRes.dll, 7/30/2015 17:18:29, 19198664 bytes
| Driver: SynTPCpl.dll, 7/30/2015 17:18:25, 3921096 bytes
| Driver: SynCntxt.rtf, 7/30/2015 17:18:21, 12598980 bytes
| Driver: SynZMetr.exe, 7/30/2015 17:18:30, 1887944 bytes
| Driver: SynMood.exe, 7/30/2015 17:18:23, 1910984 bytes
| Driver: SynTPEnh.exe, 7/30/2015 17:18:26, 3944136 bytes
| Driver: Tutorial.exe, 7/30/2015 17:18:30, 1899208 bytes
| Driver: InstNT.exe, 7/30/2015 17:18:18, 305864 bytes
| Driver: SynISDLL.dll, 7/30/2015 17:18:22, 339144 bytes
| Driver: SynUnst.ini, 7/30/2015 17:18:29, 1647128 bytes
| Driver: SynRemoveUserSettings.dat, 7/30/2015 17:18:23, 1315 bytes
| Driver: SynTPHelper.exe, 7/30/2015 17:18:29, 210120 bytes
| Driver: SynTPEnhService.exe, 7/30/2015 17:18:27, 246472 bytes
| Driver: SynReflash.exe, 7/30/2015 17:18:23, 1337032 bytes
| Driver: SynPivotRotate.mpg, 5/24/2015 13:14:46, 770663 bytes
| Driver: SynChiralRotate.mpg, 5/24/2015 13:14:42, 382277 bytes
| Driver: SynFlick.mpg, 5/24/2015 13:14:44, 737975 bytes
| Driver: SynPinch.mpg, 5/24/2015 13:14:46, 286463 bytes
| Driver: SynMomentum.mpg, 5/24/2015 13:14:44, 246230 bytes
| Driver: SynLinearVHScroll.mpg, 5/24/2015 13:14:44, 929103 bytes
| Driver: SynChiralVHScroll.mpg, 5/24/2015 13:14:42, 1620778 bytes
| Driver: SynTwoFingerVHScroll.mpg, 5/24/2015 13:14:48, 746464 bytes
| Driver: SynPivotRotate_ChiralRotate.mpg, 5/24/2015 13:14:46, 1142810 bytes
| Driver: SynThreeFingerFlick.mpg, 5/24/2015 13:14:47, 633621 bytes
| Driver: SynThreeFingersDown.mpg, 5/24/2015 13:14:47, 215907 bytes
| Driver: SynTwistRotate.mpg, 5/24/2015 13:14:48, 1826816 bytes
| Driver: SynChiralTwistRotate.mpg, 5/24/2015 13:14:42, 2998272 bytes
| Driver: StaticImg.html, 5/24/2015 13:14:40, 968 bytes
| Driver: StaticImg.png, 5/24/2015 13:14:40, 107143 bytes
| Driver: SynSysDetect.js, 7/30/2015 17:18:24, 1481 bytes
| Driver: Syn2FingerScrolling.wmv, 7/30/2015 17:18:19, 650659 bytes
| Driver: Syn3FingerFlick.wmv, 7/30/2015 17:18:20, 774019 bytes
| Driver: Syn4FingerFlick.wmv, 5/24/2015 13:14:42, 795115 bytes
| Driver: Syn4FFlickVNB.wmv, 7/30/2015 17:18:20, 381040 bytes
| Driver: SynSmartSense.wmv, 7/30/2015 17:18:24, 370121 bytes
| Driver: SynSmartSenseNB.wmv, 7/30/2015 17:18:24, 670555 bytes
| Driver: Syn4FingerFlickUpDown.wmv, 7/30/2015 17:18:20, 1264895 bytes
| Driver: Syn4FingerFlickUpDownNB.wmv, 7/30/2015 17:18:20, 711685 bytes
| Driver: Syn4FingerFlickLeftRight.wmv, 7/30/2015 17:18:20, 1201694 bytes
| Driver: Syn4FingerFlickLeftRightNB.wmv, 7/30/2015 17:18:20, 711655 bytes
| Driver: Syn3FingerPress.wmv, 7/30/2015 17:18:20, 149361 bytes
| Driver: SynEdgeMotion.wmv, 7/30/2015 17:18:22, 790425 bytes
| Driver: SynLinearScrolling.wmv, 7/30/2015 17:18:22, 486299 bytes
| Driver: SynMomentum.wmv, 7/30/2015 17:18:22, 231541 bytes
| Driver: SynMomentumScrolling.wmv, 7/30/2015 17:18:22, 1513885 bytes
| Driver: SynPinchZoom.wmv, 7/30/2015 17:18:23, 361085 bytes
| Driver: SynBlackScreen.wmv, 7/30/2015 17:18:20, 14729 bytes
| Driver: SynPivotRotate.wmv, 7/30/2015 17:18:23, 609629 bytes
| Driver: SynTwistRotate.wmv, 7/30/2015 17:18:29, 535667 bytes
| Driver: SynCoverGesture.wmv, 7/30/2015 17:18:21, 633185 bytes
| Driver: SynChiralRotate.wmv, 7/30/2015 17:18:20, 321969 bytes
| Driver: SynChiralScrolling.wmv, 7/30/2015 17:18:20, 1776645 bytes
| Driver: SynCoastingScrolling.wmv, 7/30/2015 17:18:21, 880823 bytes
| Driver: SynPointing.wmv, 7/30/2015 17:18:23, 89721 bytes
| Driver: SynPalmCheck.wmv, 7/30/2015 17:18:23, 278039 bytes
| Driver: SynSensitivity.wmv, 7/30/2015 17:18:24, 183903 bytes
| Driver: SynWindowConstrained.wmv, 7/30/2015 17:18:29, 250401 bytes
| Driver: SynSlowMotion.wmv, 7/30/2015 17:18:24, 255951 bytes
| Driver: SynConstrainedMotion.wmv, 7/30/2015 17:18:21, 1174655 bytes
| Driver: SynTapping.wmv, 7/30/2015 17:18:24, 67389 bytes
| Driver: SynButtons.wmv, 7/30/2015 17:18:20, 190451 bytes
| Driver: SynTouchStykSelect.wmv, 7/30/2015 17:18:24, 84183 bytes
| Driver: SynTouchStykButton.wmv, 7/30/2015 17:18:24, 95259 bytes
| Driver: SynTouchStykSensitivity.wmv, 7/30/2015 17:18:25, 183909 bytes
| Driver: SynEdgeMotionDragging.wmv, 7/30/2015 17:18:22, 174015 bytes
| Driver: SynEdgeMotionFixedSpeed.wmv, 7/30/2015 17:18:22, 174015 bytes
| Driver: SynEdgeMotionPointing.wmv, 7/30/2015 17:18:22, 157579 bytes
| Driver: SynEdgeMotionPressure.wmv, 7/30/2015 17:18:22, 67539 bytes
| Driver: SynNoButtons.wmv, 7/30/2015 17:18:23, 28715 bytes
| Driver: SynTapZones.wmv, 7/30/2015 17:18:24, 215105 bytes
| Driver: SynLinearHScrolling.wmv, 7/30/2015 17:18:22, 527389 bytes
| Driver: Syn2FingerHScrolling.wmv, 7/30/2015 17:18:19, 626005 bytes
| Driver: SynTapHoldToDrag.wmv, 7/30/2015 17:18:24, 62001 bytes
| Driver: SynTapLockingDrag.wmv, 7/30/2015 17:18:24, 95259 bytes
| Driver: Syn1FingerClickNB.wmv, 7/30/2015 17:18:19, 141143 bytes
| Driver: Syn1FingerClickDrag.wmv, 7/30/2015 17:18:19, 338125 bytes
| Driver: Syn2FingerClickDrag.wmv, 7/30/2015 17:18:19, 471371 bytes
| Driver: Syn2FingerFlickNB.wmv, 7/30/2015 17:18:19, 675403 bytes
| Driver: Syn2FingerFlickLR.wmv, 7/30/2015 17:18:19, 502795 bytes
| Driver: Syn2FingerHScrollingNB.wmv, 7/30/2015 17:18:19, 617787 bytes
| Driver: Syn2FingerScrollingNB.wmv, 7/30/2015 17:18:19, 634223 bytes
| Driver: Syn3FingerFlickNB.wmv, 7/30/2015 17:18:20, 749365 bytes
| Driver: Syn3FingerPressNB.wmv, 7/30/2015 17:18:20, 141143 bytes
| Driver: Syn4FingerFlickNB.wmv, 7/30/2015 17:18:20, 723930 bytes
| Driver: SynButtonsNB.wmv, 7/30/2015 17:18:20, 182233 bytes
| Driver: SynChiralRotateNB.wmv, 7/30/2015 17:18:20, 356580 bytes
| Driver: SynChiralScrollingNB.wmv, 7/30/2015 17:18:20, 2805670 bytes
| Driver: SynCoastingScrollingNB.wmv, 7/30/2015 17:18:21, 1532130 bytes
| Driver: SynCoverGestureNB.wmv, 7/30/2015 17:18:21, 633185 bytes
| Driver: SynEdgeMotionDraggingNB.wmv, 7/30/2015 17:18:22, 172875 bytes
| Driver: SynEdgeMotionFixedSpeedNB.wmv, 7/30/2015 17:18:22, 185120 bytes
| Driver: SynEdgeMotionPointingNB.wmv, 7/30/2015 17:18:22, 160630 bytes
| Driver: SynEdgeMotionPressureNB.wmv, 7/30/2015 17:18:22, 142023 bytes
| Driver: SynLinearHScrollingNB.wmv, 7/30/2015 17:18:22, 919820 bytes
| Driver: SynMomentumScrollingNB.wmv, 7/30/2015 17:18:22, 928929 bytes
| Driver: SynPinchZoomNB.wmv, 7/30/2015 17:18:23, 834947 bytes
| Driver: SynPivotRotateNB.wmv, 7/30/2015 17:18:23, 535667 bytes
| Driver: SynTapHoldToDragNB.wmv, 7/30/2015 17:18:24, 130279 bytes
| Driver: SynTapLockingDragNB.wmv, 7/30/2015 17:18:24, 212515 bytes
| Driver: SynTwistRotateNB.wmv, 7/30/2015 17:18:29, 821920 bytes
| Driver: SynPointingNB.wmv, 7/30/2015 17:18:23, 177285 bytes
| Driver: Syn2FingerMomentumVHScrolling.wmv, 5/24/2015 13:14:40, 895723 bytes
| Driver: Syn2FingerMomentumVHScrollingNB.wmv, 7/30/2015 17:18:19, 1645313 bytes
| Driver: Syn2FingerMomentumVScrolling_win8.wmv, 7/30/2015 17:18:19, 597933 bytes
| Driver: Syn2FingerMomentumVScrollingNB_win8.wmv, 7/30/2015 17:18:19, 586882 bytes
| Driver: Syn2FingerMomentumHScrolling_win8.wmv, 7/30/2015 17:18:19, 575831 bytes
| Driver: Syn2FingerMomentumHScrollingNB_win8.wmv, 7/30/2015 17:18:19, 1079005 bytes
| Driver: Syn2FingerVHCoasting.wmv, 7/30/2015 17:18:19, 1794763 bytes
| Driver: Syn2FingerVHCoastingNB.wmv, 7/30/2015 17:18:19, 2266890 bytes
| Driver: Syn2FingerVCoasting_win8.wmv, 7/30/2015 17:18:19, 919145 bytes
| Driver: Syn2FingerHCoasting_win8.wmv, 7/30/2015 17:18:19, 1003421 bytes
| Driver: Syn2FingerVCoastingNB_win8.wmv, 7/30/2015 17:18:19, 1311690 bytes
| Driver: Syn2FingerHCoastingNB_win8.wmv, 7/30/2015 17:18:19, 1397405 bytes
| Driver: SynMomentumVHScrolling.wmv, 7/30/2015 17:18:22, 1408837 bytes
| Driver: SynMomentumVHScrollingNB.wmv, 7/30/2015 17:18:22, 1774529 bytes
| Driver: SynVHCoasting.wmv, 7/30/2015 17:18:29, 1955445 bytes
| Driver: Syn2FingerHScrolling_win8.wmv, 7/30/2015 17:18:19, 432126 bytes
| Driver: Syn2FingerHScrollingNB_win8.wmv, 7/30/2015 17:18:19, 968800 bytes
| Driver: SynChiralScrolling_win8.wmv, 7/30/2015 17:18:20, 819031 bytes
| Driver: SynChiralScrollingNB_win8.wmv, 7/30/2015 17:18:20, 2805670 bytes
| Driver: SynLinearHScrolling_win8.wmv, 7/30/2015 17:18:22, 376913 bytes
| Driver: SynLinearHScrollingNB_win8.wmv, 7/30/2015 17:18:22, 919820 bytes
| Driver: SynLinearScrolling_win8.wmv, 7/30/2015 17:18:22, 354811 bytes
| Driver: SynLinearScrollingNB_win8.wmv, 7/30/2015 17:18:22, 797370 bytes
| Driver: SynPivotRotate_win8.wmv, 7/30/2015 17:18:23, 498534 bytes
| Driver: SynPivotRotateNB_win8.wmv, 7/30/2015 17:18:23, 870900 bytes
| Driver: SynTwistRotate_win8.wmv, 7/30/2015 17:18:29, 421135 bytes
| Driver: SynTwistRotateNB_win8.wmv, 7/30/2015 17:18:29, 821920 bytes
| Driver: SynEdgePulls.wmv, 7/30/2015 17:18:22, 1247447 bytes
| Driver: Syn4FingerFlick_win8.wmv, 7/30/2015 17:18:20, 598023 bytes
| Driver: Syn4FingerFlickNB_win8.wmv, 7/30/2015 17:18:20, 564870 bytes
| Driver: Syn2FingerScrolling.html, 7/30/2015 17:18:19, 3216 bytes
| Driver: Syn2FingerFlick.html, 7/30/2015 17:18:19, 3212 bytes
| Driver: Syn3FingerFlick.html, 7/30/2015 17:18:20, 3212 bytes
| Driver: Syn4FingerFlick.html, 7/30/2015 17:18:20, 3212 bytes
| Driver: Syn4FingerFlickUpDown.html, 7/30/2015 17:18:20, 3218 bytes
| Driver: Syn4FingerFlickLeftRight.html, 7/30/2015 17:18:20, 3221 bytes
| Driver: Syn3FingerPress.html, 7/30/2015 17:18:20, 3212 bytes
| Driver: SynEdgeMotion.html, 7/30/2015 17:18:21, 3210 bytes
| Driver: SynMomentum.html, 7/30/2015 17:18:22, 3208 bytes
| Driver: SynPinchZoom.html, 7/30/2015 17:18:23, 3209 bytes
| Driver: SynRotating.html, 7/30/2015 17:18:23, 3208 bytes
| Driver: SynTwistRotate.html, 7/30/2015 17:18:29, 3211 bytes
| Driver: SynCoverGesture.html, 7/30/2015 17:18:21, 3212 bytes
| Driver: SynAccessibility.html, 7/30/2015 17:18:20, 3221 bytes
| Driver: SynSmartSense.html, 7/30/2015 17:18:24, 3210 bytes
| Driver: SynButtons.html, 7/30/2015 17:18:20, 3207 bytes
| Driver: SynClicking.html, 7/30/2015 17:18:21, 3208 bytes
| Driver: SynMultiFingerGestures.html, 7/30/2015 17:18:23, 3219 bytes
| Driver: SynPalmCheck.html, 7/30/2015 17:18:23, 3209 bytes
| Driver: SynPointing.html, 7/30/2015 17:18:23, 3208 bytes
| Driver: SynScrolling.html, 7/30/2015 17:18:23, 3209 bytes
| Driver: SynSensitivity.html, 7/30/2015 17:18:24, 3211 bytes
| Driver: SynTapping.html, 7/30/2015 17:18:24, 3207 bytes
| Driver: SynTouchStykButton.html, 7/30/2015 17:18:24, 3215 bytes
| Driver: SynTouchStykSelect.html, 7/30/2015 17:18:24, 3215 bytes
| Driver: SynTouchStykSensitivity.html, 7/30/2015 17:18:24, 3220 bytes
| Driver: SynScrollingVertical.html, 7/30/2015 17:18:24, 3217 bytes
| Driver: SynScrollingHorizontal.html, 7/30/2015 17:18:24, 3219 bytes
| Driver: SynScrollingChiral.html, 7/30/2015 17:18:23, 3215 bytes
| Driver: SynLockingDrags.html, 7/30/2015 17:18:22, 3212 bytes
| Driver: SynEdgePulls.html, 7/30/2015 17:18:22, 3162 bytes
| Driver: Syn2FingerScrolling_win8.wmv, 7/30/2015 17:18:19, 398973 bytes
| Driver: Syn2FingerScrollingNB_win8.wmv, 7/30/2015 17:18:19, 940613 bytes
| Driver: SynTappingNB.wmv, 7/30/2015 17:18:24, 118535 bytes
| Driver: Syn2FingerRightClickNB.wmv, 7/30/2015 17:18:19, 177253 bytes
| Driver: SynVHCoastingNB.wmv, 7/30/2015 17:18:29, 1821565 bytes
| Driver: SynEdgePullsNB.wmv, 7/30/2015 17:18:22, 517951 bytes
| Driver: SynPalmCheckNB.wmv, 7/30/2015 17:18:23, 670557 bytes
| Driver: SynLinearScrollingNB.wmv, 7/30/2015 17:18:22, 797370 bytes
| Driver: SynSensitivityNB.wmv, 7/30/2015 17:18:24, 400455 bytes
| Driver: SynMomentumNB.wmv, 7/30/2015 17:18:22, 319815 bytes
| Driver: SynTapZonesNB.wmv, 7/30/2015 17:18:24, 258590 bytes
| Driver: SynTapZonesNB_win8.wmv, 7/30/2015 17:18:24, 258590 bytes
| Driver: SynEdgeMotionNB.wmv, 7/30/2015 17:18:22, 1360700 bytes
| Driver: SynSlowMotionNB.wmv, 7/30/2015 17:18:24, 517951 bytes
| Driver: SynConstrainedMotionNB.wmv, 7/30/2015 17:18:21, 623675 bytes
| Driver: SynWindowConstrainedNB.wmv, 7/30/2015 17:18:29, 588401 bytes
| Driver: Syn3FHSlide.wmv, 7/30/2015 17:18:19, 243720 bytes
| Driver: Syn3FHSlideNB.wmv, 7/30/2015 17:18:19, 202757 bytes
| Driver: Syn3FTapActionCenter.wmv, 7/30/2015 17:18:20, 108227 bytes
| Driver: Syn3FTapActionCenterNB.wmv, 7/30/2015 17:18:20, 105076 bytes
| Driver: Syn3FTapCortana.wmv, 7/30/2015 17:18:20, 111378 bytes
| Driver: Syn3FTapCortanaNB.wmv, 7/30/2015 17:18:20, 108227 bytes
| Driver: Syn4FTapActionCenter.wmv, 7/30/2015 17:18:20, 111378 bytes
| Driver: Syn4FTapActionCenterNB.wmv, 7/30/2015 17:18:20, 108227 bytes
| Driver: Syn4FTapCortana.wmv, 7/30/2015 17:18:20, 114529 bytes
| Driver: Syn4FTapCortanaNB.wmv, 7/30/2015 17:18:20, 111378 bytes
| Driver: Syn3FClickActionCenterNB.wmv, 7/30/2015 17:18:19, 139737 bytes
| Driver: Syn3FClickCortanaNB.wmv, 7/30/2015 17:18:19, 149190 bytes
| Driver: Syn4FClickActionCenterNB.wmv, 7/30/2015 17:18:20, 158643 bytes
| Driver: Syn4FClickCortanaNB.wmv, 7/30/2015 17:18:20, 164945 bytes
| Driver: Syn3FVSlide.wmv, 7/30/2015 17:18:20, 476954 bytes
| Driver: Syn3FVSlideNB.wmv, 7/30/2015 17:18:20, 372971 bytes
| Driver: dpinst.exe, 7/30/2015 17:18:18, 1056968 bytes
| Driver: SynSmbDrv.ini, 7/30/2015 17:18:24, 6087 bytes
| Driver: SynLinearVScroll.mpg, 5/24/2015 13:14:44, 518694 bytes
| Driver: SynWingGesture.wmv, 7/30/2015 17:18:30, 305841 bytes
| Driver: SynWingGesture.html, 7/30/2015 17:18:29, 3164 bytes
| Driver: Syn2FingerTappingNB.wmv, 7/30/2015 17:18:19, 101711 bytes
| Driver: Syn2FingerTapping.html, 7/30/2015 17:18:19, 3214 bytes
| Driver: Syn3FingerTapping.html, 7/30/2015 17:18:20, 3214 bytes
| Driver: Syn4FingerTapping.html, 7/30/2015 17:18:20, 3214 bytes
| Driver: Ckp2FingerScrolling.mpg, 5/24/2015 13:14:39, 382935 bytes
| Driver: Ckp3FingerDown.mpg, 5/24/2015 13:14:39, 153456 bytes
| Driver: Ckp3FingerFlick.mpg, 5/24/2015 13:14:39, 569095 bytes
| Driver: CkpChiralMotion.mpg, 5/24/2015 13:14:39, 420858 bytes
| Driver: CkpClickDrag.mpg, 5/24/2015 13:14:39, 271447 bytes
| Driver: CkpLinearScroll.mpg, 5/24/2015 13:14:39, 427998 bytes
| Driver: CkpLRClick.mpg, 5/24/2015 13:14:39, 284073 bytes
| Driver: CkpMomentum.mpg, 5/24/2015 13:14:39, 328085 bytes
| Driver: CkpPinch.mpg, 5/24/2015 13:14:39, 309339 bytes
| Driver: CkpPivotRotate.mpg, 5/24/2015 13:14:39, 605893 bytes
| Driver: CkpPivotRotate2.mpg, 5/24/2015 13:14:39, 779912 bytes
| Driver: CkpTouchpadDisable.mpg, 5/24/2015 13:14:39, 293736 bytes
| Driver: SynCom.dll, 7/30/2015 17:18:21, 419528 bytes
| Driver: SynTPCo31.dll, 7/30/2015 17:18:25, 255688 bytes
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 633.4 GB
Total Space: 695.5 GB
File System: NTFS
Model: Hitachi HTS547575A9E384 ATA Device
Drive: D:
Free Space: 1.7 GB
Total Space: 15.7 GB
File System: NTFS
Drive: E:
Free Space: 0.0 GB
Total Space: 4.1 GB
File System: FAT32
Drive: F:
Model: hp CDDVDW TS-L633R ATA Device
Driver: c:\windows\system32\drivers\cdrom.sys, 10.00.10240.16384 (English), 7/10/2015 06:59:39, 174080 bytes
System Devices
Name: PCI standard host CPU bridge
Device ID: PCI\VEN_1022&DEV_1700&SUBSYS_00000000&REV_43\3&2411E6FE&3&C0
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1709&SUBSYS_12341022&REV_00\3&2411E6FE&3&20
Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 10.00.10240.16390 (English), 7/14/2015 22:49:52, 325984 bytes
Device ID: PCI\VEN_1022&DEV_43A1&SUBSYS_00001022&REV_00\3&2411E6FE&3&A9
Name: PCI standard ISA bridge
Device ID: PCI\VEN_1022&DEV_780E&SUBSYS_169B103C&REV_11\3&2411E6FE&3&A3
Driver: C:\WINDOWS\system32\DRIVERS\msisadrv.sys, 10.00.10240.16384 (English), 7/10/2015 06:59:38, 19296 bytes
Device ID: PCI\VEN_1022&DEV_780F&SUBSYS_00000000&REV_40\3&2411E6FE&3&A4
Device ID: PCI\VEN_1022&DEV_1701&SUBSYS_00000000&REV_00\3&2411E6FE&3&C1
Driver: n/a
Name: Standard Enhanced PCI to USB Host Controller
Device ID: PCI\VEN_1022&DEV_7808&SUBSYS_169B103C&REV_11\3&2411E6FE&3&9A
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 10.00.10240.16384 (English), 7/10/2015 06:59:39, 95584 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 10.00.10240.16384 (English), 7/10/2015 06:59:39, 457056 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 10.00.10240.16401 (English), 7/23/2015 23:30:58, 498016 bytes
Device ID: PCI\VEN_1022&DEV_7808&SUBSYS_169B103C&REV_11\3&2411E6FE&3&92
Device ID: PCI\VEN_1022&DEV_1704&SUBSYS_00000000&REV_00\3&2411E6FE&3&C4
Driver: n/a
Device ID: PCI\VEN_1022&DEV_780B&SUBSYS_169B103C&REV_13\3&2411E6FE&3&A0
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1718&SUBSYS_00000000&REV_00\3&2411E6FE&3&C5
Driver: n/a
Name: Realtek PCIe FE Family Controller
Device ID: PCI\VEN_10EC&DEV_8136&SUBSYS_169B103C&REV_05\4&39FB9FE0&0&0020
Driver: C:\WINDOWS\system32\DRIVERS\rt640x64.sys, 9.01.0401.2015 (English), 7/10/2015 06:59:39, 587264 bytes
Device ID: PCI\VEN_1022&DEV_1705&SUBSYS_169B103C&REV_00\3&2411E6FE&3&00
Driver: n/a
Device ID: PCI\VEN_1022&DEV_43A2&SUBSYS_00001022&REV_00\3&2411E6FE&3&AA
Device ID: PCI\VEN_1022&DEV_1702&SUBSYS_00000000&REV_00\3&2411E6FE&3&C2
Driver: n/a
Name: Standard Dual Channel PCI IDE Controller
Device ID: PCI\VEN_1022&DEV_7800&SUBSYS_169B103C&REV_00\3&2411E6FE&3&88
Driver: C:\WINDOWS\system32\DRIVERS\pciide.sys, 10.00.10240.16384 (English), 7/10/2015 06:59:39, 15712 bytes
Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 10.00.10240.16384 (English), 7/10/2015 06:59:39, 51552 bytes
Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 10.00.10240.16384 (English), 7/10/2015 06:59:39, 28512 bytes
Driver: C:\WINDOWS\system32\DRIVERS\ataport.sys, 10.00.10240.16384 (English), 7/10/2015 06:59:39, 192864 bytes
Device ID: PCI\VEN_1022&DEV_1716&SUBSYS_00000000&REV_00\3&2411E6FE&3&C6
Driver: n/a
Device ID: PCI\VEN_1022&DEV_43A0&SUBSYS_00001022&REV_00\3&2411E6FE&3&A8
Name: High Definition Audio Controller
Device ID: PCI\VEN_1022&DEV_780D&SUBSYS_169B103C&REV_01\3&2411E6FE&3&A2
Driver: C:\WINDOWS\system32\DRIVERS\hdaudbus.sys, 10.00.10240.16384 (English), 7/10/2015 06:59:36, 80896 bytes
Driver: C:\WINDOWS\system32\drivers\drmk.sys, 10.00.10240.16384 (English), 7/10/2015 06:59:36, 96768 bytes
Driver: C:\WINDOWS\system32\drivers\portcls.sys, 10.00.10240.16384 (English), 7/10/2015 06:59:36, 320512 bytes
Name: Realtek PCIE CardReader
Device ID: PCI\VEN_10EC&DEV_5209&SUBSYS_169B103C&REV_01\4&42C02CE&0&00AA
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1719&SUBSYS_00000000&REV_00\3&2411E6FE&3&C7
Driver: n/a
Name: Atheros AR9485 802.11b/g/n WiFi Adapter
Device ID: PCI\VEN_168C&DEV_0032&SUBSYS_1785103C&REV_01\4&16F9DD14&0&00A9
Driver: C:\WINDOWS\system32\DRIVERS\athwbx.sys, 10.00.0000.0263 (English), 8/7/2015 15:06:32, 3859968 bytes
Driver: C:\WINDOWS\system32\DRIVERS\vwifibus.sys, 10.00.10240.16384 (English), 7/10/2015 06:59:52, 26112 bytes
Name: High Definition Audio Bus
Device ID: PCI\VEN_1002&DEV_1714&SUBSYS_17141002&REV_00\3&2411E6FE&3&09
Driver: C:\WINDOWS\system32\DRIVERS\amdkmafd.sys, 8.14.0001.6003 (English), 6/3/2015 09:35:36, 31992 bytes
Name: Standard OpenHCD USB Host Controller
Device ID: PCI\VEN_1022&DEV_7807&SUBSYS_169B103C&REV_11\3&2411E6FE&3&98
Driver: C:\WINDOWS\system32\drivers\usbohci.sys, 10.00.10240.16384 (English), 7/10/2015 06:59:39, 29184 bytes
Device ID: PCI\VEN_1022&DEV_7807&SUBSYS_169B103C&REV_11\3&2411E6FE&3&90
Name: AMD Radeon HD 6520G
Device ID: PCI\VEN_1002&DEV_9647&SUBSYS_169B103C&REV_00\3&2411E6FE&3&08
Driver: C:\WINDOWS\system32\DRIVERS\atikmdag.sys, 8.01.0001.1500 (English), 8/22/2015 15:21:20, 21632992 bytes
Driver: C:\WINDOWS\system32\DRIVERS\ati2erec.dll, 1.00.0000.0024 (English), 8/22/2015 15:21:04, 53728 bytes
Driver: C:\WINDOWS\system32\atiumd64.dll, 9.14.0010.1128 (English), 8/22/2015 15:21:23, 8867016 bytes
Driver: C:\WINDOWS\system32\atiumd6a.dll, 8.14.0010.0513 (English), 8/22/2015 15:21:23, 8979760 bytes
Driver: C:\WINDOWS\system32\atitmm64.dll, 6.14.0011.0025 (English), 8/22/2015 15:21:22, 201184 bytes
Driver: C:\WINDOWS\system32\amdpcom64.dll, 8.14.0010.0023 (English), 8/22/2015 15:21:04, 89520 bytes
Driver: C:\WINDOWS\system32\atimpc64.dll, 8.14.0010.0023 (English), 8/22/2015 15:21:20, 88000 bytes
Driver: C:\WINDOWS\system32\atiadlxx.dll, 7.15.0020.1301 (English), 8/22/2015 15:21:04, 1257952 bytes
Driver: C:\WINDOWS\system32\atiumd6a.cap, 8/22/2015 15:21:23, 3437632 bytes
Driver: C:\WINDOWS\system32\atimuixx.dll, 6.14.0010.1002 (English), 8/22/2015 15:21:20, 38384 bytes
Driver: C:\WINDOWS\system32\atiapfxx.exe, 6.14.0010.1001 (English), 8/22/2015 15:21:05, 377312 bytes
Driver: C:\WINDOWS\system32\ativvsva.dat, 7/30/2015 14:03:58, 157144 bytes
Driver: C:\WINDOWS\system32\ativvsvl.dat, 7/30/2015 14:03:58, 204952 bytes
Driver: C:\WINDOWS\system32\ativvaxy_cik.dat, 7/30/2015 14:03:57, 234420 bytes
Driver: C:\WINDOWS\system32\ativvaxy_cik_nd.dat, 7/30/2015 14:03:57, 232752 bytes
Driver: C:\WINDOWS\system32\ativce02.dat, 7/30/2015 14:03:57, 100816 bytes
Driver: C:\WINDOWS\system32\amdmmcl6.dll, 1.06.0000.0000 (English), 8/22/2015 15:20:47, 60896 bytes
Driver: C:\WINDOWS\system32\atiesrxx.exe, 6.14.0011.1199 (English), 8/22/2015 15:21:18, 255472 bytes
Driver: C:\WINDOWS\system32\atieclxx.exe, 6.14.0011.1199 (English), 8/22/2015 15:21:17, 681456 bytes
Driver: C:\WINDOWS\system32\atidemgy.dll, 4.05.5693.26310 (English), 8/22/2015 15:21:12, 451056 bytes
Driver: C:\WINDOWS\system32\atio6axx.dll, 6.14.0010.13399 (English), 8/22/2015 15:21:21, 30762464 bytes
Driver: C:\WINDOWS\system32\aticalrt64.dll, 6.14.0010.1848 (English), 8/22/2015 15:21:12, 71152 bytes
Driver: C:\WINDOWS\system32\aticalcl64.dll, 6.14.0010.1848 (English), 8/22/2015 15:21:05, 64496 bytes
Driver: C:\WINDOWS\system32\aticaldd64.dll, 6.14.0010.1848 (English), 8/22/2015 15:21:12, 15725552 bytes
Driver: C:\WINDOWS\system32\atiapfxx.blb, 8/22/2015 15:21:05, 660928 bytes
Driver: C:\WINDOWS\system32\amdmiracast.dll, 8/22/2015 15:20:47, 472832 bytes
Driver: C:\WINDOWS\system32\amdhdl64.dll, 8/22/2015 15:20:45, 143344 bytes
Driver: C:\WINDOWS\system32\hsa-thunk64.dll, 8/22/2015 15:21:43, 113120 bytes
Driver: C:\WINDOWS\system32\amdmantle64.dll, 9.01.0010.0077 (English), 8/22/2015 15:20:47, 6486000 bytes
Driver: C:\WINDOWS\system32\mantle64.dll, 9.01.0010.0077 (English), 8/22/2015 15:21:43, 137696 bytes
Driver: C:\WINDOWS\system32\mantleaxl64.dll, 9.01.0010.0077 (English), 8/22/2015 15:21:43, 103904 bytes
Driver: C:\WINDOWS\system32\ativce03.dat, 7/30/2015 14:03:57, 169152 bytes
Driver: C:\WINDOWS\system32\ativvaxy_vi.dat, 7/30/2015 14:03:58, 322868 bytes
Driver: C:\WINDOWS\system32\ativvaxy_vi_nd.dat, 7/30/2015 14:03:58, 321200 bytes
Driver: C:\WINDOWS\system32\ativvaxy_cz_nd.dat, 7/30/2015 14:03:58, 255808 bytes
Driver: C:\WINDOWS\system32\amde31a.dat, 7/30/2015 14:03:47, 167456 bytes
Driver: C:\WINDOWS\system32\detoured.dll, 2.01.0000.0207 (English), 8/22/2015 15:21:43, 14304 bytes
Driver: C:\WINDOWS\system32\amdgfxinfo64.dll, 8/22/2015 15:20:45, 213488 bytes
Driver: C:\WINDOWS\system32\atieah64.exe, 8/22/2015 15:21:17, 168944 bytes
Driver: C:\WINDOWS\system32\ativvaxy_FJ.dat, 7/30/2015 14:03:58, 250884 bytes
Driver: C:\WINDOWS\system32\ativvaxy_FJ_nd.dat, 7/30/2015 14:03:58, 249088 bytes
Driver: C:\WINDOWS\system32\amdocl12cl64.dll, 0.08.0000.0000 (English), 8/22/2015 15:21:00, 27544560 bytes
Driver: C:\WINDOWS\system32\amdicdxx.dat, 7/30/2015 14:03:48, 833798 bytes
Driver: C:\WINDOWS\system32\atiicdxx.dat, 7/30/2015 14:03:55, 737410 bytes
Driver: C:\WINDOWS\system32\atidxx64.dll, 8.17.0010.0625 (English), 8/22/2015 15:21:17, 12063560 bytes
Driver: C:\WINDOWS\SysWOW64\atiumdag.dll, 9.14.0010.1128 (English), 8/22/2015 15:21:23, 7484080 bytes
Driver: C:\WINDOWS\SysWOW64\atiumdva.dll, 8.14.0010.0513 (English), 8/22/2015 15:21:26, 8009344 bytes
Driver: C:\WINDOWS\SysWOW64\amdpcom32.dll, 8.14.0010.0023 (English), 8/22/2015 15:21:04, 82680 bytes
Driver: C:\WINDOWS\SysWOW64\atimpc32.dll, 8.14.0010.0023 (English), 8/22/2015 15:21:20, 82680 bytes
Driver: C:\WINDOWS\SysWOW64\atiadlxy.dll, 7.15.0020.1301 (English), 8/22/2015 15:21:05, 935408 bytes
Driver: C:\WINDOWS\SysWOW64\atiadlxx.dll, 7.15.0020.1301 (English), 8/22/2015 15:21:05, 935408 bytes
Driver: C:\WINDOWS\SysWOW64\atiumdva.cap, 8/22/2015 15:21:25, 3471376 bytes
Driver: C:\WINDOWS\SysWOW64\ativvsva.dat, 7/30/2015 14:03:58, 157144 bytes
Driver: C:\WINDOWS\SysWOW64\ativvsvl.dat, 7/30/2015 14:03:58, 204952 bytes
Driver: C:\WINDOWS\SysWOW64\amdmmcl.dll, 1.06.0000.0000 (English), 8/22/2015 15:20:47, 48112 bytes
Driver: C:\WINDOWS\SysWOW64\atioglxx.dll, 6.14.0010.13399 (English), 8/22/2015 15:21:22, 25310176 bytes
Driver: C:\WINDOWS\SysWOW64\atidxx32.dll, 8.17.0010.0625 (English), 8/22/2015 15:21:15, 10192776 bytes
Driver: C:\WINDOWS\SysWOW64\aticalrt.dll, 6.14.0010.1848 (English), 8/22/2015 15:21:12, 60912 bytes
Driver: C:\WINDOWS\SysWOW64\aticalcl.dll, 6.14.0010.1848 (English), 8/22/2015 15:21:05, 57840 bytes
Driver: C:\WINDOWS\SysWOW64\aticaldd.dll, 6.14.0010.1848 (English), 8/22/2015 15:21:08, 14310896 bytes
Driver: C:\WINDOWS\SysWOW64\atiapfxx.blb, 8/22/2015 15:21:05, 660928 bytes
Driver: C:\WINDOWS\SysWOW64\amdhdl32.dll, 8/22/2015 15:20:45, 132080 bytes
Driver: C:\WINDOWS\SysWOW64\hsa-thunk.dll, 8/22/2015 15:21:43, 112608 bytes
Driver: C:\WINDOWS\SysWOW64\amdmantle32.dll, 9.01.0010.0077 (English), 8/22/2015 15:20:46, 5076976 bytes
Driver: C:\WINDOWS\SysWOW64\mantle32.dll, 9.01.0010.0077 (English), 8/22/2015 15:21:43, 123872 bytes
Driver: C:\WINDOWS\SysWOW64\mantleaxl32.dll, 9.01.0010.0077 (English), 8/22/2015 15:21:43, 96736 bytes
Driver: C:\WINDOWS\SysWOW64\detoured.dll, 2.01.0000.0207 (English), 8/22/2015 15:21:43, 14304 bytes
Driver: C:\WINDOWS\SysWOW64\amdgfxinfo32.dll, 8/22/2015 15:20:45, 198640 bytes
Driver: C:\WINDOWS\SysWOW64\atieah32.exe, 8/22/2015 15:21:17, 152560 bytes
Driver: C:\WINDOWS\SysWOW64\amdocl12cl.dll, 0.08.0000.0000 (English), 8/22/2015 15:20:56, 22328800 bytes
Driver: C:\WINDOWS\system32\ATIODCLI.exe, 1.00.0000.0001 (English), 8/22/2015 15:21:21, 61408 bytes
Driver: C:\WINDOWS\system32\ATIODE.exe, 1.00.0000.0001 (English), 8/22/2015 15:21:21, 343008 bytes
Driver: C:\WINDOWS\system32\DRIVERS\atikmpag.sys, 8.14.0001.6463 (English), 8/22/2015 15:21:20, 673776 bytes
Driver: C:\WINDOWS\system32\atiu9p64.dll, 8.14.0001.6463 (English), 8/22/2015 15:21:22, 130072 bytes
Driver: C:\WINDOWS\system32\atiuxp64.dll, 8.14.0001.6463 (English), 8/22/2015 15:21:27, 162240 bytes
Driver: C:\WINDOWS\system32\atig6txx.dll, 8.14.0001.6463 (English), 8/22/2015 15:21:18, 165360 bytes
Driver: C:\WINDOWS\system32\atiglpxx.dll, 8.14.0001.6463 (English), 8/22/2015 15:21:18, 78320 bytes
Driver: C:\WINDOWS\system32\aticfx64.dll, 8.17.0010.1404 (English), 8/22/2015 15:21:12, 1466712 bytes
Driver: C:\WINDOWS\SysWOW64\aticfx32.dll, 8.17.0010.1404 (English), 8/22/2015 15:21:12, 1214712 bytes
Driver: C:\Program Files\AMD\CCC2\Install\ccc2_install.exe, 8.97.0100.0300 (English), 8/22/2015 15:21:43, 96556024 bytes
Driver: C:\WINDOWS\system32\OpenCL.dll, 2.00.0004.0000 (English), 8/22/2015 15:21:04, 73712 bytes
Driver: C:\WINDOWS\system32\amdocl64.dll, 10.00.1800.0008 (English), 8/22/2015 15:21:03, 47794160 bytes
Driver: C:\WINDOWS\system32\amdocl_as64.exe, 8/22/2015 15:21:03, 1197552 bytes
Driver: C:\WINDOWS\system32\amdocl_ld64.exe, 8/22/2015 15:21:03, 1070592 bytes
Driver: C:\WINDOWS\system32\clinfo.exe, 8/22/2015 15:21:43, 245216 bytes
Driver: C:\WINDOWS\SysWOW64\OpenCL.dll, 2.00.0004.0000 (English), 8/22/2015 15:21:04, 68080 bytes
Driver: C:\WINDOWS\SysWOW64\amdocl.dll, 10.00.1800.0008 (English), 8/22/2015 15:20:51, 39725024 bytes
Driver: C:\WINDOWS\SysWOW64\amdocl_as32.exe, 8/22/2015 15:21:03, 1005552 bytes
Driver: C:\WINDOWS\SysWOW64\amdocl_ld32.exe, 8/22/2015 15:21:03, 808944 bytes
Driver: C:\Program Files\AMD\amdkmpfd\amdkmpfd.sbz, 8.14.0001.6028 (English), 8/22/2015 15:20:45, 73968 bytes
Driver: C:\Program Files\AMD\amdkmpfd\amdkmpfd.ibz, 8/22/2015 15:20:45, 1988 bytes
Driver: C:\Program Files\AMD\amdkmpfd\amdkmpfd.cbz, 8/22/2015 15:20:45, 9788 bytes
Driver: C:\WINDOWS\system32\atig6pxx.dll, 8.14.0001.6463 (English), 8/22/2015 15:21:18, 83952 bytes
Driver: C:\WINDOWS\SysWOW64\atiu9pag.dll, 8.14.0001.6463 (English), 8/22/2015 15:21:22, 112368 bytes
Driver: C:\WINDOWS\SysWOW64\atiuxpag.dll, 8.14.0001.6463 (English), 8/22/2015 15:21:27, 143056 bytes
Driver: C:\WINDOWS\SysWOW64\atigktxx.dll, 8.14.0001.6463 (English), 8/22/2015 15:21:18, 150512 bytes
Driver: C:\WINDOWS\SysWOW64\atiglpxx.dll, 8.14.0001.6463 (English), 8/22/2015 15:21:18, 78320 bytes
Driver: C:\WINDOWS\system32\coinst_15.20.dll, 1.00.0005.0009 (English), 8/22/2015 15:21:43, 876000 bytes
Device ID: PCI\VEN_1022&DEV_1703&SUBSYS_00000000&REV_00\3&2411E6FE&3&C3
Driver: n/a
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,10.00.10240.16384
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,10.00.10240.16384
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,10.00.10240.16384
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,10.00.10240.16384
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,10.00.10240.16384
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,10.00.10240.16384
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,10.00.10240.16384
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,10.00.10240.16384
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,10.00.10240.16384
DV Muxer,0x00400000,0,0,qdv.dll,10.00.10240.16384
Color Space Converter,0x00400001,1,1,quartz.dll,10.00.10240.16384
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.10240.16384
AVI Splitter,0x00600000,1,1,quartz.dll,10.00.10240.16384
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,10.00.10240.16384
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,10.00.10240.16384
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,12.00.10132.0000
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,10.00.10240.16384
StreamBufferSink,0x00200000,0,0,sbe.dll,10.00.10240.16384
MJPEG Decompressor,0x00600000,1,1,quartz.dll,10.00.10240.16384
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,10.00.10240.16384
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,10.00.10240.16384
VBI Codec,0x00600000,1,4,VBICodec.ax,10.00.10240.16384
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,10.00.10240.16384
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,10.00.10240.16384
SBE2FileScan,0x00200000,0,0,sbe.dll,10.00.10240.16384
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,12.00.10240.16384
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,10.00.10240.16384
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,10.00.10240.16384
DV Splitter,0x00600000,1,2,qdv.dll,10.00.10240.16384
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,10.00.10240.16384
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,12.00.10240.16384
ACM Wrapper,0x00600000,1,1,quartz.dll,10.00.10240.16384
Video Renderer,0x00800001,1,0,quartz.dll,10.00.10240.16384
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,10.00.10240.16384
Line 21 Decoder,0x00600000,1,1,,
Video Port Manager,0x00600000,2,1,quartz.dll,10.00.10240.16384
Video Renderer,0x00400000,1,0,quartz.dll,10.00.10240.16384
VPS Decoder,0x00200000,0,0,WSTPager.ax,10.00.10240.16384
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.10240.16384
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,10.00.10240.16384
File writer,0x00200000,1,0,qcap.dll,10.00.10240.16384
DVD Navigator,0x00200000,0,3,qdvd.dll,10.00.10240.16384
Overlay Mixer2,0x00200000,1,1,,
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,12.00.10240.16384
WST Pager,0x00200000,1,1,WSTPager.ax,10.00.10240.16384
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,10.00.10240.16384
DV Video Decoder,0x00800000,1,1,qdv.dll,10.00.10240.16384
SampleGrabber,0x00200000,1,1,qedit.dll,10.00.10240.16384
Null Renderer,0x00200000,1,0,qedit.dll,10.00.10240.16384
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,10.00.10240.16384
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,10.00.10240.16384
StreamBufferSource,0x00200000,0,0,sbe.dll,10.00.10240.16384
Smart Tee,0x00200000,1,2,qcap.dll,10.00.10240.16384
Overlay Mixer,0x00200000,0,0,,
AVI Decompressor,0x00600000,1,1,quartz.dll,10.00.10240.16384
AVI/WAV File Source,0x00400000,0,2,quartz.dll,10.00.10240.16384
Wave Parser,0x00400000,1,1,quartz.dll,10.00.10240.16384
MIDI Parser,0x00400000,1,1,quartz.dll,10.00.10240.16384
Multi-file Parser,0x00400000,1,1,quartz.dll,10.00.10240.16384
File stream renderer,0x00400000,1,1,quartz.dll,10.00.10240.16384
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,12.00.10132.0000
StreamBufferSink2,0x00200000,0,0,sbe.dll,10.00.10240.16384
AVI Mux,0x00200000,1,0,qcap.dll,10.00.10240.16384
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,10.00.10240.16384
File Source (Async.),0x00400000,0,1,quartz.dll,10.00.10240.16384
File Source (URL),0x00400000,0,1,quartz.dll,10.00.10240.16384
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,10.00.10240.16384
Enhanced Video Renderer,0x00200000,1,0,evr.dll,10.00.10240.16384
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,10.00.10240.16384
MPEG Video Decoder,0x40000001,1,1,quartz.dll,10.00.10240.16384
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,10.00.10240.16384
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,10.00.10240.16384
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,10.00.10240.16384
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,10.00.10240.16384
DV Video Encoder,0x00200000,0,0,qdv.dll,10.00.10240.16384
MJPEG Compressor,0x00200000,0,0,quartz.dll,10.00.10240.16384
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,10.00.10240.16384
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,10.00.10240.16384
IMA ADPCM,0x00200000,1,1,quartz.dll,10.00.10240.16384
Microsoft ADPCM,0x00200000,1,1,quartz.dll,10.00.10240.16384
GSM 6.10,0x00200000,1,1,quartz.dll,10.00.10240.16384
CCITT A-Law,0x00200000,1,1,quartz.dll,10.00.10240.16384
CCITT u-Law,0x00200000,1,1,quartz.dll,10.00.10240.16384
MPEG Layer-3,0x00200000,1,1,quartz.dll,10.00.10240.16384
Audio Capture Sources:
Internal Mic (IDT High Definition Audio CODEC),0x00200000,0,0,qcap.dll,10.00.10240.16384
External Mic (IDT High Definition Audio CODEC),0x00200000,0,0,qcap.dll,10.00.10240.16384
Stereo Mix (IDT High Definition Audio CODEC),0x00200000,0,0,qcap.dll,10.00.10240.16384
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,10.00.10240.16384
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,10.00.10240.16384
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,10.00.10240.16384
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,10.00.10240.16384
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,10.00.10240.16384
WDM Streaming Capture Devices:
HP Webcam-101,0x00200000,1,2,ksproxy.ax,10.00.10240.16384
MuxedIn1,0x00200000,1,1,ksproxy.ax,10.00.10240.16384
MuxedIn2,0x00200000,1,1,ksproxy.ax,10.00.10240.16384
,0x00000000,0,0,,
,0x00000000,0,0,,
CyberLink Webcam Splitter,0x00200000,0,1,ksproxy.ax,10.00.10240.16384
WDM Streaming Rendering Devices:
,0x00000000,0,0,,
,0x00000000,0,0,,
HpOut,0x00200000,1,1,ksproxy.ax,10.00.10240.16384
Speaker,0x00200000,1,1,ksproxy.ax,10.00.10240.16384
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.10240.16384
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.10240.16384
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.10240.16384
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.10240.16384
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,10.00.10240.16384
Video Capture Sources:
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,10.00.10240.16384
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,10.00.10240.16384
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,1,EncDec.dll,10.00.10240.16384
Encrypt/Tag,0x00200000,0,0,EncDec.dll,10.00.10240.16384
PTFilter,0x00200000,0,0,EncDec.dll,10.00.10240.16384
XDS Codec,0x00200000,0,0,EncDec.dll,10.00.10240.16384
WDM Streaming Communication Transforms:
Audio Renderers:
Speakers and Headphones (IDT High Definition Audio CODEC),0x00200000,1,0,quartz.dll,10.00.10240.16384
Default DirectSound Device,0x00800000,1,0,quartz.dll,10.00.10240.16384
Default WaveOut Device,0x00200000,1,0,quartz.dll,10.00.10240.16384
DirectSound: Speakers and Headphones (IDT High Definition Audio CODEC),0x00200000,1,0,quartz.dll,10.00.10240.16384
DirectSound: Communications Headphones (IDT High Definition Audio CODEC),0x00200000,1,0,quartz.dll,10.00.10240.16384
Preferred DirectShow Filters
[HKEY_LOCAL_MACHINE\Software\Microsoft\DirectShow\Preferred]
<media subtype GUID>, [<filter friendly name>, ]<filter CLSID>
MEDIASUBTYPE_MPEG1Payload, MPEG Video Decoder, CLSID_CMpegVideoCodec
MEDIASUBTYPE_MPEG1Packet, MPEG Video Decoder, CLSID_CMpegVideoCodec
MEDIASUBTYPE_DVD_LPCM_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG2_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG2_VIDEO, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
{78766964-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_mp4s, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{6C737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{64737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{64697678-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{64687664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{58564944-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{5634504D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_MP4S, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMVR, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVP, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MJPG, MJPEG Decompressor, CLSID_MjpegDec
{44495658-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMVA, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mpg4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MPG4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_h264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_H264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_WMV3, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_MP43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_m4s2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMV2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MSS2, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
MEDIASUBTYPE_M4S2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WVP2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MP42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_WMV1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MSS1, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
MEDIASUBTYPE_WVC1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_AVC1, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
{20637664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
MEDIASUBTYPE_MPEG_LOAS, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG_ADTS_AAC, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_WMAUDIO_LOSSLESS, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_WMAUDIO3, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
WMMEDIASUBTYPE_WMAudioV8, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_RAW_AAC1, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
WMMEDIASUBTYPE_MP3, MP3 Decoder DMO, CLSID_CMP3DecMediaObject
MEDIASUBTYPE_MPEG1AudioPayload, MPEG Audio Decoder, CLSID_CMpegAudioCodec
WMMEDIASUBTYPE_WMSP2, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
WMMEDIASUBTYPE_WMSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms]
<category>:
<transform friendly name>, <transform CLSID>, <flags>, [<merit>, ]<file name>, <file version>
Video Decoders:
Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}, 0x1, msmpeg2vdec.dll, 12.00.10132.0000
DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}, 0x1, mfdvdec.dll, 10.00.10240.16384
Microsoft H265 Video Decoder MFT, {420A51A3-D605-430C-B4FC-45274FA6C562}, 0x1, hevcdecoder.dll, 10.00.10240.16384
Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT, 0x1, mp4sdecd.dll, 10.00.10240.16384
Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT, 0x1, msmpeg2vdec.dll, 12.00.10132.0000
WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject, 0x1, wmvsdecd.dll, 10.00.10240.16384
WMVideo Decoder MFT, CLSID_CWMVDecMediaObject, 0x1, wmvdecod.dll, 10.00.10240.16384
MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}, 0x1, mfmjpegdec.dll, 10.00.10240.16384
Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject, 0x1, mp43decd.dll, 10.00.10240.16384
Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject, 0x1, mpg4decd.dll, 10.00.10240.16384
Video Encoders:
H264 Encoder MFT, {6CA50344-051A-4DED-9779-A43305165E35}, 0x1, mfh264enc.dll, 10.00.10240.16384
WMVideo8 Encoder MFT, CLSID_CWMVXEncMediaObject, 0x1, wmvxencd.dll, 10.00.10240.16384
H263 Encoder MFT, {BC47FCFE-98A0-4F27-BB07-698AF24F2B38}, 0x1, mfh263enc.dll, 10.00.10240.16384
WMVideo9 Encoder MFT, CLSID_CWMV9EncMediaObject, 0x1, wmvencod.dll, 10.00.10240.16384
Microsoft MPEG-2 Video Encoder MFT, {E6335F02-80B7-4DC4-ADFA-DFE7210D20D5}, 0x2, msmpeg2enc.dll, 12.00.10240.16384
H265 Encoder MFT, {F2F84074-8BCA-40BD-9159-E880F673DD3B}, 0x1, mfh265enc.dll, 10.00.10240.16384
Video Effects:
Frame Rate Converter, CLSID_CFrameRateConvertDmo, 0x1, mfvdsp.dll, 10.00.10240.16384
Resizer MFT, CLSID_CResizerDMO, 0x1, vidreszr.dll, 10.00.10240.16384
VideoStabilization MFT, {51571744-7FE4-4FF2-A498-2DC34FF74F1B}, 0x1, MSVideoDSP.dll, 10.00.10240.16384
Color Control, CLSID_CColorControlDmo, 0x1, mfvdsp.dll, 10.00.10240.16384
Color Converter MFT, CLSID_CColorConvertDMO, 0x1, colorcnv.dll, 10.00.10240.16384
Video Processor:
Microsoft Video Processor MFT, {88753B26-5B24-49BD-B2E7-0C445C78C982}, 0x1, msvproc.dll, 12.00.10240.16384
Audio Decoders:
Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}, 0x1, DolbyDecMFT.dll, 10.00.10240.16384
MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}, 0x1, MSAMRNBDecoder.dll, 10.00.10240.16384
WMAudio Decoder MFT, CLSID_CWMADecMediaObject, 0x1, WMADMOD.DLL, 10.00.10240.16384
Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT, 0x1, MSAudDecMFT.dll, 10.00.10240.16384
A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}, 0x1, mfcore.dll, 12.00.10240.16431
GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}, 0x1, mfcore.dll, 12.00.10240.16431
WMAPro over S/PDIF MFT, CLSID_CWMAudioSpdTxDMO, 0x1, WMADMOD.DLL, 10.00.10240.16384
Microsoft FLAC Audio Decoder MFT, {6B0B3E6B-A2C5-4514-8055-AFE8A95242D9}, 0x1, MSFlacDecoder.dll, 10.00.10240.16384
Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}, 0x1, MSAudDecMFT.dll, 10.00.10240.16384
WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject, 0x1, WMSPDMOD.DLL, 10.00.10240.16384
G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}, 0x1, mfcore.dll, 12.00.10240.16431
IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}, 0x1, mfcore.dll, 12.00.10240.16431
MP3 Decoder MFT, CLSID_CMP3DecMediaObject, 0x1, mp3dmod.dll, 10.00.10240.16384
Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}, 0x1, MSAlacDecoder.dll, 10.00.10240.16384
ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}, 0x1, mfcore.dll, 12.00.10240.16431
Audio Encoders:
LPCM DVD-Audio MFT, {068A8476-9229-4CC0-9D49-2FC699DCD30A}, 0x1, winmde.dll, 12.00.10240.16412
MP3 Encoder ACM Wrapper MFT, {11103421-354C-4CCA-A7A3-1AFF9A5B6701}, 0x1, mfcore.dll, 12.00.10240.16431
Microsoft FLAC Audio Encoder MFT, {128509E9-C44E-45DC-95E9-C255B8F466A6}, 0x1, MSFlacEncoder.dll, 10.00.10240.16384
WM Speech Encoder DMO, CLSID_CWMSPEncMediaObject2, 0x1, WMSPDMOE.DLL, 10.00.10240.16384
MS AMRNB Encoder MFT, {2FAE8AFE-04A3-423A-A814-85DB454712B0}, 0x1, MSAMRNBEncoder.dll, 10.00.10240.16384
Microsoft MPEG-2 Audio Encoder MFT, {46A4DD5C-73F8-4304-94DF-308F760974F4}, 0x1, msmpeg2enc.dll, 12.00.10240.16384
WMAudio Encoder MFT, CLSID_CWMAEncMediaObject, 0x1, WMADMOE.DLL, 10.00.10240.16384
Microsoft AAC Audio Encoder MFT, {93AF0C51-2275-45D2-A35B-F2BA21CAED00}, 0x1, mfAACEnc.dll, 10.00.10240.16384
Microsoft ALAC Audio Encoder MFT, {9AB6A28C-748E-4B6A-BFFF-CC443B8E8FB4}, 0x1, MSAlacEncoder.dll, 10.00.10240.16384
Microsoft Dolby Digital Encoder MFT, {AC3315C9-F481-45D7-826C-0B406C1F64B8}, 0x1, msac3enc.dll, 10.00.10240.16384
Audio Effects:
AEC, CLSID_CWMAudioAEC, 0x1, mfwmaaec.dll, 10.00.10240.16384
Resampler MFT, CLSID_CResamplerMediaObject, 0x1, resampledmo.dll, 10.00.10240.16384
Multiplexers:
Microsoft MPEG2 Multiplexer MFT, {AB300F71-01AB-46D2-AB6C-64906CB03258}, 0x2, mfmpeg2srcsnk.dll, 12.00.10240.16412
Others:
Microsoft H264 Video Remux (MPEG2TSToMP4) MFT, {05A47EBB-8BF0-4CBF-AD2F-3B71D75866F5}, 0x1, msmpeg2vdec.dll, 12.00.10132.0000
Media Foundation Enabled Hardware Categories
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\HardwareMFT]
EnableDecoders = 1
EnableEncoders = 1
EnableVideoProcessors = 1
Media Foundation Byte Stream Handlers
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\ByteStreamHandlers]
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\Preferred]
<file ext. or MIME type>, <handler CLSID>, <brief description>[, Preferred]
.3g2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.ac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
.adt, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.am?, {EFE6208A-0A2C-49FA-8A01-3768B559B6DA}, MF AMRNB Media Source ByteStreamHandler
.amr, {EFE6208A-0A2C-49FA-8A01-3768B559B6DA}, MF AMRNB Media Source ByteStreamHandler, Preferred
.asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
.dvr-ms, {65964407-A5D8-4060-85B0-1CCD63F768E2}, dvr-ms Byte Stream Handler, Preferred
.dvr-ms, {A8721937-E2FB-4D7A-A9EE-4EB08C890B6E}, MF SBE Source ByteStreamHandler
.ec3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
.flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
.m2t, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.m2ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mk3d, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mka, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mks, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mkv, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mov, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mp2v, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mp4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
.mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mpg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.nsc, {B084785C-DDE0-4D30-8CA8-05A373E185BE}, NSC Byte Stream Handler, Preferred
.sami, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
.smi, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
.tod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.uvu, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.vob, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
.wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wtv, {65964407-A5D8-4060-85B0-1CCD63F768E2}, WTV Byte Stream Handler, Preferred
audio/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/aacp, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/eac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
audio/L16, {3FFB3B8C-EB99-472B-8902-E1C1B05F07CF}, LPCM Byte Stream Handler, Preferred
audio/mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/MP4A-LATM, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mpeg3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/vnd.dlna.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/vnd.dolby.dd-raw, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
audio/wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
audio/x-aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/x-m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/x-matroska, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
audio/x-mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/x-mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/x-ms-wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
audio/x-wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
video/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
video/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
video/msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
video/vnd.dece.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/vnd.dlna.mpeg-tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
video/x-m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/x-matroska, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
video/x-ms-asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-ms-wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-ms-wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
Media Foundation Scheme Handlers
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\SchemeHandlers]
<URL type>, <handler CLSID>, <brief description>[, Preferred]
file:, {477EC299-1421-4BDD-971F-7CCB933F21AD}, File Scheme Handler, Preferred
http:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler
http:, {9EC4B4F9-3029-45AD-947B-344DE2A249E2}, Urlmon Scheme Handler
http:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
httpd:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler, Preferred
httpnd:, {2EEEED04-0908-4CDB-AF8F-AC5B768A34C9}, Drm Scheme Handler, Preferred
https:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
httpsd:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
httpt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
httpu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
mcast:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
mcrecv:, {FA6D33D4-9405-4BA5-9983-12604AC8E77A}, Miracast Sink Scheme Handler, Preferred
mms:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
ms-appdata:, {CFC81939-3886-4ACF-9692-DA58037AE716}, MsAppData Scheme Handler, Preferred
ms-appx-web:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppxWeb Scheme Handler, Preferred
ms-appx:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppx Scheme Handler, Preferred
ms-winsoundevent:, {F79A6BF9-7415-4CF3-AE10-4559509ABC3C}, Sound Event Scheme Handler, Preferred
rtsp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtspt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtspu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
sdp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
Preferred Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\Preferred]
<media subtype GUID>, [<transform friendly name>, ]<transform CLSID>
{E06D802C-DB46-11CF-B4D1-00805F6CBBEA}, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
MFVideoFormat_MPEG2, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
MEDIASUBTYPE_DOLBY_DDPLUS, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
{7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{73616D72-767A-494D-B478-F29D25DC9037}, MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}
MEDIASUBTYPE_mp4s, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_DVSL, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_DVSD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_DVHD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
{63616C61-0000-0010-8000-00AA00389B71}, Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}
MFVideoFormat_MP4V, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{53564548-0000-0010-8000-00AA00389B71}, Microsoft H265 Video Decoder MFT, {420A51A3-D605-430C-B4FC-45274FA6C562}
MFVideoFormat_MP4S, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{53314356-0000-0010-8000-00AA00389B71}, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVR, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVP, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MJPG, MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}
{43564548-0000-0010-8000-00AA00389B71}, Microsoft H265 Video Decoder MFT, {420A51A3-D605-430C-B4FC-45274FA6C562}
MEDIASUBTYPE_WMVA, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{3F40F4F0-5622-4FF8-B6D8-A17A584BEE5E}, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
MEDIASUBTYPE_mpg4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MPG4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MFVideoFormat_H264, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
MFVideoFormat_WMV3, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{33363248-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MEDIASUBTYPE_mp43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
MFVideoFormat_MP43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_m4s2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_WMV2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MSS2, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
MFVideoFormat_M4S2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MEDIASUBTYPE_WVP2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MP42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MFVideoFormat_WMV1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MSS1, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
MFVideoFormat_MPG1, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
MFVideoFormat_WVC1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_DVC, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
{0000F1AC-0000-0010-8000-00AA00389B71}, Microsoft FLAC Audio Decoder MFT, {6B0B3E6B-A2C5-4514-8055-AFE8A95242D9}
{00007361-0000-0010-8000-00AA00389B71}, MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}
{00002000-0000-0010-8000-00AA00389B71}, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
MFAudioFormat_AAC, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_WMAudio_Lossless, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MFAudioFormat_WMAudioV9, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MFAudioFormat_WMAudioV8, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MEDIASUBTYPE_RAW_AAC1, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_MP3, MP3 Decoder MFT, CLSID_CMP3DecMediaObject
MFAudioFormat_MPEG, Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}
{00000031-0000-0010-8000-00AA00389B71}, GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}
{00000011-0000-0010-8000-00AA00389B71}, IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}
MFAudioFormat_MSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
KSDATAFORMAT_SUBTYPE_MULAW, G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}
{00000006-0000-0010-8000-00AA00389B71}, A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}
KSDATAFORMAT_SUBTYPE_ADPCM, ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}
Disabled Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\DoNotUse]
<transform CLSID>
Disabled Media Sources
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\DoNotUse]
<media source CLSID>
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
Quality Flags: 2576
Enabled:
Force throttling
Allow half deinterlace
Allow scaling
Decode Power Usage: 100
Balanced Flags: 1424
Enabled:
Force throttling
Allow batching
Force half deinterlace
Force scaling
Decode Power Usage: 50
PowerFlags: 1424
Enabled:
Force throttling
Allow batching
Force scaling
Decode Power Usage: 0
Diagnostics
Windows Error Reporting:
+++ WER0 +++:
Fault bucket , type 0
Event Name: PnPDriverInstallError
Response: Not available
Cab Id: 0
Problem signature:
P1: x64
P2: 0000045B
P3: hpvpl06.inf
P4: a2c13bc322b4fbc0dc22adc73c3025dfcafed587
P5: INSTALL_3050A_J611_VISTA
P6:
P7:
P8:
P9:
P10:
+++ WER1 +++:
Fault bucket 133177207413, type 5
Event Name: MoAppCrash
Cab Id: 0
Problem signature:
P1: Microsoft.MicrosoftOfficeHub_17.6106.23501.0_x64__8wekyb3d8bbwe
P2: praid:Microsoft.MicrosoftOfficeHub
P3: 16.0.6106.2350
P4: 55c40ea1
P5: Mso30Imm.dll
P6: 16.0.6014.1000
P7: 55a5783f
P8: c0000005
P9: 00000000000b9882
P10:
+++ WER2 +++:
Fault bucket 0x154_c0000006_c000000e_nt!SMKM_STORE_MGR_struct_SM_TRAITS_::SmIoCtxQueueWork, type 0
Event Name: BlueScreen
Cab Id: 0d704fa4-cdc1-4b07-9227-1da6c4ff7ca7
Problem signature:
P1: 154
P2: ffffe0007dc78000
P3: ffffd000276ab180
P4: 0
P5: 0
P6: 10_0_10240
P7: 0_0
P8: 768_1
P9:
P10:
+++ WER3 +++:
Cab Id: 0
Problem signature:
P1: x64
P2: 0000045B
P3: hpvpl06.inf
P6:
P7:
P8:
P9:
P10:
+++ WER4 +++:
Cab Id: 0
Problem signature:
P1: 154
P4: 0
P5: 0
P6: 10_0_10240
P7: 0_0
P8: 768_1
P9:
P10:
+++ WER5 +++:
Fault bucket 124752848148, type 5
Event Name: WindowsUpdateFailure3
Cab Id: 0
Problem signature:
P1: 10.0.10240.16397
P2: 80070643
P3: D34FD4FC-7FE3-4DF8-80A8-C22F61A9F17F
P4: Install
P5: 201
P6: 0
P7: 80070005
P8: Windows Defender (77BDAF73-B396-481F-9042-AD358843EC24)
P9: {7971F918-A847-4430-9279-4A52D1EFE18D}
P10: 0
+++ WER6 +++:
Cab Id: 0
Problem signature:
P2: 80070643
P4: Install
P5: 201
P6: 0
P7: 80070005
P10: 0
+++ WER7 +++:
Cab Id: 0
Problem signature:
P2: 80070643
P4: Install
P5: 201
P6: 0
P7: 80070005
P10: 0
+++ WER8 +++:
Fault bucket 124595281556, type 5
Event Name: MpTelemetry
Cab Id: 0
Problem signature:
P1: 0x80070005
P2: MpUpdateEngine
P3: AM BDE
P4: 11.1.5128.0
P5: mpsigstub.exe
P6: 4.8.10240.16384
P7: Windows Defender
P8:
P9:
P10:
+++ WER9 +++:
Fault bucket 124592468096, type 5
Cab Id: 0
Problem signature:
P1: unspecified
P2: HardeningTelemetry
P3: HardeningTelemetryDisableAS
P4: 4.8.10240.16384
P5: unspecified
P6: unspecified
P7: unspecified
P8:
P9:
P10:
From: JasbeerSingh [mailto:forums_noreply@adobe.com]
Sent: Thursday, August 27, 2015 10:19 PM
To: Julian Edwards
Subject: [Using Flash Player] Flash Player in Windows 10 won't play
Flash Player in Windows 10 won't playcreated by JasbeerSingh in Using Flash Player - View the full discussion Hi Can you please share the dxdiag of your machine. Below are the steps to obtain dxdiag:
Thanks If the reply above answers your question, please take a moment to mark this answer as correct by visiting: https://forums.adobe.com/message/7906583#7906583 and clicking ‘Correct’ below the answer Replies to this message go to everyone subscribed to this thread, not directly to the person who posted the message. To post a reply, either reply to this email or visit the message page: [https://forums.adobe.com/message/7906583#7906583] Please note that the Adobe Forums do not accept email attachments. If you want to embed an image in your message please visit the thread in the forum and click the camera icon: https://forums.adobe.com/message/7906583#7906583 To unsubscribe from this thread, please visit the message page at [https://forums.adobe.com/message/7906583#7906583], click "Following" at the top right, & "Stop Following" Start a new discussion in Using Flash Player by email or at Adobe Community For more information about maintaining your forum email notifications please go to https://forums.adobe.com/thread/1516624. |
I have now done a complete system restore and flash player is working partially in Edge and IE. But it will not play videos from websites (only the audio works). Sometimes it is black screen or pixels show up.
Chrome browser works well.
Is anyone there to answer this post?
I have now tried uninstalling flash player and shockwave, downloading shockwave again, turning off IE, turning it on again. Enabling shockwave in IE and disabling ActiveX. Nothing worked and flash player still won't run. Now what?
I find now that flash player works in Chrome for me!! But not Edge nor IE
Microsoft has woken up to the fact that lots of folks have similar issues
I have the same problem with Edge, IE, and chrome in windows 10 where most webpages with flash dynamic content crash upon load. I have tried just about everything and cant find a solution. Any Ideas?
I am getting the same issue on Windows 10 checked the Adobe flash settings and they are what they should be. Is there any staff here to help.
I have given up trying to solve this problem. Microsoft techs on the help line tried to help but couldn't. Adobe support is useless. I don't use Edge for anything. I use Chrome as my default browser. It plays anything and everything seamlessly.
