1 Reply Latest reply on Nov 28, 2006 5:36 AM by rson
    AS3 & AS help
      I have a bit of an issue. I am working on an app with JAVA & AS3. The app functions as an SMS gateway where message are filtered then qued to tcp in XML. Now the front-end has to be published in 7...not in 8 or 9. Therefore, in the shell or front-end I need to open a port by tcp and pull the xml. I felt the most efficient approach would be to create an XMLSocket. With this the shell is connecting and opening the port successfully, but when I attempt to pull the data my traces seem to be server configs(linux). Now my question is, is the XMLSocket the correct solution. Moreover, if not any ideas to how to open the tcp port and parse the xml? Here is the connection code that I am currently working with.
      Thanks in advanced.
