Hello,
Is there a way to get back the Quiz Review Area? When I created a quiz question, it was not there.
Captivate 8.
Many thanks,
Julie
For most quiz question types the Quiz Review area is not used now.
Which quiz question type are you referring to?
You don't need the quiz review area for this question type as the correct and incorrect answers are marked on the slide during Review Mode via small graphic icons.
It is still used, but only for the warning that a question has been skipped, and it is used on the Score slide. The change that Rod mentioned during Review has happened with Captivate 6.
Can you check the Quiz master slides? You can always copy/paste master slides from other projects.
Multiple answer question type.
THanks!
