2 Replies Latest reply on Aug 28, 2015 1:21 AM by Learn2Gro
    Dialog box: Create number of edit_text box counting number of annotes
    Learn2Gro
      HI Forum.
      Can you please help to auto create edit_text box counting the number of annotations in the PDF document.
      Instead of creating manually is that possible to auto-create Edit_Text... for example
      {name:"wkt1", item_id: "txt50", type: "edit_text",  multiline: true,  width:100, height: 100 },
      Thank you.
        • 1. Re: Dialog box: Create number of edit_text box counting number of annotes
          George_Johnson MVP & Adobe Community Professional
          I'm not sure what you're asking, can you clarify?
          Note that item_id strings must be exactly four characters, so "txt50" is not valid.
          • 2. Re: Dialog box: Create number of edit_text box counting number of annotes
            Learn2Gro Level 1
            Hi George. thanks for the reply.
            This is a folder action script:
            My requirement is to create the "edit_text" field in the dialogue - UI panel. The number of "edit_text" created in dialog panel depends on number of annotations marked in the PDF. For example if the PDF has 2 annotations then 2 "edit_text" field should be created and the annotations contents should be pulled into the edit_text field. Please see below the sample script.
            var annots = this.getAnnots();
            var cMyC = "QA_Name\tComment\t\t\t\t====>Job_Number";
            for ( var i=0; i<annots.length; i++ )
            cMyC += ("\n"+annots[i].contents + "\t\"" + "\t\"" + annots[i].page + "\"");
            var mm = cMyC;
            var QA_Tool = {
            annos: mm,
            initialize: function(dialog) {
            dialog.load({"text8":this.annos});
            commit: function(dialog) {
            var results2 = dialog.store();
            this.annos = results2["text8"];
            description:
            name: "Comments_QA", // Dialog box title
            elements:
            type: "view",
            elements:
            { name: "PLEASE CHECK YOUR QC COMMENTS", item_id:"txt15", type: "static_text"},
            type: "view",
            align_children: "align_distribute",
            elements:
            { item_id: "text8", type: "edit_text", multiline: true, width: 500, height: 100 }, // here all the annotations will be pulled inside the single text field, but intention is to create text field for each annotations and pull it inside.
            app.execDialog(Comments_QA);
            Thank you for the support.
