4 Replies Latest reply on Aug 27, 2015 7:24 PM by debbyc60598352
    LR6 Imprt Problem
    debbyc60598352
      I have my LR6 catalogue on my Internal HD "E".  My LR6 catalogue for the month of June 2015 is missing several days of images and I can't Import them as LR tells me they are already there.  Non of the missing days folders can be seen in the month of June.
      How do I get them into my catalogue?
      Thank you
      Debby
        • 1. Re: LR6 Imprt Problem
          ManiacJoe Adobe Community Professional
          LR says the images have already been imported, so there is no need to do so again; that just makes the problem worse.
          Check the Library grid for any folders marked as missing "!".
          From the Library grid, find some of the images you think are in the wrong folders, right-click on one and select "go to folder in library". From there you should be able to determine if the individual images are in the wrong folder or if the whole folder is under the wrong parent.
          • 2. Re: LR6 Imprt Problem
            debbyc60598352 Level 1
            As I said, the images are not listed in my Folders Panel so I can not find
            them in Library.
            As an Import test, I have now deleted one day of 7 images (2015/06/27) from
            my hard drive, after copying onto my Desktop ( I do have them on my back up
            external drive).  I then tried to Import these 7 into my catalogue and it
            almost worked except instead of getting my usual 2015/06/27  with images in
            the 27 folder I got another 2015/06/27 in my 06 folder!  I do not have the
            Include in subfolders checked off so I don't know why LR put them into
            repeat folders!!  Any ideas?
            • 3. Re: LR6 Imprt Problem
              I figured out the date problem.  The destination had to be E drive Images
              without 2015/06027 after the word Images. One thing solved.  The 7 images
              went to the correct folder in Destination and my E catalogue.
              I guess it means I have to copy the June folders onto Desktop, Delete them
              from my hard drive and Import so hopefully they will then be in the correct
              folder in my Folders panel E drive.
              Painful and I still don't understand why LR thinks they are in the
              catalogue when they are not in the Folders list in Left panel of LR.  Any
              ideas?  Missing images I can deal with bu
              t this is crazy when LR thinks the images are in the catalogue!  I must not
              be understanding something.
              Debby
              • 4. Re: LR6 Imprt Problem
                ideas?  Missing images I can deal with but this is crazy when LR thinks the
                Debby
