0 Replies Latest reply on Aug 28, 2015 1:44 AM by Andrew3358945
    Using Excel VBA writing JS to add watermark
    Andrew3358945 Level 1
      I'm new to JS totally but managed to use Excel VBA to do a watermark base PDF to add watermark to PDFs. most of the PDFs are ok but there are some that created problem.
      1. when it is with PDF/A type of PDF, the watermark will show on display and print preview but not printout
      2. certain watermarked PDFs are not showing watermark on display but show on print preview and printout.
      I'm using Acrobat DC Standard
      below is the VBA code that i do for watermarking, will that be anyway that i can fix it via js code?
      Dim base_PDF As String, Watermark_PDF As String, printThis As String
      Dim delfile, myw As String
      Dim j, k As Long
      Dim kk As Variant
      Dim cell As Range, i As Integer
      Sheets("Listing").Select
      myw = Sheets("Listing").Range("B2").Value2
      delfile = Range("I1").Value2 & "JN" & myw & ".pdf"
      kk = "C:\Temp\AMD" & myw & ".pdf"
      j = 7
      k = Range("A6").End(xlDown).Row
      For j = 7 To k
          If Dir(delfile) <> "" Then
            SetAttr delfile, vbNormal
            Kill delfile
          End If
          If (Range("H" & j) <> "") Then
              base_PDF = Range("J" & j)
              Sheets("PDF").Cells.ClearContents ' Make a watermakePDF
              Sheets("PDF").Range("K1").Value2 = Sheets("Listing").Range("B" & j).Value2
              Sheets("PDF").ExportAsFixedFormat xlTypePDF, kk, xlQualityStandard, True, False, , , False
              Dim pdfDoc1 As AcroPDDoc
              Dim jsObj As Object
              Set pdfDoc1 = CreateObject("AcroExch.PDDoc")
              If pdfDoc1.Open(base_PDF) Then
                  Set jsObj = pdfDoc1.GetJSObject
                  jsObj.addWatermarkFromFile kk, 0, 0, 0, True, True, True, 50, -1, 0, 0, False, 1, True, 0, 1
              End If
              pdfDoc1.Save 1, base_PDF
              pdfDoc1.Close
              Set jsObj = Nothing
              Set pdfDoc1 = Nothing
          End If
      Next
      Regards,
      Andrew
