• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
0
I want to use adobe sans mm in editing a document
Guest
Aug 28, 2015 Aug 28, 2015
Hi all,
I'm trying to edit a document but get a warning that the font adobe sans mm is not available on my system. It appears all the text in the document has been created in that font. It uses an alternative font, but not one that resembles the original at all. I would like a closely matching font, or even better just be able to use adobe sans mm. Otherwise, you can see my amendments if you look closely. I've found an arial font that will do as a substitute but want to do better.
Any ideas?
Thanks.
TOPICS
Create PDFs
Views
81.4K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Advisor , Aug 29, 2015 Aug 29, 2015
Adobe Sans MM and Adobe Serif MM are fallback fonts that Acrobat uses whenever a font is not embedded in a pdf.
These fonts are Multiple Master fonts that only exist within Acrobat and are not available at the system level.
According to Dov Isaacs at Adobe, you must have a font actually installed in your system to be able to use it to edit a PDF.
Think of these as virtual fonts that don't actually exist on your computer, so therefore they can't be used to edit a PDF.
You can see them and you can pr
Votes
Translate
Translate
Guest
Hi ,
If you want that specific font for your PDF,you could simply download that font from the web and would be able to edit the PDF in that particular font.
Regards
Sukrit Dhingra
Votes
Translate
Translate
Report
Report
Wrong! Adobe Sans is not a font “downloadable from the web.” And for that matter, it cannot even be licensed.
- Dov Isaacs, former Adobe Principal Scientist (April 30, 1990 - May 30, 2021)
Votes
Translate
Translate
Report
Report
Advisor ,
You can see them and you can print them, but you cannot access them.
The only exist within Acrobat and only come into play as a default font that Acrobat utilizes whenever the actual font that was used was not embedded.
(Multiple Master fonts never really became popular and are no longer produced. They have been superseded by OTF open type fonts)
Votes
Translate
Translate
Report
Report
To augment Bo's correct response ...
(1)   A document could absolutely not have originally been created using Adobe Sans or Adobe Serif. They are not installed or otherwise available for normal application use. As Bo indicates, they are special substitution fonts used by Acrobat and some other Adobe applications. It you open a PDF file and look at the Fonts panel of Document Properties (Ctrl-D), for a particular font entry, the only place you would see Adobe Sans or Adobe Serif would be as the font listed as Actual Font. This is the case in which the creator of the PDF file didn't embed the font and Acrobat has to try to find the font installed on the user's system or use a substitution font. For fonts such as Helvetica, Times, and Courier, Acrobat has the “smarts” to use system fonts Arial, Times New Roman, and Courier New respectively since they generally have identical set widths to the original fonts. Missing ITC Zapf Dingbats are replaces with Adobe Pi, and for anything else using a Western Latin character set, Adobe Sans or Adobe Serif is used depending on whether the original font was a san serif or serif style. These two Multiple Master technology fonts have the capability of matching the set widths of any other Western Latin font.
(2)  There are some very limited situations in which Adobe Sans and/or Adobe Serif can end up showing as the font of the text and possibly even embedded in a PDF file. That is the situation in which a PDF with non-embedded fonts and for which the fonts are not installed on the user's system is printed from Acrobat to the Adobe PDF PostScript printer driver instance, a process known as “refrying a PDF file” which is strongly discouraged by Adobe for some fairly obvious reasons. Since the original font cannot be found, Acrobat outputs PostScript using Adobe Sans and/or Adobe Serif in the PostScript stream and feeds that to the Distiller which them embeds those fonts in the refried PDF file.
(3)  If you are trying to get the look of Adobe Sans, whether or not you are trying to edit existing text in a PDF file or add text or even create text in a new document, use Myriad Pro. Adobe Sans was based on an early Multiple Master Type 1 version of Myriad. Myriad Pro is the closest font in terms of design and metrics to Adobe Sans. In terms of Adobe Serif, use Minion Pro. Adobe Serif was likewise based on an early Multiple Master version of Minion. Minion Pro is the closest font in terms of design and metrics to Adobe Serif.
Votes
Translate
Translate
Report
Report
New Here ,
May 18, 2016 May 18, 2016
Hi Dov,
       I tried myriad pro but it is some what differ from adobe sans , I need to use same like adobe sans mm. I tried minion pro also that too not work out. so can you please tell me the steps how to download adobe sans mm font for acrobat dc pro. Or please any exact matching font please do the needful. thanks in advance.
Votes
Translate
Translate
Report
Report
LEGEND ,
May 19, 2016 May 19, 2016
You should be very clear it is not possible to use this font.  The font, being multiple master, has no real native look; all aspects of its design including thickness and shape are changed to make a substitute close to an original. You must find another font; there are hundreds of thousands to choose from...
Votes
Translate
Translate
Report
Report
May 21, 2016 May 21, 2016
Adobe Sans is not available for the use you want it for. As previously indicated, Adobe Sans was derived from the older Multiple Master version of Myriad. The closest font to Adobe Sans now is Myriad Pro.
However, you should note that when Adobe Sans is found in a PDF file, it was probably used as a substitution font for something else and the widths of the characters, as found in your current PDF file, reflect the widths of whatever that original font was, not the widths of Myriad.
Votes
Translate
Translate
Report
Report
New Here ,
Aug 29, 2020 Aug 29, 2020
Sorry if this is a bump or reply is too late. Both AdobeSansMM and AdobeSerifMM may be indeed Metric Master fonts. However they may be converted to installable OTF files via any free font editing tool eg. FontForge. Then they can be installed into your computer and used in any document as you please.
Votes
Translate
Translate
Report
Report
LEGEND ,
Aug 30, 2020 Aug 30, 2020
Yes but that surely violates Adobe's licensing.
Votes
Translate
Translate
Report
Report
LATEST
There is no such thing as a “Metric Master” font.
Don't assume that you would get anything useful out of a “conversion” of either of those two fonts to some OpenType format. Which “instance” of the Multiple Master would you get?
And as previously pointed out, Adobe does not license either Adobe Sans MM or Adobe Serif MM for any use whatsoever beyond use in Acrobat itself as a substitution font. If you potentially want to hear from Adobe Legal, that's obviously the risk you take.
We also previously pointed out in this thread that if you want the design and metrics of Adobe Sans MM or Adobe Serif MM, you should be using Myriad Pro and Minion Pro font families respectively.
With that, we will close this thread since this we are revisiting the exact same area covered over five years ago.
Votes
Translate
Translate
Report
Report
