Hey, So I wanted to test an app on Xcode 7/iOS 9 beta and I'm getting this error. I'm using flash builder 4.7 btw.
Error occurred while installing the application:
Unknown or unsupported SDK version: /Applications/Xcode-beta.app/Contents/Developer/Platforms/iPhoneSimulator.platform/Develo per/SDKs/iPhoneSimulator.sdk
It runs fine on iOS 8 simulator. So does this mean that air 18 doesn't run on iOS 9? Sorry I don't have an actual device to install iOS 9 on.
Hello,
Thanks for reporting the issue.
This error is appearing because of not using correct xcode command line tools. Please set following properties -
1) Open xocde.
2) Xcode > Preferences > Locations > Command line tools
3) Set it to Xcode 7.
Also, please check following properties in flash builder > launch configuration -
1) Simulator SDK's location - /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneSimulator.platform/Developer/SDKs
2) Default Device - IPad
3) Simulator SDK Version - iPhone
...Copy link to clipboard
Hello,
1) Open xocde.
3) Simulator SDK Version - iPhoneSimulator9.0 sdk
Regards,
Mayank
‌Ah, thanks. The Xcode location was the problem. It was set at Xcode 6.4 still. The fb4.7 de budding doesn't work like in iOS 8 though. It pops up dialog box like if it was a real device. I'd hit ok but the debug isn't received by fb.
