1 Reply Latest reply on Aug 31, 2015 4:37 AM by resdesign
    remove unused images
    GraphicsGeezer Level 1
      How do you remove unused images form an Edge Animate presentation? I have several that I can't figure out how to get rid of and there doesn't seem to be anything in the manual about it. My OAM file is bloated and unusable without being able to do this.
        • 1. Re: remove unused images
          resdesign Adobe Community Professional & MVP
          You will have to first check that you have deleted any symbol that you are not using from the symbol panel and that are using any image you want to delete and then elete the images in the images folder.
          you might want to do that one by one to make sure you do not run into any problem so you can trace what image may be causing the problem.
          I have done that numerous times without any problem. The ony me time I get an error is when there is still a symbol containing an image I deleted which give an error but this error is corrected as soon as the symbol is  deleted
